SS Brake Line Suggestions...
Old Feb 6, 2011 | 10:48 AM
Laardilla21's Avatar
Laardilla21
Hey All,
I think the next mod on my car will be SS brake lines when I change out the fluid. Any suggestions on a specific brand?
Thanks!
-Johnny
Old Feb 8, 2011 | 06:51 PM
howsoonisnow1985's Avatar
howsoonisnow1985
I am gonna get some Goodrich ones from Tire Rack.
SS Lines
Goodrich
Helix
Ireland Engineering
Stop Tech
Fluids
ATE Super Blue
Motul RBF600
Old Feb 8, 2011 | 07:04 PM
Laardilla21
Awesome!
Thanks for the info. Also, I do not track my car, but I do several club events every few months in the mountains. Are the fluids you mentioned great for a car that is more daily driver than track car?
-Johnny
Old Feb 8, 2011 | 07:24 PM
jcauseyfd's Avatar
jcauseyfd
Dan at Grassroots sells some ss lines that look very nice imo.
I'm running the Super Blue now for daily driving and weekend spirited driving.
Old Feb 8, 2011 | 07:28 PM
Laardilla21
Thanks Jeff!
Dan had some slightly used ones there when I got my springs and sway bar done on the 29th. They were also a great color: blue! (Too bad you cannot really see them, though.) I will definitely call/email him tomorrow.
-Johnny
Old Feb 8, 2011 | 09:53 PM
howsoonisnow1985
You will be fine with Castrol GT LMA brake fluid and probably don't really need SS lines.
Old Feb 9, 2011 | 01:04 PM
ptrd's Avatar
ptrd
I used to have SS brake lines on the prelude and I remember reading about coated ones versus non-coated.
If it's just a regular rubber line with a SS mesh on top, those are wear items and probably need to be inspected every year.
If it's coated, I read they last longer. Reason being dirt / grime can get between the mesh SS and rubber hose and rubbing.
Just a thought if you really need SS lines.
Old Feb 9, 2011 | 05:24 PM
Vollgas's Avatar
Vollgas
Most performance car mfg. will recomend that the brake fluid be flushed every year. Even though it is a closed pressurized system, moisture can still get in to it, via the weather temperture.
You will notice a much more positive pedal feel with SS lines. A rubber brake hose line will expand via pressure increase. This will cause a "mushy" feel in the brake system.
I just changed my entire brake system and used ATE Super Blue. Any DOT 4
brake fluid is compatable with the system. Do not use 2 different types of fluid.
Old May 11, 2011 | 10:13 PM
princecasanova's Avatar
princecasanova
i recommend some good ones, I used to have SS brake lines and there are lots of Brake hoses & lines to choose from depending on your cars need. better check them out your self.
Old Jul 9, 2011 | 02:26 AM
Porthos's Avatar
Porthos
What did you end up getting because I really need to bleed my line really bad and want to get SS lines.
Old Jul 9, 2011 | 08:04 AM
Dwight Walhood's Avatar
Dwight Walhood
I've had NM's SS lines now for 2yrs. and +25K. They have a Teflon tube wrapped in SS mesh that's coated. They gave an immediate improvement in peddle feel and that hasn't changed to this day. Will be doing a fluid change soon and am going to Motul RBF 600 at that time. Will have to cut my fluid interval in half with that stuff, but so be it.
Old Jul 9, 2011 | 12:34 PM
sooper_cooper's Avatar
sooper_cooper
I'm planning to get a set for my car too. These are the ones I've found so far:
http://autoxcooper.com/carbotech_bra...s.html#ss_hose
http://www.waymotorworks.com/stainle...5-r56-r57.html
Old Jul 9, 2011 | 02:44 PM
toddtce's Avatar
toddtce
Add:
http://www.tceperformanceproducts.com/mini/kits-16/
Old Jul 9, 2011 | 04:50 PM
kukaepe's Avatar
kukaepe
+1 on NM stainless brake lines. Installed them, flushed fluid and pedal feel improved significantly.
squawSkiBum
Tires, Wheels, & Brakes
27
Nov 19, 2024 10:26 AM
W0TM8
Dec 19, 2019 07:50 AM
ebowling
90
Aug 4, 2019 09:15 AM
minimofo
Apr 4, 2016 07:36 PM
minimofo
Dec 26, 2015 11:45 AM
