Where are 36mm SHALLOW sockets?
Old Jan 2, 2004 | 08:28 AM
joshua's Avatar
joshua
i went to sears and looked online a bit, but can only find standard depth sockets. can anyone point me to the shallow ones or to the bmw tool?
thanks.
Old Jan 2, 2004 | 08:40 AM
scobib's Avatar
scobib
I ordered mine from here:
Samstag Sales
Awesome service and reeeeeeally quick delivery.
You need the Hazet HZ 2169-36 socket.
Old Jan 2, 2004 | 08:43 AM
canajun's Avatar
canajun
I went to the local Sears and picked up a regular 36mm socket for a 1/2 inch drive ... works like a champ. It was 'shallow' enough to fit back there even with the torque wrench. Best part ... cost less than $4.
Cheers
Geoff
Old Jan 2, 2004 | 08:44 AM
Casey's Avatar
Casey
I just went to sears and bought one there...it doesn't have to be shallow...as long as it isn't the deep...the normal ones will work fine...bring in a wrench and your MINI to sears...grab one and ask them if you can check to see if it fits...that is what I did - they let me take it out to my car and check before I bought it. A shallow would give you a bit of more room but with mine I can still get in there just fine. I couldn't find a craftsman one that fit, can't remember the brand I got - I'll double check tonight.
Old Jan 2, 2004 | 11:01 AM
apexer's Avatar
apexer
I bought a 1/2 inch drive 36mm from Sears, may have been the deep well because it was about 2" deep. Cost as I recall $5.99. Took it too a machine shop and had them take 3/4" off, cost $3.00. Works fine and, with hindsight, would probably been Ok without any machine work because I ended up using a 1/2 to 3/8 adapter inorder to use my 3/8 drive rachet to remove and 1/2 drive torque wrench after re-install.
Old Jan 2, 2004 | 11:37 AM
orthomini's Avatar
orthomini
matco tools sells them. you can find a dealer from their web site. part #2169-36. theyre not cheap though.
Old Jan 2, 2004 | 03:48 PM
Driving_Hamster's Avatar
Driving_Hamster
I recall a post a while back about people finding them at Walmart in there little half hearted-tool section. Hope that helps.
Old Jan 2, 2004 | 04:36 PM
fishey72's Avatar
fishey72
I got my 36mm at Sears also, standard depth socket. A 1/2 with an articulating head works like a dream for clearance, also bought a Sears.
Old Jan 2, 2004 | 06:30 PM
flyboy2160's Avatar
flyboy2160
that was me getting the stanley large metric 1/2" drive socket set at walmart. they have "flank drive" and the whole set cost about $15.
right, the walmart tool section isn't like sears, but hey, i got flank drive sockets, mobil 1 oil, popcorn, grape juice, and razor blades all in one stop! so there!
flyboy2160
Old Jan 2, 2004 | 09:48 PM
The_Beastmaster's Avatar
The_Beastmaster
Sears was out of the 36mm so I went to Home Depot and got one.
Old Jan 10, 2004 | 10:19 PM
zgokart's Avatar
zgokart
_________________
My local Sears store did not carry the 36 mm socket, so I'll try Home Depot. BIG question: is the Sears or Home Depot socket hexagonal or multi toothed? I prefer the hex socket because it fits the drain valve nut without chewing out the corners of the nut. Thoughts on this, anyone?
P.S. the Samstag website shows a shallow 36mm German made socket intended for Mercedes (but good for any 36 mm nut size), but it is quite expensive at $20 something.
Old Jan 10, 2004 | 10:21 PM
zgokart's Avatar
zgokart
Correction: I meant the oil filter canister nut, not the drain valve. Still thinking of the Fumoto oil drain valve which I purchased.
Old Jan 11, 2004 | 06:47 AM
apexer's Avatar
apexer
I think the Sears is multi-tooth but, no worrys on chewing up the canister nut as it isn't torqued that tight... just about 1/4 grunt
Old Jan 11, 2004 | 07:48 AM
BigBrownDog's Avatar
BigBrownDog
I did the same last weekend, Sears Hardware sold me the normal length 36mm socket, 1/2" drive, 12point for $5.99. I used my normal Craftsman 1/2" socket wrench and there was plenty of clearance.
I bought the Mobil-1 at Walmart in a 5qt jug, it was cheaper than 5 1qt bottles and once I put in the new oil I had a handy jug just the right size to hold the old oil for recycling.
I tried searching Walmart for the elusive socket set but none to be found here.
R3411y
Nov 23, 2015 01:10 PM
EVMini
Sep 28, 2015 10:20 AM
rt808
Sep 25, 2015 01:59 PM
StillK
R55 :: Clubman Talk (2008+)
Sep 10, 2015 12:17 PM
Sep 10, 2015 11:55 AM
