R55 brake light
Old Sep 7, 2015 | 04:51 PM
StillK's Avatar
StillK
brake light
The brake light on the passengers side of my 11 Clubman was not operating - got the dead bulb icon. I bought a new bulb and installed it and no luck. While removing the bulb socket from the housing I noticed that the plastic around the socket was slightly distorted - like it melted ever so slightly - the socket was also harder to remove and reinstall than the other sockets. I tried adjusting the contacts but no luck. Any ideas - anyone with similar experience
Old Sep 7, 2015 | 06:37 PM
Drivehard's Avatar
Drivehard
I would get a new socket holder. BMW mini warnings are based on increased resistance so any thing shy of normal will tend to set a light. Btw check the other side you may have a bulb on the way out. Take them out and hold them up to the light. If they are shaded in a little bit of black then get new bulb.
Sent from my iPad using NAMotoring
Old Sep 9, 2015 | 01:30 PM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
Usually it's best to replace bulbs in pairs, as stated above, as they typically go out pretty close together. Yes, it may be best to replace the socket and see if that resolves the issue. Determine what socket is needed, 63212756177 or 63212756176.
888.280.7799 | 6am - 5pm PST
Old Sep 10, 2015 | 12:17 PM
StillK - Do you have a pic ? I can help you out, sounds like the socket holder.
theblackfalcon
Oct 11, 2015 09:49 AM
Powershift
Aug 16, 2015 05:14 PM
Terry Gallentine
Aug 11, 2015 03:31 PM
