Help Grinding/Crunching noise when starting
Old May 4, 2010 | 06:18 PM
Mini4CY's Avatar
Mini4CY
I took my 06 S out of storage about a month ago and have driven it a couple of times with out a problem. I took it out this morning and she started up great, but when I went to pick up my daughter from school today, I tried starting it and there is a loud grinding/crunching noise. It will start but the sound is horrible and I cannot imagine the damage that it is doing.
Any help in finding the problem would be great, seeing as the closest current dealer is about 2 1/2 hours away.
Old May 4, 2010 | 06:59 PM
-=gRaY rAvEn=-'s Avatar
-=gRaY rAvEn=-
Moderator
Where in the engine bay is the noise coming from, pass mid area or drivers side - if you can tell ?
Old May 4, 2010 | 07:01 PM
Mini4CY's Avatar
Mini4CY
It is hard to tell, if I had to try and pin point it I would say Pass mid area.
Old May 4, 2010 | 07:06 PM
-=gRaY rAvEn=-
Moderator
could be your Hydraulic engine mount......there are tons of threads on that here.
Old May 4, 2010 | 07:08 PM
Mini4CY's Avatar
Mini4CY
Any idea what it would be if it were on the drivers side?
Old May 4, 2010 | 07:09 PM
-=gRaY rAvEn=-
Moderator
Look at these photos and see if you have same brownish stains....
https://www.northamericanmotoring.co...tor-mount.html
Old May 4, 2010 | 07:14 PM
-=gRaY rAvEn=-
Moderator
If drivers side could be the water pump, but on an 06 ? Sorta doubt it.
Part No 1 below. It is driven by gears from the Supercharger....How many miles on your MINI ?
Old May 4, 2010 | 07:16 PM
Mini4CY's Avatar
Mini4CY
There are no stains there, any other idea's?
Mini4CY's Avatar
Mini4CY
about 53,000 miles. It does sound like gears grinding together.
Old May 4, 2010 | 07:25 PM
-=gRaY rAvEn=-
Moderator
Yikes...Could be SC gears then at water pump side ?
And other symptoms Mini4CY before the loud grinding noises ? Normally there are some other unusual engine sounds before they get as bad as you describe- some time before hand, any sounds of chains being dragged on pavement ?
Old May 4, 2010 | 07:29 PM
Mini4CY's Avatar
Mini4CY
On occasion there was what sounded like a heat shield being dragged, but other that not nothing. The only time there is a grinding noise though is when I start the car. After it is started the car runs fine.
Old May 4, 2010 | 07:36 PM
-=gRaY rAvEn=-
Moderator
check this thread....
https://www.northamericanmotoring.co...-start-up.html
and this one...
https://www.northamericanmotoring.co...ing-noise.html
Old May 4, 2010 | 07:42 PM
Mini4CY's Avatar
Mini4CY
Neither of those links seemed to work for me. But I guess I should put up a sound file on this. The sound is only while it is starting, are there gears in the starter motor? That was my first thought because once the car starts it does not make any odd sounds.
Old May 4, 2010 | 07:44 PM
-=gRaY rAvEn=-
Moderator
Sorry first link was bad...could be. Did the alternator light on your dash ever activate ?
Melvinyip
Apr 17, 2020 09:28 AM
maestro39
Oct 27, 2015 02:38 PM
theblackfalcon
Oct 11, 2015 09:49 AM
tacticalbacon02
Aug 22, 2015 06:05 PM
patrioticmini
Aug 20, 2015 10:54 AM
