R56 Replacing side blinker
Old Jan 15, 2010 | 11:42 AM
ZipGun47's Avatar
ZipGun47
I was driving to work today and heard a thumping noise; I looked out my window to see my side scuttle fixture flapping wildly about (this is while doing 75 on the highway) By the time I could get over to the shoulder, it had completely ripped off, leaving me with just the wires to the light sticking out. So my question is, is replacing the light fixture something I need a professional to do, or is it relatively simple? I haven't had a chance to look at it under the hood yet.
Old Jan 15, 2010 | 12:07 PM
trwxxa's Avatar
trwxxa
Easy to do, unless the connector for the light got torn off too. The light fixture hooks into the scuttle on the forward end, and back of it snaps in (when you see it, you'll figure it out).
The scuttle piece has hooks that snap into slots on the quarter panel. Raise the bonnet, press the hooks into the slots, and slide towards the rear. Again, once you see it, you'll figure it out.
If you want to see how it works on your remaining side marker light, raise the bonnet, and use the heal of your hand to kind of snap the assembly forward. It should pop right out.
I'd take pics, but my Cooper is 800 miles away right now. Perhaps someone else will post some.
Old Jan 15, 2010 | 12:21 PM
djam43's Avatar
djam43
look in your manual under "changing the bulb for that fixture". It will tell you how to remove it.!!!
Old Jan 15, 2010 | 12:26 PM
ZipGun47's Avatar
ZipGun47
It's not just changing the bulb, it's replacing the whole thing, as all that's left is the wires sticking out; the bulb and its housing came off as well. I attached a pic.
Old Jan 15, 2010 | 12:34 PM
schatzy62's Avatar
schatzy62
I would recommend going back to the dealer as soon as possible (today) and explain that it just fell off. Some dealers will take care of you. This has happened to other people as well.
Old Jan 15, 2010 | 12:41 PM
ZipGun47's Avatar
ZipGun47
It wasn't the stock scuttle though, I had put on the black jack ones. I suppose I could take off the other black jack and put on the original, but that's a bit...shady.
Old Jan 15, 2010 | 01:34 PM
Porthos's Avatar
Porthos
Get the LED ones offered at Mini Mania they are awesome. Plug and Play
Old Jan 15, 2010 | 02:24 PM
MINIxB's Avatar
MINIxB
Go to the dealer. They should replace it (including the Black Jack sides) under warranty.
Old Jan 15, 2010 | 02:41 PM
drewstermalloy's Avatar
drewstermalloy
I agree with Porthos, but in this case I'd still take it to the dealer first.
Old Jan 15, 2010 | 05:09 PM
Porthos's Avatar
Porthos
Well ya take it to the dealer to get stock parts but LED side repeater FTW
Old Jan 15, 2010 | 06:05 PM
Joey D's Avatar
Joey D
Got a link to these? I didn't see them on their website.
Old Jan 16, 2010 | 11:38 AM
Porthos's Avatar
Porthos
OOPPSS! What I meant to say was Moss MIN, http://www.mossmini.com/Shop/ViewPro...eIndexID=71141
Here is the ones I got.
Old Jan 16, 2010 | 11:40 AM
Joey D's Avatar
Joey D
Cool thanks, do they throw a bulb out warning or no?
Old Jan 16, 2010 | 11:53 AM
Porthos's Avatar
Porthos
No warning and fixed the link
Old Jan 16, 2010 | 12:17 PM
saturn's Avatar
saturn
Any particular reason that anyone knows why these don't look like the one's on their website?
The reason why I ask is because I very much like the frosted lens rather than the clear one where you can see all the innerds.
OK Edit here: Porthos, did you get the black ones?
Old Jan 17, 2010 | 10:10 AM
trwxxa's Avatar
trwxxa
So you did lose the lamp connector. I expect the dealer will charge you some $$ to replace that.
If you can handle a soldering iron and heatshrink tubing, you could just go looking for a wrecked MINI in a boneyard, cut the connector (and about 3 inches of wiring) off of it and splice it onto what's left of yours.
Old Jan 17, 2010 | 09:14 PM
Porthos's Avatar
Porthos
The reason is because I got the black ones not the chrome ones.
boostedhaze
Jan 2, 2018 07:26 PM
thebordella
Aug 31, 2015 01:37 PM
cm.d
Aug 19, 2015 08:51 AM
Mini-Hype
Aug 17, 2015 06:32 AM
Minibeagle
Aug 13, 2015 10:00 AM
