R56 Washing the key fob
Old Jan 15, 2010 | 05:34 AM
AustinS's Avatar
AustinS
Washing the key fob
Shhhh...don't tell anyone, but I inadvertently let my key fob in my pocket and it went through a one hour wash cycle and 45 minutes in the dryer.
When I found it taking the clothes out of the dryer I thought, Oh great, now I am out $85 for a new one. At least that's what I have heard they cost.
It was very hot to the touch, so I let it cool down before trying it, but all is well and it seems to work fine. I can hardly believe I was so lucky I didn't ruin it but I am sure happy. I wonder if anyone else has done this.
Old Jan 15, 2010 | 05:47 AM
darmog's Avatar
darmog
Consider yourself luckier cause the cost of a new key fob isn't $85..it's more $200+.
Old Jan 15, 2010 | 05:58 AM
Fatherdeth's Avatar
Fatherdeth
If you accidently wash one of these, most of the time as long as you give it a chance to dry out before attemping to use it, you're fine. My wife's Mazda 6 key got washed a week ago. I just let it air dry and it was fine. On the other hand, I've never experienced having one go through a dryer cycle. That could possibly ruin one more so than the water. I'm glad you didn't have to spend that amount of money.
Old Jan 15, 2010 | 06:46 AM
drewstermalloy's Avatar
drewstermalloy
$85? I have heard them being well over $300.
Old Jan 15, 2010 | 06:52 AM
iwashmycar's Avatar
iwashmycar
yikes. i thought they were like sub-100 too. thats nuts
Old Jan 15, 2010 | 06:55 AM
schatzy62's Avatar
schatzy62
Well you got it partly correct there just needs to be a 2 in front of that 85.
Don't ask how I know I will not tell.
$285 + tax is what my dealer charged me a year ago any way.
Old Jan 15, 2010 | 07:55 AM
jimz68's Avatar
jimz68
Yep! I've run mine through the wash/dry as well.
Still works fine and smells Rain Forest Fresh!
Jim
Old Jan 15, 2010 | 08:08 AM
lotsie's Avatar
lotsie
One of our Clubman keys got washed, works fine.
Mark
Old Jan 15, 2010 | 10:22 AM
Julien321's Avatar
Julien321
Never try to use a wet electronic device (OP lucked up). Always completely dry. Best to place in a clean air tight jar with silica gel for 2 to 4 days then give it a try.
Old Jan 15, 2010 | 11:28 AM
911Fan's Avatar
911Fan
Next time, swish it around in some deionized (or distilled) water when it comes out of the pocket after washing/drying and then let it dry completely before using it. The objective is to rinse out residues from ordinary tap water which can interfere with the electronics.
BTW, electronic boards are routinely washed after manufacturing.
Old Jan 15, 2010 | 11:33 AM
Robin Casady's Avatar
Robin Casady
But not with batteries in place.
I suspect the fob is designed to survive being washed. It is obviously a common occurrence.
Old Jan 15, 2010 | 11:48 AM
911Fan's Avatar
911Fan
Actually, in some cases boards have batteries soldered to them and they still get washed. It's the water...
Old Jan 15, 2010 | 12:25 PM
mochi's Avatar
mochi
Mine went through a whole wash cycle once. Found it in the washer while transferring clothes to the dryer. Still works fine but I wouldn't want to try it again.
Old Jan 15, 2010 | 01:32 PM
MauriceW's Avatar
MauriceW
I'm glad to know I'm not the only one who's done this!
Old Jan 15, 2010 | 01:35 PM
Flyinace2000's Avatar
Flyinace2000
You can also use a zip lock bag or tuperware w/ rice. Does a very good job.
Old Jan 15, 2010 | 04:18 PM
Julien321's Avatar
Julien321
Actually this is an old wives tell and isn't correct. Cold dry rice does a poor job of absorbing water. It must be heated to a high temperature in order to break down the starches before it starts absorbing any significant amount of moisture (water).
It's use in the salt shaker is more about keeping the salt free flowing than absorbing moisture.
Old Jan 16, 2010 | 01:02 AM
Sketch's Avatar
Sketch
Wow thats some story. FWIW, some dude on ebay sells R56 fobs for $85.00
Old Jan 16, 2010 | 05:38 AM
AustinS's Avatar
AustinS
It's good to know I'm not the first, or the only, one to do this.
Old Jan 16, 2010 | 11:49 AM
Robin Casady
Before ordering from ebay better ask your dealer if they can/will reprogram it for your car, and what they will charge.
Old Jan 16, 2010 | 02:06 PM
Flyinace2000
On a recent episode of the AV Rant podcast he put up specialized beads for saving your electronic and rice. The rice absorbed several times more than the synthetic beads.
http://lifehacker.com/269427/dry-out...adgets-in-rice
http://www.audioholics.com/reviews/p...and-conclusion
Old Jan 16, 2010 | 02:57 PM
mattsenpai's Avatar
mattsenpai
It's amazing how you guys can fit such a monstrosity of an object in your pocket!!
Old Jan 16, 2010 | 03:36 PM
Robin Casady
Fits nicely in the coin pocket on Levis.
Old Jan 18, 2010 | 11:27 AM
BoxedUp's Avatar
BoxedUp
More info is required to assist with your situation:
Did you use the delicate or heavy duty wash cycles? What were the wash and rinse cycle temperatures? Front load or top load?
Did you wash with just whites or a mixed load?
Chlorine bleach or all fabric detergent?
Did you dry it on permanent press setting? Timed or automatic?
Did you use fabric softener in the wash or those sheets in the dryer?
(...and my wife thinks that I don't know how to do laundry. I just don't let on that I do. Besides, I never ask her to wash the cars. Why should I do the clothes?)
Old Jan 18, 2010 | 11:28 AM
BoxedUp's Avatar
BoxedUp
Hey, let's not get personal....
Old Jan 18, 2010 | 12:09 PM
Flyinace2000
THATS WHAT SHE SAID!
BOOYA!
