very rough idle, limp mode and a P1125 my car hates me
Old Nov 25, 2009 | 08:34 PM
Malcon's Avatar
Malcon
I was driving to target earlier tonight and my service engine light came on. It was throwing a code P0171, ok. I leave target and the light is still on. About a mile away from my house I give the car gas and it just lost power (i think this is the dreaded Limp mode) I could only get the car up to around 10 mph and the gas pedal wouldnt do to much. It would only raise the RMPs to around 2100 or so.. i'm not sure i was a little busy trying to avoid traffic. When I got to the apartment, the car was idling very rough. almost light it was missfiring on a cylinder. It was doing this around 850 rpm or so. I turned off the car and restarted. the car wouldnt stay running unless I gave it gas. then it would go back into that rough idle...
I've read that this may be a bad spark plug, the plastic air inlet that is connected to the supercharger may be cracked.. or the throttle body could be bad...
Anybody have any ideas? or Live near burbank that would have the time to possible come check it out with me?? I just moved to Burbank and really dont know where any good garages are... boo!
thanks for the help and feedback!
Old Nov 25, 2009 | 10:00 PM
Malcon's Avatar
Malcon
ok well I tried to reset the ecu by leaving the battery unplugged for a few hours (not sure if the time matters)
Now I get two codes. the P1125, and now its paired with P0638
I havent found what P0638 is yet.. but any code is no good....
ah... so frustrating
Old Nov 26, 2009 | 08:32 AM
Revolution Mini Works's Avatar
P0638DTC Definition:Throttle Actuator Range/Performance (Bank 1)
P0171DTC Definition:System Too Lean (Bank 1) Call Danny and he will get you back on the road!
11316 Burbank Blvd Unit B
North Hollywood, CA 91601
Phone: (818) 505 - 8240
Email: danny@minicorsa.com
Old Nov 26, 2009 | 11:40 AM
Malcon's Avatar
Malcon
Thanks Jan! I'm going to give him a call tomorrow since today is thanksgiving
So this morning I went out and checked everything. The belt is fine, i checked all the spark plugs etc... nothing seems out of place. The car was running really rough, and it would rev up and down between 1200-1800.. so i turned the car off.. looked around and cranked it again.. it was a little bit better... so i did the same. I turned the car off and turned it back on...
Everytime I did this it got a little better... untill the car is running like normal again...
Do you think this could be bad gas? or something was clogged???
I'm going to go grab some injector cleaner and dump it in the tank to see if that helps. and drive around all day to make sure everything is running ok....
hmmm
MINI's have a mind of their own sometimes..
Old Nov 26, 2009 | 11:42 AM
Malcon's Avatar
Malcon
oh and the car also pulled the codes P1125, and P1126 on the first start up this morning... It had just done the P1125 earlier...
i dont know. We'll see what Danny has to say about it I guess
Old Nov 26, 2009 | 12:13 PM
Malcon's Avatar
Malcon
well I was on the way to autozone. and i noticed a delayed reaction from the throttle body. also I heard the throttle body suck in air as if i pressed the gas a few times.. only i didnt press the gas. so I think it is the throttle body freaking out on me...hmmm
Old Nov 26, 2009 | 04:09 PM
Malcon's Avatar
Malcon
FOUND THE PROBLEM!
So a few months ago I had an engine management unit installed. There was a wire that was connected to monitor the TPS. Well it turns out that when the unit was removed it left the wire nicked, and that wire was never repaired all the way. So I fixed the wire and now everything is back to normal. No codes. and I even have a little better throttle response haha.
anyway I'm really happy that it wasnt the throttle body and that I didnt have to replace the harness!.
thanks for all the help!
Old Nov 28, 2009 | 01:20 PM
Professor's Avatar
Professor
Good job on finding the issue brother!
Old Nov 28, 2009 | 06:09 PM
the platform's Avatar
the platform
...well,at least you now know who the best mechanic is in the area!
Hell,I drive from Vegas to have Danny work on my car.
Old Nov 29, 2009 | 01:39 AM
MrCooperS's Avatar
MrCooperS
Moderator
Wow all that from a nick of a wire... scary...
Old Feb 12, 2010 | 10:35 AM
MINI COOPER TEAM's Avatar
MINI COOPER TEAM
i have the same problem,,
please explain that : There was a wire that was connected to monitor the TPS.
and witch wire was nicked?
is that the only reason for this code ( 1125 ) ??
i installed four therottle body and still have this !! :(
plaese help
THANKS
Old Feb 24, 2010 | 07:19 PM
McGiver's Avatar
McGiver
Code P1125
I am having the same problem intermitantly. The computer goes into lock out mode about once every 400-500 miles. I checked all the connections to the accelerator, throttle body, computer, and changed the throttle body. I thought I had it but its back. Does anyone know where to get a good service manual? I want to check voltages and see if theres a way to calibrate the throttle body.
iggi
18
Feb 9, 2026 01:00 AM
nomar116
Aug 10, 2015 11:24 PM
xpunisherx
Aug 10, 2015 10:50 PM
Lt. Dan
Aug 10, 2015 08:23 AM
tippin
Aug 5, 2015 08:43 AM
