OBD p1776 1776
Old Aug 16, 2009 | 11:29 PM
genebaker's Avatar
genebaker
OBD p1776 1776
"Service Engine Soon" light on my '05 MCS auto-transmission. OBD meter shows 0700 and 1776. 0700 makes it a transmission problem, but I don't know the meaning of code 1776 within MINI or BMW.
Anybody know the code fault? Any specific experience with this fault? Thanks.
Old Aug 17, 2009 | 01:33 AM
not-so-rednwhitecooper
Trans fault. P0700 Transmission Control System Malfunction, P1776 Solenoid Switch Valve Latched in Low Reverse Position.
Old Oct 31, 2009 | 10:47 AM
sjungers's Avatar
sjungers
I have the same codes(p1776 & 0700) comming up. plus the abs light also. did you ever find out what the problem was.my transmission seems to function ok. thanks
Old Oct 31, 2009 | 06:32 PM
genebaker's Avatar
genebaker
The problem was the ABS speed sensor. In my case, it was the left front.
I found a kind Mini shop that put a full diagnostic computer on my Mini, and he was able to get the detail code for the front left ABS speed sensor. This is an easy fix and took me less than an hour to replace the part. The part cost about $70.
Old Oct 21, 2011 | 10:18 AM
SilverBullet05's Avatar
SilverBullet05
So how would one find out which sensor wire is bad,
Scanning the Code doesn't specify which cable....other than
physical damage how would I be able to tell?
PsychoRallye
21
Feb 17, 2019 06:08 AM
JLSM511
Feb 25, 2016 01:02 PM
potterstein
Sep 13, 2015 09:57 PM
mtwaddle
Sep 13, 2015 08:10 PM
potterstein
Sep 11, 2015 09:24 PM
