Suspension Ripped front strut mount!!!! HELP!!!
Old May 5, 2009 | 05:42 PM
drftobin's Avatar
drftobin
Is it bad to drive my car with a completly ripped front strut mount!!!
Old May 5, 2009 | 06:34 PM
onasled's Avatar
onasled
Interesting. Any pics?
Honestly, not that big of a deal to repair something like that. Need to find someone who can fab and weld.
Don't drive the car though!
Old May 5, 2009 | 07:00 PM
Ryephile's Avatar
Ryephile
If you mean the rubber portion of the strut mount, welcome to the club. Plan on replacing them every 30k to 50k miles, and more often if you run lowering springs. It's not at all a good idea to drive on ripped rubber.
Old May 5, 2009 | 08:32 PM
quikmni's Avatar
quikmni
If you need to replace the top rubber strut bushing because it has ripped, you might want to think of a better replacement such as the IE Fixed Camber Plates or some adjustable Camber Plates such as from Hotchkis.
Old May 6, 2009 | 07:51 AM
davavd's Avatar
davavd
This happened to me in the warranty period (ripped 3/4 of the way around on passenger side). I called the dealership and they said it was OK to drive it in (75 miles). I did baby it, though.
Old May 7, 2009 | 08:36 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
Good time to get a set of camber plates, or if it's just your daily driver you can go back to oem.
http://www.waymotorworks.com/home.php?cat=288
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old May 8, 2009 | 06:48 PM
drftobin's Avatar
drftobin
Miniguru already ordered! came today {thank you} all I need is my M7 strut bar??
Old May 8, 2009 | 08:56 PM
Vendor
Bar shipped
Old May 8, 2009 | 09:05 PM
drftobin's Avatar
drftobin
Thanks!
Old May 9, 2009 | 04:06 AM
Usagee's Avatar
Usagee
I damaged mine a few years ago as well. I was taking the bends a little to hard. I switched them out for Ireland Camber plates.
Old May 9, 2009 | 07:38 PM
drftobin's Avatar
drftobin
Started the process to replace the mounts, with IE fixed camber plates. Also going back to the stock springs. Had some H&R's in but the roads here in Boston are so bad I need to bring the car back up to stock ride hight. Did the back today and removed the fronts, tomorrow switch the stock junked mounts with the IE camber plates and put the front back together. I also banged out some mild mushrooming I had, Alot easier than I thought I did the well known hunk O 2x4 and my big O'le hammer and in like 5mins done!!!
Old May 9, 2009 | 10:07 PM
JPMM's Avatar
JPMM
nice pics on your website, I'll be needing a set of IE plates and struts etc
Old May 10, 2009 | 11:59 PM
drftobin's Avatar
drftobin
Update !!!So I swap out the front springs,and add the IE camber plates. Can anyone tell me why the driver side is always more of a pain in the but than the passenger side! So when I was done I took it for a test ride and I heard a knocking in the back and when I got back it looks like my exhaust is closer to the bumper the before the switch back to stock springs. It looks like some how in the process of the job the exhaust moved? Any input from the masses would be helpful. Did not go back under the car to check yet I will tomorrow an post any findings.
Old May 11, 2009 | 01:40 AM
JPMM's Avatar
JPMM
Does no mount rubber mean vibration?
sorry can't help you out with the exhaust problem. But isn't there a reason for the OEM rubber isolators? To isolate the vibration of the road and tires? Does the aftermarket ( for example ireland fixed camber plates) have any rubber?(I don't think so) .If they don't ,will they transmit vibration through the cars body to the persons in the car?
Old May 11, 2009 | 06:52 AM
kazlot's Avatar
kazlot
Actually they do. And as a point of interest the bearing and rubber bushing that are used come from a BMW Z4.
Hope this helps...
Old May 15, 2009 | 09:45 PM
drftobin's Avatar
drftobin
Did some research with the exhaust, and ruled it out as the source! So I pulled out the left rear shock and spring unit, and tightened the top nut again, while makening sure the spring was fully compressed and that seemed to do the trick! Also while under the car made sure the sway bar end link & bushing bolts were tight, also control arm ,and sub frame bolts too. But I think it was the top nut on the shock that was knocking FIXED woohoo
Old May 15, 2009 | 11:08 PM
OldRick's Avatar
OldRick
The IE fixed camber plates have more rubber, and seem to run quieter than, the stock strut-top bushings.
Old May 15, 2009 | 11:48 PM
MINI_NS's Avatar
MINI_NS
I shroomed even with camber plates and a strut bar.....
Old May 16, 2009 | 07:10 AM
drftobin's Avatar
drftobin
Wow!!! MINI NS do you drive in a pothole covered city like I do in here in Boston? The roads here in boston are "BAD", its hard to enjoy driving my mini here while dodging pothole every 20yrds, even the highways around boston are covered in potholes. The Pothole that I think murdered my stock mount or at least finished it off was on 95N !!!
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Toolman
Jan 20, 2016 06:50 AM
sabjcw
Aug 14, 2015 07:40 AM
ClayTaylorNC
Aug 10, 2015 09:19 PM
