R52 HELP I can't see....
Old Sep 2, 2008 | 04:59 PM
Bleeding Eardrum's Avatar
Bleeding Eardrum
When I wear my perscription sunglasses with polorized lenses I can't read my Clock, Milege, or OBC can't even see the speedometer on the Tach.
Also noticing I can't read my sell phone unless I turn it 90 degrees to the right.....
Anyone else have this problem?
would Non-polorized lenses be better?
Old Sep 2, 2008 | 06:21 PM
cxg's Avatar
cxg
that would fix it
I wear non-polarized for that very reason. not easy to find either, but I bet tey et easier as people realize that it is the cause of that problem. Everything is LCD now.
Old Sep 2, 2008 | 07:38 PM
Bleeding Eardrum
Yep, the Polarized was a free upgrade since they didn't have non-polarized lenses in stock in my perscription "Coke Bottle"
Old Sep 13, 2008 | 08:57 AM
haygood's Avatar
haygood
Wow, that's good to know. I was planning on getting some polarized lenses. Guess I won't be driving with them.
If you tilt your head 90 degrees to one side, you should be able to see your gages. LOL.
Old Sep 15, 2008 | 11:21 AM
LIWexler's Avatar
LIWexler
try rotating glass covering
I wear my polarized sunglasses all the time, and have little problem reading my gages. Since polarized lenses line molecules up in lines, try rotating the glass on the gages (if you can) and see if that helps. It might be more trouble then it is worth to loosen the glass and rotate it, but it is worth a try. You might also want to ask your eye glass place if they can rotate the lense 90 degrees the next time thy make your glasses. I love my polarized lenses, and couldn't think about life without them in a Cabrio.
Old Sep 15, 2008 | 12:51 PM
Kelly Girl's Avatar
Kelly Girl
i drive with polarized lenses.. and i can see my gauges fine.. unless my head is tilted 90 degrees...
you driving with your head tilted???
Old Sep 15, 2008 | 01:19 PM
haygood's Avatar
haygood
OK, Kelly Girl's post was funny. I thought we were talking about the LCD digits in the gage being polarized, not the big round gauge faces.
Polarized lenses oriented vertically wouldn't work so well. They are oriented to block the glare coming off of horizontal objects primarily, like roadways. I suppose they would work the same if you are talking about glare directly from oncoming lights (as opposed to lights that are going off? - you know what I meant). Somebody's lenses were ground crooked, I bet. We just don't know whose.
All I know is that I'm going to borrow some if I can and look at ma wafs MINI with them before I buy some of my own.
Old Sep 15, 2008 | 01:31 PM
rkw's Avatar
rkw
I use multiple polarized sunglasses (non-prescription) and have no problem reading gauges. You should talk to your optometrist about it. As LIWexler says, they should be able to make them with polarization set to a different angle.
If you have the problem with multiple devices (e.g. cellphone), it is possible that they made your glasses with polarization at the wrong angle. Go to a drugstore (or anyplace else that sells sunglasses) and look at your cellphone through other polarized sunglasses. If they all look the same except your prescription pair, yours may have been set to a non-standard angle.
Old Sep 15, 2008 | 03:48 PM
Bleeding Eardrum
I'm gonna bring the sunglasses back to the doc. this week sometime. I agree with the post about the glasses being cut on the wrong angle.
I'll keep ya posted as to weather my glasses were made wrong, or non-polarized solved the problem.
Thanks for the advice
MPB
Old Sep 15, 2008 | 08:10 PM
coopselt's Avatar
coopselt
From: Camano Island, WA, but wish was still Oahu, Hawaii
Weird post for car forum??
My two cents. I wear polarized sunglasses (non-prescription), and not only can't read any of the digital displays (even radio), but I see these little blocks in the windows...
Old Sep 15, 2008 | 08:42 PM
Motor On's Avatar
Motor On
I've worn several pairs of polarized sunglasses, different brands styles etc. put them in at different rotations, my best experience has been with ones that set the polarization at 45deg
Old Sep 15, 2008 | 09:53 PM
Bleeding Eardrum
yep yep, I see the little blocks in the tinted windows as well
MPB
Old Sep 16, 2008 | 03:15 AM
cg1's Avatar
cg1
Looks like you already got your answer - but for those grooving on Polorized and driving a 'vert. These are my favorites !!
http://www.wileyx.com/EcommSuite/Pro...G&ItemCode=695
Wiley X Airrage - NO sun over the top and NO wind -- its an incredible pleasure wearing these shades when driving my Mini. The padded lining comes out - if my top is up I remove it, if its down...in it goes.
Old Sep 16, 2008 | 05:37 PM
JustJAY's Avatar
JustJAY
Wow.... Just.... Wow
Cole9953
Apr 21, 2014 10:11 AM
dsleedesign
R59 :: Roadster Talk (2012+)
Apr 28, 2013 03:35 PM
jacobsen1
New York/New England
Apr 5, 2011 06:34 PM
adam_randell
Oct 25, 2009 09:28 AM
welshmenwillnotyield
Mid-Ohio Motoring Club
29
May 14, 2009 06:38 PM
