R50/53 Mounting the Scanguage II
Old Apr 23, 2008 | 08:55 AM
Frank Matyja's Avatar
Frank Matyja
Blew By U
I'm thinking of buying a Scanguage II but I'm in a quandry as to where to mount it. If anyone has a solution I would really like to see a picture of your mounting solution.
Frank
Old Apr 23, 2008 | 09:00 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Here's my writeup with pics.
I love this spot. Easy to see, easy to reach, out of the way, easy to wire, no obtrusive cables, mostly hidden from the outside by my inspection sticker. I put a piece of black-out tape over the port on the end, which makes it look even better.
Old Apr 23, 2008 | 09:09 AM
Eric_Rowland's Avatar
Eric_Rowland
Nice, Blimey! I may have to do that.
No pics, but currently I have mine just laying in front of the OEM gauge bundle between the downtubes. Have to take out the lighter for it to fit, but it's stable, and low enough that I can still see the oil temp needle (I don't bother with the voltmeter, though that shows, too)
edit: Blimey you should give some love to Way Motor Works in your writeup (he'll sell to NAM for $150 shipped, matching another 'group buy')
Old Apr 23, 2008 | 09:18 AM
BlimeyCabrio
Just edited my post to mention that - thanks!
Old Apr 23, 2008 | 09:25 AM
MINIAC's Avatar
MINIAC
Mine is mounted on a home-made bracket in the center-stack cubby:
More ...
Old Apr 23, 2008 | 09:28 AM
BlimeyCabrio
I like that bracket and install
But that's where I have my G-Timer installed.
Old Apr 23, 2008 | 09:38 AM
Eric_Rowland
That's where mine is - note that if you're really lazy, you can just lay it there (lighter removed) and wedge the wire behind the gauges (if so equipped.)
Old Apr 23, 2008 | 10:56 AM
JatoPrieto's Avatar
JatoPrieto
i have a couple of questions about this bad boy...
does it tell you your actual HP and boost?
and other than that, how usefull will thi tool be?
Old Apr 23, 2008 | 11:08 AM
BlimeyCabrio
It reports actual MAP (Manifold Absolute Pressure), and it calculates theoretical HP based on various engine parameters. You can program it to calculate approximate boost by subtracting a constant for your local atmospheric pressure. Read my blog post and you'll learn more.
But there are LOTS of other things to know about your car (in fact, things you can actually use and do something with), other than boost and HP...
Old Apr 23, 2008 | 11:29 AM
JatoPrieto's Avatar
JatoPrieto
ok thanks
Loony2N's Avatar
Loony2N
Mine's mounted like Miniac's. Except I just have it velcro'd to the underside of the toggles (not sure it that will work pre-R56). That way, I still have access to the cubby.
Old Apr 23, 2008 | 12:36 PM
Partsman's Avatar
Partsman
Legion_of_Doom
Here's mine...
...mounted right in sight. The IATs displayed right next to ambient on the tach.
Old Apr 23, 2008 | 07:29 PM
shokk's Avatar
shokk
7th Gear
Anyone know if Mini frowns upon plugging into the ODB-II port while under warranty?
Old Apr 23, 2008 | 07:34 PM
Eric_Rowland
If they do, they'll need to discuss it with CARB (California Air Resources Board), as they require connecting to the OBDII for smog checks.
Really though, no. You're not CHANGING anything in the car, you're just listening to what it has to say.
Old Apr 23, 2008 | 07:47 PM
Guest's Avatar
Guest
Frank
I just have mine mounted over my Navi (Right above the center Speedo if you don't have Nav). It's a good location for me cause my dash area is already too busy with gauges.
I've got my Speedo, Tach, Air Fuel, Oil Pressure and Oil temp gauges all mounted directly ahead. It's nice to be able to glance to the right a bit and see that, but not have it right in front of me. I'll take a picture when i can.
Old Apr 23, 2008 | 07:48 PM
Guest's Avatar
Guest
Even if they did they wouldn't have a way to tell. The OBDII port is for diagnostics, and tracks quite a bit of information. There's no reason why they'd care if you plugged into it.
Old Apr 23, 2008 | 08:50 PM
chpsk8's Avatar
chpsk8
I like the way Miniac has it the best. I have my navi mounted there though. I have mine mounted like Blimey. It's ok, but I may move it to the center of the dash. There are two downfalls with the dash mount. One is that it can be seen from outside the car. The other is that it is slightly crooked. I may move it to the center. It would be hidden from outside view by the wipers and be more consistent with the rest of the car. If you have nothing under the radio I would suggest mounting it there, it's the most stealthy. The downfall is that you have to look down to see the readouts. It really depends on what you use it for I guess.
I have mine set for speed and I'm going to add boost. Those two I want to see as a heads up. The other two readings are intake temp and water temp. I just need to check those occasionally.
As a side note...the orange color does match well with the rest of the lights.
Scangauge far left - Navi under the radio
Filmy
15
Jun 6, 2023 06:27 AM
BRebels
Electrical
20
Jul 31, 2016 02:10 PM
JCW Clubman 2010
Oct 1, 2015 01:57 PM
minimofo
Sep 30, 2015 12:26 AM
Sep 4, 2015 02:34 PM
