18x7.5 ET40 and lowering??
Old Mar 26, 2008 | 08:46 AM
fredde_f's Avatar
fredde_f
Hi!!
I have found a set of rims with deminsion 18x7.5 ET40 to my MCS -04... Planing to use 215/35/18 tires..
Anybody know if it will fit with 30mm lowering springs??
Please help me... Have looked aurond in the forum but haven't found any answers...
Best regards Fredde (Sweden)
Old Mar 26, 2008 | 12:17 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Originally Posted by fredde_f
Hi!!
Yes, it should fit.
If you need more clearance in the rear you can use more rear negative camber- add adjustable lower control arms.
Old Mar 27, 2008 | 01:16 AM
Coen_de_K's Avatar
Coen_de_K
easy!!! :D
Old Mar 27, 2008 | 02:58 AM
fredde_f's Avatar
fredde_f
Originally Posted by minihune
Yes, it should fit.
So in front you absolutely think it will fit??
how much do adjustable lower control arms cost?? do you got any sites??
Old Mar 27, 2008 | 03:00 AM
fredde_f's Avatar
fredde_f
Originally Posted by Coen_de_K
easy!!! :D
easy!!! you say:D
Do you know any who has it on his car???
Old Mar 27, 2008 | 07:51 AM
Wake|MCS's Avatar
Wake|MCS
easy!!! :D
x2
Old Mar 27, 2008 | 09:45 AM
Robmaster's Avatar
Robmaster
and what's about 17x8" ET35 and lowring...???
Old Mar 27, 2008 | 02:01 PM
Robmaster's Avatar
Robmaster
what's about a 17x8" with ET35? will this rub with lowring?
Old Mar 27, 2008 | 09:46 PM
minihune's Avatar
minihune
Using 215/35-18 or 225/35-18 tires you should be fine with moderate lowering 1" front and rear.
Again, more negative rear camber will increase clearance if needed.
Don't use tires that are taller than stock 24.3" tire diameter.
Rear lower control arms-
Various vendors:
http://www.helix13.com/mini/products/suspension-chasis $229 for pair.
or
http://www.outmotoring.com/mini-coop...es/suspension/
From $190 to $247 per pair. Weights and appearance vary, they are functional, only lower control arms need upgrade to adjust for rear negative camber.
Old Mar 28, 2008 | 12:11 AM
Robmaster's Avatar
Robmaster
my stock tires are 205/45/17. so i would put this tires on.
Old Mar 28, 2008 | 12:29 AM
roofaS's Avatar
roofaS
Both should fit fine.
I was running 18x8 et 38mm lowered 30-33mm - fine.
Now running 18x7.5 et42 (but with 5mm spacers upfront so effectively et 37mm) lowered 30-33mm - fine.
Old Mar 28, 2008 | 12:39 AM
Coen_de_K's Avatar
Coen_de_K
I had 18" 7,5J with an offset of 37... NO rubbing and lowered about 6cm's
I say EASY!!!
had 1cm spacer mounted... It fitted but was tooo much...
so I say EASY!! :D
good luck freddy!!
Coen
Old Mar 28, 2008 | 06:35 AM
fredde_f's Avatar
fredde_f
Thanks for all your answers... I think i'm going to by the wheels now:D
And maybe buy adjustable lower control arms if it rubbs...
Thanks again// Fredde
smdmini
Oct 7, 2019 06:05 AM
massmini03
Sep 18, 2015 05:40 PM
hydouken
Sep 15, 2015 05:49 AM
Sep 2, 2015 11:15 AM
