R50/53 error code
Old Mar 15, 2008 | 01:34 PM
emagers's Avatar
emagers
error code
Have an error code on my 2003 non-s MC. Came on after oxygen sensors were changed by a local mechanic. Code is P0130. Shop manual says is O2 sensor circuit ( bank 1 sensor 1). Comes on and off but mostly on. Plug in connection appears good and clean. Bought sensors from Minicarparts.com, appear identical to OEM sensors, plug connector etc, also identical to Bosch sensors. Thinking about just changing. Does anyone know is above code is pre or post catalyst sensor. Any other advice. Runs good gas milage normal. Thanks.
Old Mar 15, 2008 | 09:11 PM
Ancient Mariner's Avatar
Ancient Mariner
1/1 should be pre-cat sensor
Old Mar 16, 2008 | 03:28 PM
Jhud's Avatar
Jhud
new means never worked before.
Old May 7, 2008 | 02:51 PM
Silkworm's Avatar
Silkworm
Hey I just installed both of those sensors new from minicarparts.net on my o3 mcs i think the brand is amp and I have the same code that comes and goes. I think we may be starting a pattern If you solve this let me know im getting ready to buy a bosch and replace the precat one to see if it helps. I will also let you know if i come up with a solution. But its looking to be an off brand issue at this point.
Old May 7, 2008 | 04:29 PM
Jhud's Avatar
Jhud
what is the code exactly? p0130 is a generic code and doesnt offer much info as to the problem exactly ( ie. warm up phase, too rich, too lean, heating circuit, could be alot of things. )
Old May 27, 2008 | 05:20 AM
Silkworm's Avatar
Silkworm
to follow up after talking with emagers it looks to be the off brand sensors causing the issue. He replaced both with the boch and havent heard of the code comming back from him. Ill be replacing mine soon and ill add my results to this post for the search engine on the board.
p.s - The p0130 is rather vauge it says "O2 sensor malfunction bank 1 sensor 1"
-Josh
Old Jul 16, 2008 | 03:39 PM
Silkworm's Avatar
Silkworm
Installed new bosch precat today gimmie a week to put 150mi a day mixed on it and ill post my rersults also seems it cured my wierdo DSC light issue I was havin. (Heard the pre cat o2 was on same circut as the DSC so It kinda makes sense. fingers crossed and knocking on my head (AKA wood). Hope this thread helps some others like it has emagers and I. Glad to hear you cars runnin good with the bosch Emagers gives me hope for the week.
Old Sep 3, 2008 | 04:57 PM
spirit's Avatar
spirit
I just got my scangauge II and was able to read why my engine indicator was on. It was the P0130 (02 Sensor Malfunction). How would one go about finding out what needs to be fixed? I'm under warranty so I could make the 2HR trek up to a dealer.
Thanks.
Steffen.Johnson
71
Jan 26, 2021 09:11 AM
hamptup
R55 :: Clubman Talk (2008+)
18
Nov 29, 2016 05:04 PM
MiniSkoon
Sep 9, 2015 12:40 PM
MasterShaftner
Sep 4, 2015 03:52 PM
