R50/53 rattling issues...
Old Feb 6, 2008 | 02:31 PM
Tread's Avatar
Tread
rattling issues...
Hey all,
my mini (2005 s) makes a good bit of noise when going over rough road. It sounds like it comes from the back, and it comes and goes. Sometimes everything sounds nice and solid, other times, it sounds like the damn car is about to fall apart.
Is this a common thing, and has anyone found a solution?
thanks much!
Old Feb 6, 2008 | 02:38 PM
HighLife4136's Avatar
HighLife4136
Originally Posted by Tread
Hey all,
thanks much!
Welcome to the MINI Experience
Old Feb 6, 2008 | 02:57 PM
Tread's Avatar
Tread
haha, grrreeaaaat
Old Feb 6, 2008 | 03:09 PM
lotsie's Avatar
lotsie
MINIs are not very sound proof from road noise, and your sitting inches off the road. If you have your back seats folded down, or completely removed, the noise is even louder.
To fix this, play your favorite music with the little black **** on the stereo turned way to the right
Mark
Old Feb 6, 2008 | 03:34 PM
sequence's Avatar
sequence
and dont bug yr service advisor unless it gets REAL bad my dash had a rattle that at one time sounded like freaking bubble wrap being twisted and popped. Lotsie's li'l black *** trick didnt help. I told them it was a deal breaker that Id get rid of the car (aug 04 build 05 S) unless it was fixed. and shore nuff 4 shop days later it was. almost 2 years later it's come back, but at tolerant occasional scale dependent on road surface, moreso in winter. I turn up the CC
but sometimes the rattles are like a little plastic symphony tho, Rover conducting
Old Feb 6, 2008 | 03:47 PM
AstroBlackS's Avatar
AstroBlackS
If it sounds like a "clunk" sort of noise, then it may be the top strut nut, as that has been known to be a source of noise when not tightened down all the way. However that usually doesn't pop up unless the suspension was worked on or removed at some point.
Old Feb 6, 2008 | 05:47 PM
nabeshin's Avatar
nabeshin
Functioning Lunatic
Ditching the runflats and putting on some 15 inch rims will decrease or eliminate all rattles and creaks.
Old Feb 6, 2008 | 06:08 PM
ClubmanS's Avatar
ClubmanS
Common dude! Interior plastics seem affected by exterior temperature = creaks at times.
torpeau
Oct 8, 2015 11:10 AM
Jim Ferrell
Oct 6, 2015 08:09 AM
eliseo1981
Sep 30, 2015 07:57 PM
patsum
Sep 30, 2015 02:10 PM
Nicefeet
Sep 24, 2015 06:53 PM
