R56 Glove Box Organizer doesn't seem to fit?
I just got a glove box organizer for my '07 MCS, and it doesn't seem to fit the glove box...a touch too wide. Is there a trick to putting this in, or am I missing something obvious?
It fits, but in a very particular way. The easiest way I found was to open the glovebox and remove the stuff inside (duh). Holding the unit with the divider on top and the tapered end facing you, flip the unit vertically so the divider faces the glove box front of the car. Now move it forward into the glovebox. The unit should need to be tilted (45 degrees or so) down towards you as it is placed into the glove box. Once placed, when you let go of it , the unit will lay flat on the glove box door and you can close it. However, you will need to adjust the contents of the glove box forward and backward to ensure it closes corrrectly. Honestly, while it does do a good job of keeping the glove box organized, the odd shape causes a bit more space loss than most people will be willing to accept. Still it works well for me.
The SA here at my local dealer advised against buying the R56 organizer, saying it was not a good fit at all, and was not the best purchase.
Still not able to get it to fit....push hard, or following the instructions from Nimcosi. Mine looks completely different than the one shown in the pic above though....looks like this:
This is not a pic of mine, it is a pic I found on the web....doesn't look anything like the one I ordered. Did they send me the wrong one?
i cut mine down with a hacksaw... fits perfectly now!
Mine is an R56. However, after looking at the different ones available, I bought it from Minspeed (they sell the GoMiniGo organizer), but it looks like they mistakenly sent me the one for the R53 instead of for the R56.
I'm in the process of working that out with them now. That would explain why it doesn't fit!
Stealing Minidrivr's picture, I make sure my OEM R56 organizer matches up with the indicated indentation prior to closing. That works for me. However, I'm not impressed with the OEM organizer, and think that T-horn's GoMiniGo suggestion is probably the better way to go.
~Neal
~Neal
Stealing Minidrivr's picture, I make sure my OEM R56 organizer matches up with the indicated indentation prior to closing. That works for me. However, I'm not impressed with the OEM organizer, and think that T-horn's GoMiniGo suggestion is probably the better way to go.~Neal
Does the felt "shed" like the OEM one?
My OEM glovebox organizers never had any shedding issues...this is my second (first on an '03, and now on my '07). I like the finished edges of the OEM unit and the elastic hold-downs are very useful given that the unit moves up and down with the glovebox door. That said, for me the secret of making it work was getting it centered. If mine wasn't centered it seemed to hit some internal part of the glovebox as I closed it. It's not a precision thing, but one I got it roughly centered it's worked great. I just use it all the time and never give it a second though which, afterall, is what you should do with a glovebox organizer.
blackie
Jan 18, 2017 09:56 PM
minipopkart
Aug 13, 2015 05:22 AM
