Audio Integrations - sub enclosures and high-end audio fabrication for the MINI
Old Dec 21, 2007 | 08:23 AM
Mark's Avatar
Mark
North American Motoring :: Founder
Hey guys - we're new vendors here and are happy to be a part of the MINI community! As a quick introduction to our company we're an audio shop that specializes in custom fabrication design and installation as well manufactures our own line of vehicle specific subwoofer enclosures. There are three of us here, Nick - Business Operations/Sales, Ryan -Install/Fabrications/Sales, and Todd - Install/Fabrications/Sales. Please feel free to pm (Audio Integrations), email or call with any questions. Visit our site to see our latest products and design work!
Old Dec 22, 2007 | 04:18 PM
K_Blax's Avatar
K_Blax
Hey Guys,
I am wanting to install this Sony Explode amp in my MINI S and had a few questions. I think I will be able to do a custom intall in the right rear panel in the boot where the cd changer would go. I bought a kit to connect to the two rear speakers that converts into RCA imputs for the amp. My biggest question was power. Although the battery is in a super place for putting an amp in the boot of the car will my amp always be on if I hook up to the battery. "Normally you would run a blue remote wire to the head unit but I don't really want to get into all of the dash. Could I run the blue remote wire say from the rear 12V lighter socket to my amp. Would that be an ok spot to tie into since it only has power when the car is on or can the remote wire even work that way?
Thanks so much for you help,
Kris Blackwell
Pensacola, FL
Old Dec 22, 2007 | 04:43 PM
Audio Integrations's Avatar
Audio Integrations
Your amplifier will have a separate power wire (8 - 4 gauge), ground wire (8 - 4 gauge) and a remote turn on wire (16 - 18 gauge). You'll want to run a constant power ( 8 - 4 gauge) from the battery for the power input, make sure you fuse it within 18 inches or shorter of the battery. Then for the remote turn on you'll want to use a switched/ignition wire (power only when key/ignition is on). You don't want to hook the remote turn on wire to any circuit in the car that is constant, you'll also want to fuse the remote turn on wire as well.
If the lighter your referring to is on a switched circuit then that would work, but generally you only want your amplifier powered on when your radio is on. Hooking to anything other that the radio switched wire will keep your amp powered on regardless of the radio and can cause unnecessary wear on your amplifier. You'll also want to be careful the circuit you tie into can handle the extra current of the amp turn on, generally the factory fuses are only the correct amperage for factory devices in the vehicle.
Do you have the factory amplifier in your Mini?
Old Dec 24, 2007 | 08:44 AM
K_Blax's Avatar
K_Blax
I am not sure if I have a factory amp in or not. I don't have the Hardon Karmon sound system. Would the amp be located under the front seats? Maybe I could tie in there? I have an 05 Mini S
Old Dec 26, 2007 | 09:49 AM
Audio Integrations
No, the amp would be in the right side rear quarter panel if equipped, the turn on wire would be white there as well as at the radio.
There are some great threads stickied at the top of the audio section, below are a couple links about adding aftermarket gear to your mini, lots of info there on everything.
This thread is about adding an amplifier to a stock system
https://www.northamericanmotoring.co...highlight=amps
This thread is a directory about all topics on adding/changing audio system
https://www.northamericanmotoring.co...ad.php?t=26547
Old Dec 27, 2007 | 12:28 PM
redmini04's Avatar
redmini04
hey guys.
Here is the deal. My 04 MCS w/ HK, the rears went out, only squeeks and pops-even when the head unit is off. So i figure the amp is toast. Not going to put any $ into that. Actually I was always dissapointed with the HK. The solution (this is where I need your help). I want to rip out the back seat (backs and bottom) and make a platform...kinda make it into a mini station wagon. I figure then that I will have all this room to put subs and amp(s). Any suggestions on a Head unit, amp(s), sub(s), door and rear speakers. I want all new. What I want out of the system is volume, cd, sat compatible, aux for ipod. Don't need nav, or dvd.
Jim
Old Dec 27, 2007 | 01:34 PM
Audio Integrations
Originally Posted by redmini04
hey guys.
Jim
PM'ed ya a couple ideas/options, let us know what ya think and we'll figure something out.
Old Dec 28, 2007 | 09:20 AM
Montana82's Avatar
Montana82
Working on anything for the 2007 and on cooper models yet?
Old Dec 28, 2007 | 11:56 AM
Audio Integrations
we haven't gotten to it yet, it takes a while to build and develop one, and unfortunately at this time we don't have it on the schedule. It's been on our mind though...
Old Dec 28, 2007 | 01:28 PM
Montana82's Avatar
Montana82
Thanks for the reply. Is there anybody you recommend, since you don't have one? You can PM me if you'd like.
Thanks again.
Old Dec 31, 2007 | 08:56 AM
Audio Integrations
Thanks again.
PM Sent, Thanks!
Old Jan 11, 2008 | 07:58 PM
rrcaniglia's Avatar
rrcaniglia
What options do you have for after-market upgrades to the standard MINI speaker system in the 2008 models?
Old Jan 16, 2008 | 09:19 AM
Audio Integrations
Hey - We haven't had the chance to get an 08 in the shop yet, so we're still unfamilar with what's exactly doable. Are you looking at upgrading some of the factory audio components or maybe just adding a subwoofer?
Old Jan 16, 2008 | 04:37 PM
rrcaniglia's Avatar
rrcaniglia
I didn't buy the upgraded speaker set and got the stock radio/CD player. I'm interested in what is doable. I don't want to light up the neighborhood with bass or screaming highs--I've got some hearing loss from my time in the military and have to be careful--but can still appreciate a full, rich sound. The stock speakers were a bit anemic. I don't know if there is anything wrong with the radio/CD.
R
Old Mar 5, 2008 | 06:21 AM
bav_m_pwr's Avatar
bav_m_pwr
Is your sub box applicable to 2007s also, or just 02-06? Thanks!
Old Mar 8, 2008 | 08:51 AM
mistro's Avatar
mistro
wher are you guys located?
Old Mar 8, 2008 | 09:13 AM
Audio Integrations
Just the 02-06, we're looking for an 07 though to takje a peek at.
Originally Posted by mistro
where are you guys located?
Southern washington state, about twenty minutes away from portland
Old Mar 8, 2008 | 06:18 PM
bav_m_pwr's Avatar
bav_m_pwr
NC
Dec 23, 2015 10:36 AM
honderpilot
Aug 31, 2015 02:53 AM
marendt428
Aug 8, 2015 04:44 AM
tippin
Aug 5, 2015 08:43 AM
