Roll call - 8"+ wide wheels
Old Nov 9, 2007 | 01:20 PM
Wake|MCS's Avatar
Wake|MCS
I thought it would be a good idea to make a thread for those of you who are running wheels with a width of 8 inches or more. Wide wheels isn't commonplace here on NAM and it can be challenging to find info if you're looking to go this route. I'm hoping we can create some sort of a database where one can find info on wide(r) wheel/tire setups.
So, if your running wide wheels, whether they are staggered or not, post all the specs and a pic of your ride.
For example:
Wheel/Model: BBS LM
Offset: 30
Wheel Size: 17x8, 17x9
Tire Size: 205/40/17, 215/40/17
Suspension: KW Coils dropped appx. 2"
Camber Settings: -1.5 F, -2.5 R
Rubbing: No
Pic: Insert Pic here
*NOTE* The above is purely made up for the sake of showing an example.
Old Nov 9, 2007 | 01:56 PM
Wake|MCS's Avatar
Wake|MCS
I'll start us off... Hopefully Rally will keep us going
*NOTE* This is off memory, I'll look into it when I'm not here at the office.
Former member, D6-MCS.
Wheel/Model: Keskin KT4
Offset: ET35 F, ET25 R
Tire Size: 205/40/17, 215/40/17 (Bridgestone Potenza S-03)
Suspension: KW Coils dropped appx. 2.5"
Camber Settings: -? F, -? R
Rubbing: Cutting it close
Pic:
Old Nov 9, 2007 | 02:08 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
Guess I'll post my pictures and stats yet again Gonna probably be changing to new wheels next spring since these come off for winter soon.
Wheel/Model: BBS RM012 2-piece rims with custom Schmidt lips
Offset: ET13 F, ET8 R
Wheel Size: 15x8, 15x8.5
Tire Size: 205/50/15 on all four (Dunlop direzza)
Suspension: Megans drop=I dont know....a lot 2.5"+
Camber Settings: -2.5 F, probably -1.5 ? R
Rubbing: None up front...a little in the rear because i haven't set the camber to my specs yet. Arches were trimmed
Old Nov 11, 2007 | 03:24 PM
Wake|MCS's Avatar
Wake|MCS
Thanks for the post Rally. So no one else out here is running wide wheels and a nice drop? Tire stretch or poke isn't a necessity to be part of this. Just a wide wheel in general...
Anyone?
Old Nov 11, 2007 | 05:39 PM
snid's Avatar
snid
There are a few people out there running the 949 Racing 6UL in 15x8. The 949 website mentions a 15x10 coming soon.
Old Nov 13, 2007 | 03:29 PM
MisterDangerPants's Avatar
MisterDangerPants
Compomotive MO
Wheel/Model: Compomotive MO 6-spoke
Offset: 40
Wheel Size: 17x8
Tire Size: 215/45/17
Suspension: Stock
Camber Settings: Stock
Rubbing: None
Old Nov 13, 2007 | 04:45 PM
chili_red07's Avatar
chili_red07
Originally Posted by RallyMINI
That is a great look! Makes me wonder about mine...
Old Nov 13, 2007 | 07:33 PM
Dab's Avatar
Dab
here is a pic of my 15X8 949s. I have 225/50/15 RA1s on them... no rubbing in the front. To get the rear tucked in with no rubbing I needed to shorten the wheel base a bit by adjusting the rear factory toe adjustement and UPPER/LOWER control arms.
Car has KW coilovers lowered about 1".
Now it's a perfect fit
Old Nov 13, 2007 | 09:45 PM
Wake|MCS's Avatar
Wake|MCS
Above setup re-formatted.
Wheel/Model: 949 Racing 6UL
Offset: 36
Wheel Size: 15x8
Tire Size: 225/50/15
Suspension: KW Coilovers - Lowered appx. 1"
Camber Settings: F - Stock, R - Minor negative camber
Rubbing: None
Ok now we are finally starting to get somewhere. I'm sure there are more of you running wheels wider than 7.5 inches. Please chime in else this thread is worthless...
Old Nov 14, 2007 | 04:41 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Is anyone running more than 9" I would love to see a 10" smashed under there!
Old Nov 14, 2007 | 04:46 PM
jasonsmf's Avatar
jasonsmf
Offset: approx. +30mm (wheels are +36mm, with .25" spacer)
Wheel Size: 15x8
Tire Size: 225/45/15
Suspension: Stock Springs
Camber Settings: F: -2.25 deg, R: -1.25 deg
Rubbing: None (see above, stock springs )
Old Nov 14, 2007 | 04:47 PM
jasonsmf's Avatar
jasonsmf
Yes, there is a SCCA DSP car running 15x10's and Hoosier 275/35/15 tires. Lots of cutting for this setup. I am sure somebody has pics out there....
Jason
Old Nov 14, 2007 | 05:50 PM
Wake|MCS's Avatar
Wake|MCS
Nope, aside from the person mentioned below. But he's running EXTREMELY low offsets and the wheels stick out INCHES past the fenders. A 10" wheel could MAYBE fit with an ET20 but then you'd have a good amount of poke on the fender side...
Jason
Minihune posted them, an electric blue MCS right? Looks terrible IMO, does it actually help at the autox?
Old Nov 14, 2007 | 06:03 PM
jasonsmf's Avatar
jasonsmf
Looks? Who cares about looks, wide wheels are all about going fast!
But yes, from what I hear the 275 Hoosiers produce some pretty amazing levels of grip!
Jason
Old Nov 14, 2007 | 06:19 PM
Rally@StanceDesign
My wide wheels are all about going slow! (and low)
Old Nov 14, 2007 | 09:44 PM
Wake|MCS's Avatar
Wake|MCS
IMO, there's no point in going fast if you look like **** (in a DD at least). Wide wheels are all about LOOKing good. If speed is your thing, go for it, with MCS I'm more interesting in looks right now...
If I wanted fast and a good handling car I would've gotten a beater CRX stripped it, done suspension mods, sohc with built internals and boosted running 11s all day long and destroying most of the cars at the local auto-x. All for less than I've spent in mods on my MCS. BUT, at the end of the day it's still an old pos crx...
Back to wide wheels and looking good.
Old Nov 15, 2007 | 06:58 AM
Dab's Avatar
Dab
a little contradictory to say the least...
If you think its ALL about the LOOKS your only half enjoying the MINI!
Old Nov 15, 2007 | 08:02 AM
Rally@StanceDesign
My car does 0-60 in 10.9 seconds
Old Nov 15, 2007 | 12:16 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
Rally your wheels are some hard SOBs to find. I started looking about and could barely find any. I found some, but they are all foreign.
Old Nov 15, 2007 | 12:22 PM
Rally@StanceDesign
yah...they're especially hard to find in good condition for our bolt pattern 4x100. Took me about a year to find some....and they were awful condition, but local which was awesome
Old Nov 15, 2007 | 12:25 PM
ChrisMCS04's Avatar
ChrisMCS04
Peace Keeper
If you do find any let me know. And keep me in mind when you get rid of yours if ever.
Old Nov 15, 2007 | 02:15 PM
Wake|MCS's Avatar
Wake|MCS
Contradictory? How...
Oh believe me I'm enjoying my MINI to the fullest, there's more than a couple 350Z, G35, GTi, SRT4, WRX, etc. owners that can vouch for that
Go low or go home! Hahah
Old Nov 15, 2007 | 03:50 PM
ca$per's Avatar
ca$per
Ok you guys... let's get this thread back on track
Wheel/Model: Axis Decade
Offset: 40
Wheel Size: 18x8
Tire Size: 225/35/18
Suspension: H-Sport Springs & Koni Yellows - Lowered appx. 1"
Camber Settings: forgot the setting
Rubbing: none
And it's all thanks to WAKE|MCS
Old Nov 15, 2007 | 03:58 PM
Mr. D's Avatar
Mr. D
Ca$per do you have any side shots available. (View down the side from front or rear.)
I am going to call on some 18x8 Giovanni rims that are missing the center caps tomorrow.
Old Nov 15, 2007 | 10:51 PM
ca$per's Avatar
ca$per
You mean like this
