Marketplace - Archive Old Marketplace threads and posts (Read-only). Please use appropriate Marketplace forum for new posts.
Wanted: Motor for Cooper S
Old Aug 23, 2005 | 03:23 PM
GClemons's Avatar
GClemons
Thanks to an offtrack racing experience, I now get to replace the motor in my car. Anyone have a motor (or at least a block) available?
Old Aug 23, 2005 | 03:36 PM
qweewq12's Avatar
qweewq12
no motor to give/sell.. just wanna hear a story....
Old Aug 23, 2005 | 03:58 PM
binkysmini's Avatar
binkysmini
Try this one...
https://www.northamericanmotoring.co...ad.php?t=49286
Waylen gets busy sometimes and it looks like he needs to catch up on some pm's, but it is worth a shot.
Old Aug 23, 2005 | 06:50 PM
DrkSilvrMini's Avatar
DrkSilvrMini
Alright you gotta spit it out what you do
Old Aug 23, 2005 | 08:15 PM
MadHatter's Avatar
MadHatter
Did your NOS system have anything to do with the
offroad experience and motor issue ?
Hope you get things resolved without pain. But would like to know if your NOS had anything to do with this problem.
Good luck
Old Aug 24, 2005 | 09:27 AM
GClemons's Avatar
GClemons
The problem came from taking turn 2 at Willow Springs to hot, and ending up in the dirt. A rock cracked my oilpan, and before I new it the engine was gone. Looks like a need a rod kit and a crank kit, but it may be easier (and cheaper) to just get a new lower block.
Nitrous was not in play with this one....the tank was at home in the garage.
Old Aug 24, 2005 | 09:36 AM
CooperSS's Avatar
CooperSS
The problem came from taking turn 2 at Willow Springs to hot, ....
I was there, this is true understatement !!!!:smile:
Good Luck on getting the car fixed and back on the road, fortunately Steve will do it cheaper and better than just about anyone.
Bill
Old Aug 24, 2005 | 11:33 AM
Joe Donovan's Avatar
Joe Donovan
The lower half alone will not work. the block is machined as a unit with the two halfs bolted and torqued together for machining . an new half wont match up.[QUOTE=GClemons]The problem came from taking turn 2 at Willow Springs to hot, and ending up in the dirt. A rock cracked my oilpan, and before I new it the engine was gone. Looks like a need a rod kit and a crank kit, but it may be easier (and cheaper) to just get a new lower block.
And I dont understand why you couldn't save the whole block and have it line bored, and go to oversized main bearings. Did it seize up or did you spin a thrust bearing ? Unless it got so hot that its warped beyond tollerance It should be ok to machine.
Old Aug 25, 2005 | 02:35 PM
GClemons's Avatar
GClemons
I am not going to use the new block, just the rods and crank. It is proving to be easier and less expensive to find a used lower block than order a new rod kit and crank.
Old Aug 25, 2005 | 08:18 PM
MadHatter's Avatar
MadHatter
Very sorry to hear this GClemons
Hope it can be fixed without too much expense...
I am going out there early October... Better watch the corner and look out for that specific rock !!
Old Aug 26, 2005 | 10:56 AM
wc351's Avatar
wc351
I've been told that our engine is basiclly the same as a Dodge Neon. If this is true we could simply build a larger displacement Mini Engine. If I was told wrong let me know. Thanks
Old Aug 26, 2005 | 10:58 AM
not-so-rednwhitecooper
european Neon
Old Aug 27, 2005 | 07:09 AM
mdsbrain's Avatar
mdsbrain
I just found this one on Ebay:
http://cgi.ebay.com/ebaymotors/03-MI...96143718QQrdZ1
Old Aug 27, 2005 | 07:17 AM
camelpilot's Avatar
camelpilot
Originally Posted by mdsbrain
hehehe, he states "Please look at the picture closely, because what you see is what you get." So does that mean he will throw in the Bulldog too?
Old Aug 28, 2005 | 12:01 AM
motorsports_3's Avatar
motorsports_3
LOL i got dibs on the bulldog.
Old Aug 30, 2005 | 08:50 AM
mini-bear's Avatar
mini-bear
I think the bulldog is in lieu of shipping insurance.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
Gil-galad
Eastern Iowa MINIs
63
Nov 17, 2016 02:54 PM
Zettinger
Aug 25, 2015 04:04 PM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
