JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW shift light
Old Feb 13, 2006 | 03:35 PM
Hotelcalif's Avatar
Hotelcalif
JCW shift light
Anyone installed the JCW shiftlight? I got one today but no instructions on how to wire it in.
Old Feb 13, 2006 | 03:38 PM
ScuderiaMini's Avatar
ScuderiaMini
i will have one next month with my aux. gauges
Old Feb 13, 2006 | 04:47 PM
weezer2282's Avatar
weezer2282
OOooo...I already have aux. gauges! No need for a JCW shift light either with the auto. It does look kinda cool though.
Old Feb 13, 2006 | 05:42 PM
mdsbrain's Avatar
mdsbrain
I was looking to get this as well. But like you said no instructions.
*bumps thread*
Old Feb 13, 2006 | 07:27 PM
Maximusmini's Avatar
Maximusmini
You have to tap into the Tach Signal wire leading to the tachometer..
Old Feb 13, 2006 | 07:49 PM
Hounddog's Avatar
Hounddog
JCW shiftlight??
Didn't know this existed. Who is selling it?
Old Feb 13, 2006 | 08:14 PM
Gabe's Avatar
Gabe
*bumps thread*
Check MotoringFile tomorrow morning
Old Feb 14, 2006 | 02:58 AM
Hotelcalif's Avatar
Hotelcalif
Morristown Mini has some on Ebay.
Old Feb 14, 2006 | 03:30 AM
mdsbrain's Avatar
mdsbrain
I will try and wait
Old Feb 14, 2006 | 07:45 AM
ScuderiaMini
thanx Gabe
Old Feb 14, 2006 | 07:50 AM
mdsbrain's Avatar
mdsbrain
thanx Gabe
+1 I needed something to aid me in doing this in the future.
Old Feb 14, 2006 | 07:47 PM
racinbmw's Avatar
racinbmw
Not to rain down on JCW at all, but does anyone know if this can be done by making yourself? I am curious from the people that have already purchased this if it is a circuit board that controls this and if so can this be done ourselves or do we have to pay a ton of money to get a nice feature? Just curious since I am a DIY typ eof person.
Old Feb 14, 2006 | 08:06 PM
Greatbear's Avatar
Greatbear
Moderator :: Performance Mods
Apparently the JCW light has at it's core a rather common circuit/display assembly due to the cylinder selection included in the DIP switch settings. JCW simply mounted this assembly in a custom housing to match the MINI interior and contours and supplied a harness and hardware to connect and install it. In this case, just about any similarly configurable aftermarket shift light can be installed using the connections given (power, ground and RPM signal).
Motor On's Avatar
Motor On
If you know your way around electrionics it bet it is very possible to make oyur own, nothing more advanced than a garage door opener. Check out the PDF for the official install. If you beat me to it post a DIY procedure, this looks like if I can figure it out it could be a good weekend project, but first I need to fix my airbag issue.
Old Feb 14, 2006 | 08:16 PM
racinbmw's Avatar
racinbmw
Well I am a great DIY person but would love the assistance of someone helping me understand what parts are needed in order for this to work. I can then make a carbon fiber housing and I think the best place for it would be on the steering column itself. That is my plan as soon as someone helps me figure out what I need to make this. Thanks
Old Feb 15, 2006 | 01:23 AM
Cooper_Si's Avatar
Cooper_Si
Ive always thought about using one of the unused black circles in the rev counter (thats the best way i can describe it) Im sure i can place a small SMD on the circuit board and route wiring from that, into the existing wiring loom for that factory finish. Would look rather discreet, yet also close to the line of vision.
Hmmmmm
Old Feb 15, 2006 | 05:43 AM
jimz68's Avatar
jimz68
Instructions are printed out by the dealer.
Jim
Old Feb 15, 2006 | 04:30 PM
Hotelcalif's Avatar
Hotelcalif
Morristown Mini sent the instructions and got it done in about 30 minutes. Very simple.
Old Feb 15, 2006 | 05:23 PM
cooldaddy's Avatar
cooldaddy
that must be ugliest piece of JCW crap ever released. this calls for a proper aftermarket MINI specific item, M7 are you listening?
Old Feb 15, 2006 | 09:58 PM
Motor On's Avatar
Motor On
I gave it some thought and there are two place I can thing of that this would really work, in the rear view mirror, so you can see at as you leave folks in the dust and so when you're in the corners and it gets in the way you are a least able to check your revs w/out looking away or in the speedo ring drill out holes incrimentally around the speedo so as the need move the LEDs show the revs and all the info is in one spot for added bling factor w/ a co-pilot. I'm partial toward the first esp cause I have the manual dimming mirorr and no garage door opener up there, but the wire routing would be more difficult. Theres my input, this project will have to wait for me but maybe dow the road...
Old Feb 16, 2006 | 04:11 AM
mdsbrain's Avatar
mdsbrain
I'm looking @ installing this right above my tach and speedo combo (I have the Navi). That way its more in my line of site.
Old Feb 16, 2006 | 01:21 PM
Profpatpending's Avatar
Profpatpending
you guys ever seen these??
https://www.northamericanmotoring.co...ad.php?t=51281
look at the three pics in post no 8
Old Feb 16, 2006 | 02:59 PM
Motor On's Avatar
Motor On
Yah, but I'm looking for something that will make it so I don't have to take myeyes off the road. I have also considered the defilink VSD, but its still too expenvise and isn't quite sutle enough of a look.
Old Feb 16, 2006 | 04:19 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
Instructions from the great folks at MotoringFile.com
JCW Shift Light How-to
Old Feb 16, 2006 | 06:31 PM
ScuderiaMini
anybody has this one on the car yet? any pics?
