JCW Some underside pics of the GP3
Old Jun 4, 2020 | 11:11 AM
abstrader's Avatar
abstrader
Some pics from underneath the car. Note that the swaybar endlinks are still made out of plastic, which is sort of surprising. Sway bar seems to be about the same thickness as the JCW but it is apparently stiffer. Undertray beneath part of the engine is gone. Also big brace added in place of the thin sheet metal piece that is on the JCW. I'm sure there is a lot of other stuff that is different but that is what I noticed initially.
Old Jun 4, 2020 | 11:52 AM
MikeMJCW's Avatar
MikeMJCW
I want that brace!!!
Old Jun 5, 2020 | 12:53 AM
al the mini man's Avatar
al the mini man
Be interested to know haw much that lower brace costs.
Old Jun 5, 2020 | 11:31 AM
MikeMJCW's Avatar
MikeMJCW
Dealer says they need part or Vin numbers to look up GP3 parts. Where are the ECS guys when you need them?
Old Jun 5, 2020 | 12:20 PM
You dont need a VIN just an updated etk. Dealers just ask for that, what i need is the part number off of that sticker or stamped into the brace. Some part numbers are not on the dealer etk as the car is so new. So keep that in mind.
Thanks for the underside shot. In the past when i was the first to get GP2 parts I took my phone and shot under the car on the stickers and then looked them up. Before they were in the dealer data.
Old Jun 6, 2020 | 05:11 AM
sgscomps's Avatar
sgscomps
You will not be able to get an updated ETK as BMW stopped the disk versions a few years ago, check realoem.com and you will see the cutoff date when they stopped getting a disk from whatever dealer or employee was supplying it to them. ETK is now with dealer login credentials only. Dealers will need a vin to lookup GP parts jut like Alpina BMW's. Some GP and Alpina parts have to be special ordered with a vin and proof of ownership that is sent to BMW before they will release parts. Currently the parts in inventory are only being used to build production cars and nothing can be ordered without photos being sent to BMW proving the parts are needed, ie accident.
Old Jun 6, 2020 | 08:29 AM
ASKtheteach's Avatar
ASKtheteach
I’ve already spoken to two friends of mine who work for MINI. One is a Motoring Advisor and one is a Service Advisor. As with all GPs of any generation, you will need a VIN to order GP parts. The best hope is that eventually, someone will either make replica parts or someone will eventually total one and parts may be able to be purchased from a junk yard.
Old Jun 6, 2020 | 07:44 PM
Clutch Wotan's Avatar
Clutch Wotan
If you have a VIN you can order! I have ordered several parts for evaluation, and yes they are great "positive" samples for molds, especially the rear wing, which has the final price of 3 kgs Polyurethan 40 Euro
The front spoiler is not only a bargain for "the few", but also for the ones which knows !
Old Jun 7, 2020 | 06:08 AM
JackMac's Avatar
JackMac
GP1 parts have been available without VIN for a while. GP2 parts were available from the beginning. Guess we’ll see how it goes with GP3.
Old Jun 8, 2020 | 08:22 AM
MikeMJCW's Avatar
MikeMJCW
Rear brace 51-71-9-880-269
Strut bar 51-61-9-479-058
Here you go ECS folks start generating some prices.
Old Jun 9, 2020 | 08:02 PM
https://www.ecstuning.com/Search/Sit...h/51719880269/
https://www.ecstuning.com/Search/Sit...h/51619479058/
Thanks, they are in the data, but i have to double check if they were released yet. Most of the time no matter what part if its brand new GP3 or any MINI, MINI likes to hold the stock then they release it.
Old Jun 10, 2020 | 07:13 AM
MikeMJCW's Avatar
MikeMJCW
$1362 for a strut bar and $467 for a rear brace... Seems overpriced (understand its manufacturers item). That money that could towards a new trade
Thanks for pricing it for us.
Old Jun 15, 2020 | 01:31 PM
Yep, GP prices can be very high and bounce around, the highest price parts that i have seen were from the MINI goodwood. Some of the prices are very high for parts. 1K floormats anyone?
https://www.ecstuning.com/b-genuine-...r/51477315977/
Old Jun 15, 2020 | 01:37 PM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Yeah, but look at them!!! Those would make me want to drive barefoot.
I wonder if there are any lambswool pedal covers available....
Old Jun 15, 2020 | 02:29 PM
I know When i saw them come in a did not even want to touch them out of the bag. lol You can sleep on those they are so thick.
lambs wool covers ...for soft shifts.
Old Jun 15, 2020 | 03:56 PM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
any pics of the undertrays / aero improvements under the car?
Old Jun 15, 2020 | 04:58 PM
DavidPinAZ's Avatar
DavidPinAZ
Looks like I'll have to order some SS brake lines. Anyone know if the current F56 SS brake lines from ECS will fit the GP3?
https://www.ecstuning.com/b-nm-engin...mwm.4.068.cbn/
Old Jun 16, 2020 | 10:29 AM
They look the same as the JCW brakes on the caliper side and that fitting, so i would say they most likely the same.
https://www.ecstuning.com/Mini-2015-...Braking/Lines/
F55-F57 all MINIs brake line kit.
But on the back side of the caliper the line comes off at an angle verse the JCW brake kit: https://www.ecstuning.com/b-genuine-...112352872~oem/ Up and down.
F55-F57 JCW front brakes
VS
Looks like a 45 degree from the caliper. fittings end looks the same and over lentgh might be different. We saw that in our ECS SS GP2 line development.
The GP3 brakes on the front are the same as the F54... maybe F60 caliper but in steel " Braking is another area that MINI focused on. Despite the size and weight difference, the 2020 JCW GP makes use of the same 14” front rotors from the JCW Clubman but in steel for better heat dissipation. This should allow for both excellent performance and fade resistance at the track."
https://www.ecstuning.com/Search/Sit...h/34306894453/ is the brake line used which fits the JCW and NON JCW cars. My guess is that its used on the GP3. Could be the same line and a grommet more or a hair longer? Or the same and MINI just like to make new part numbers, we seen that before.
Old Feb 3, 2021 | 12:44 PM
This looks like that part number for the front lower bumper spoiler/splitter.
https://www.ecstuning.com/Search/Sit...h/51119481329/
Old Feb 3, 2021 | 12:58 PM
These are the CF fender, all four, dont have the number stickers.
https://www.ecstuning.com/Search/Sit...h/51775A0FC03/
https://www.ecstuning.com/Search/Sit...h/51775A0FC04/
https://www.ecstuning.com/Search/Sit...h/51775A25CF5/
https://www.ecstuning.com/Search/Sit...h/51775A25CF6/
Old Feb 4, 2021 | 11:09 AM
bluonyx's Avatar
bluonyx
For those of us that have put on a GP3 grill, how about finding the piece that fills the gap between the grill and radiator?
I can't seem to find it anywhere cause no one's part finder is that up to date, and I need a GP3 VIN.
It's the piece that attaches to the top of the GP3 grill and mounts it up the the stock air intake. Circled the bolt up area.
So need this but the GP3 version...
Old Feb 4, 2021 | 11:53 AM
Clutch Wotan
for the few
https://www.leebmann24.de/bmw-ersatz...=51&bt=51_z035
Old Feb 4, 2021 | 01:59 PM
bluonyx's Avatar
bluonyx
a huge THANK YOU!
Can't get the part number but at least I know have a picture for reference to show the parts department.
Old Feb 5, 2021 | 02:45 PM
This is the part MINI gave me.
https://www.ecstuning.com/Search/Sit...h/51749464494/
Old Feb 6, 2021 | 11:39 PM
Clutch Wotan
That lower brace costs 14 kg and is a quick remove.
