JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
Lighting Cable Adapter/iPhone issues
Old Dec 2, 2019 | 06:59 AM
32 ft. per sec2's Avatar
32 ft. per sec2
I've been using the Lighting Cable Adapter, BMW p/n 61122408012 with my iPhone 6 without incident for about 2 years but recently it ceased to work. I suspect it's because Apple pushed a new iOS release and somehow this got lost in the mix.
Anyone else have similar issue? Workaround?
Old Dec 2, 2019 | 08:46 AM
I have used mine in the past ok, did you restart your phone? If that does not work, you might need a flash update at the dealership.
Old Dec 2, 2019 | 08:55 AM
32 ft. per sec2
Thanks and I'll re-boot the phone (again) and if that doesn't work will take it to the dealer. When they "flash" what exactly are they flashing, the unit or my car?
Old Dec 2, 2019 | 09:08 AM
Main software update. It will cover the media and stereo also. I would ask them to see what the flash you have and see if there is an update first. They can pull that up for you with a quick stop at the dealer. Most of the time a main flash fixes it.
Old Dec 2, 2019 | 11:04 AM
maccoder's Avatar
maccoder
You might want to take a look at this thread as well:
https://www.northamericanmotoring.co...-iphone-x.html
Might be similar issue.
Old Dec 3, 2019 | 07:14 AM
32 ft. per sec2
Thanks for the link and my problem is similar to this earlier post from Dube53:
"Sorry for the confusion. I use an Iphone 7 with no SIMS card connected to the Y cable for music only. The problem seems to be the software doesn't recognize the cable anymore."
Mine's an iPhone 6 and I'll check for the charging issue & clean the ports but seem to think it's due to a software update by Apple as everything else seems to be OK.
Old Dec 3, 2019 | 07:27 AM
maccoder's Avatar
maccoder
Which specific iOS update are you referring to? I seriously doubt it's a software issue. Could you try different phone with the same iOS?
Old Dec 3, 2019 | 07:32 PM
dube53's Avatar
dube53
Unfortunately, the problem is back after everything was fine for 2 weeks. Both ports (USB and Audio) in the car are OK because I can use a Bluetooth device for audio.
I am also believing the issue may be with Apple. This morning, I reboot the Iphone 7 I use as an Ipod and it was fine. In the afternoon, the connection was gone again.
Old Dec 4, 2019 | 06:49 AM
32 ft. per sec2
I have to agree with Dube53 as I've done all the checks & cleaning and it's still not connecting (however it's charging). I swear it's an Apple iOS issue because it was working fine one day and then "kaput" the next. I haven't tried another iPhone (wife's on Android) yet.
Old Dec 4, 2019 | 07:24 PM
dube53's Avatar
dube53
I use an Iphone X for communication and the problem is the same. What brings me even further to believe this is an Apple issue is sometimes it works fine with the Iphone 7 and not at all with Iphone X.
Old Dec 5, 2019 | 08:40 AM
32 ft. per sec2
What also complicates it for me is that I have a Manic tune by Mario and when I asked him what would happen if the dealer flashed the car he felt I'd loose the tune- so no way that's happening. Crikey, I may have to go buy CDs after I gave mine away to shift to iTunes :(...
Old Dec 5, 2019 | 11:23 AM
32 ft. per sec2
OK so I switched out the regular official Apple Lightning cable for another one for my iPhone 6S and LO!, it reads iPod on the display HOWEVER when I go to activate it there's an error message that says the cable isn't supported. Sooooo, I grabbed an old iPod with the larger cable port, inserted that and got the same error message.
ARGH! All this would be academic if we were in the '70s with great FM radio stations, not the dreck that's playing now.
Old Dec 11, 2019 | 05:26 AM
Raptortilla's Avatar
Raptortilla
fwiw I always had problems with my iPhone X. Basically it would show the track info on the mini display, but the audio would keep coming from the phone. When I eventually bought a ProClip mount I just put a data isolator between the usb port and the lightning cable. That way I can still get power to my phone, and just stream audio over bluetooth.
Old Dec 12, 2019 | 07:30 AM
32 ft. per sec2
Success!
The new updated version iOS 13.3 seems to fix this problem.
scottbushey
Sep 27, 2014 03:03 PM
hazmatte
Jan 21, 2014 06:30 AM
swiftaw
12
Nov 16, 2013 04:12 PM
BrianM
Nov 13, 2012 07:10 PM
Jack & Coke
Nov 5, 2012 10:47 AM
