JCW why does my JCW handle worse than my justa"
madmix - Have you determined whether your suspension is fully stock or not? In a earlier post you noted the mods on your car and said the car came with those. I don’t remember if you had a chance to check your suspension for mods, like a big RSB.
Not sure where Charlie got his wheels from. He has a post about it in the the thread I linked. I think he did something special to get those. The ones I found for the MINI JCW are 7-1/2 wide, which should still be a good size for a 225 wide tire.
My MINI is straight off the show room floor (literally), tires (RFTs), brakes, etc., and no issues
Eddie you have DDC?
For the ABS system, there is a fuse you can pull to disable it. I wonder if it is the same for the DDC. But will it work at all if it is disabled? Does it revert back to a basic suspension? I know that the MINI info for the JCW Pro suspension parts says that they are not compatible with the DDC. I wonder why...
Maybe you can unplug each corners DDC wiring harness. The fronts are the wiring connector that plugs in at the top of the shock/strut assembly that you can see easily when you open the hood. Maybe you can find the backs. I don't have DDC so I don't know where the rear connections are. Just a thought.
I don't like the way my 2019 JCW handles in any high speed turns. When high speed braking and cornering at the same time, the front of the car swims around quite a bit, unpredictably I'd add. Part of me thinks the high speed corner/braking starts to activate the ABS too early, possibly from detecting the unloaded inside tire rotation slowing, (it certainly isn't locking up yet) and that's what causes the front to feel like it's skittering around like that. It almost feels like the pulsating you get with the ABS. On NON-braking high speed cornering I would describe that the front and the rear don't "take a set" at the same rate. The quick, initial, turn-in happens fine, but then the front of the car continues to lean and bite progressively harder, and feeds into oversteer. I wouldn't mind dealing with the oversteer, but it comes in unevenly in relation to the steering input. The car can lean, that's not bad, but it should ideally lean evenly at the same rate. My 2008 Cooper S didn't have this characteristic, but in general the 2008 was way more skittish over the bumps.
So far I've only added the NM 22mm rear sway bar and it flattens the car up a bit for spirited lower speed darting around town, which is great, but it didn't change the unevenness of how the car takes a set at higher speeds. I have the Eibach front and rear sway bar kit in the garage but haven't put them in yet. I'm trying to track down what might help. I might try upgraded coilovers down the road. All that said, I like the fun factor of the car enough that my suspension complaint doesn't really bother me too much, but it's still there.
So I don't have any suggestions, but I wanted to write up my description of the handling dynamics that I don't like. Maybe it'll give you some ideas. I'm also wondering if anyone else interprets the handling similarly to what I've described.
And your most recent post you say that you don’t have DDC. So, maybe the DDC isn’t involved here? Probably still worth checking, though.
Also, do I assume correctly that that the issues you had with the handling you described in this post were before you added the 22mm RSB?
You also say that you have the Eibach front and rear sway bar kit but have not put it in yet. I am very curious about your thoughts and opinion of it once you do put it in. That was a great mod on my R56 MINI.
Eddie is correct. I have no intention of getting rid of my JCW. I still enjoy driving it every day. I am hoping to get the attention of BMW/Mini with this thread to see if there is a defective part or something in some cars. I agree that there are some that have no issues with the car, and others that clearly do. A guy in my club races his GP and his new 2018 JCW, and has experienced the "tail wag", but just accepts it as normal. I have a feeling what he is feeling and what I am feeling might be different. I am almost ready to just bite the bullet and get better wider tires to see if that helps. I did notice that Charlie is running 8" wheels. Wider tires made all the different in the world on my Justa. I was wondering the other day if the car brakes so well that the tires are loosing traction and the ABS is cycling, but would love to start getting some data points. I know a lot of people don't run completely stock. so....
if you run stock suspension, brakes and experience the braking/stability issue please reply.
if you run modified suspension or brakes and DONT experience braking/stability issues please reply
EDIT: I'm sorry the first paragraph is messed up. I don't know how to correct it.
Hi Eddie,
About those Eibach Bars:[size=3] [/size]
[size=3]My description of how the cars front and back responds under turning load is that I don't feel like it happens at the same time.. The oversteer was feeling like it progressively increases with one given steering input. I did notice I felt it happen right away when the car was brand new and before even the 22NM rear bar install (especially since I was upgrading from a Gen2 Cooper S that same day). Then I put the NM 22 solid rear bar and it felt flatter, and more fun, but the front versus rear load timing didn't really seem to change, it was still noticeable and a little spooky.[/size]
[size=3]Then with the Eibach front and rear together. It seems much more like the 2008 Gen 2 Cooper S overall. It's certainly stiffer feeling since the two shocks work together even more. I'd also say "slightly" bouncier (only slightly), but still firm, quiet, and solid. In my opinion, now, the cars front and back during cornering load much "quicker" than stock, and also quicker than the NM rear bar by itself (I still can't yet say they load at the same rate). The Eibach pair does feel even flatter than with just the rear NM bar which still was a fun upgrade.[/size]
Specifically about the high speed front and rear taking a set at the same time, I still am not sure if it changed. One thing is with the car feeling like it leans and takes a set "quicker", it feels like the "steering response" is just quicker over all. So it's not as noticeable that the rear washes around a few heartbeats after the front has already loaded. And the steering wheel "feels" like it can control the car better. I just haven't had a chance to try my favorite off-ramps (of course when no one else is around and not on the advice of a driving school). I'm thinking to really dial in a criticism, it would take me a decent amount of testing time on the roads to interpret the handling flaw now (if any), whereas, I felt like I noticed it right away before the Eibach Bars.
I was very weary of putting on the Eibach fronts because it felt like a lot of work "just to see if I liked it". If not, was I just gonna pull it back out? Ugh
I'm reluctant to frame any of this other than my opinion. Partly because it all gravitates towards stiffening up the car a little and some people may hate it. To me, in general stiffness (not handling) it feels comparably stiff to my 2008 Gen 2. But at the same time more sophisticated and better engineered to deal with bumps in the road. It never skitters sideways over bumps like the 2008.
I see you definitely had fun with the Mods on your 2012 Smokey. Awesome stuff.
I have the 2019 JCW Sport suspension and the only Suspension Mods at all are the Eibach Front and Rear bars. Still on Run-flats (just summarizing for anyone first reading this)
Hi Eddie,
Hi Eddie,
Hi Eddie,
Good clarification.
I have found that the “anti-conventional” wisdom for making a MINI handle well works much better than any other (my opinion). The front/rear sway bar combination is a much maligned mod, but it works. You can get a similar result with stiffer front springs instead of the sway bar, but that has its own pros and cons. I do all of my 99% “testing” out on the track, but that is not to say I don’t enjoy a good twisty road to drive on.
However, the tracks I run are very unforgiving. So, I take things in baby steps. I will get the JCW out, but it may be a while. I plan a stock run with it. Should be interesting.If curious about how the car with big front and rear sway bars handles/look on the track... Here is a link to a link (don’t want to stray to much on this thread) of a view of my R56 from the rear going around Lime Rock Park.
https://www.northamericanmotoring.co...ml#post4470958
As for your first paragraph formatting, the only fix that I know of to fix this is painful, at least on an iPad. On a windows machine maybe (have not tried, though) go into edit mode for the post, cut/copy the post into the Text Editor, clean it up and then paste it back in... Sucks...
It almost sounds like the rear suspension is going though a big camber change or toe-in change. A little change of either can “steer” the car a lot. Doesn’t make sense that a new car would have bad bushings and alignments have been checked, which are things that I would check. Then I would check tires, but those are new too. And it would seem we would all have the handling issue, if those were the culprits. I wonder if this handling change is occurring as a result of the inside rear wheel coming off the ground and changing the grip on the rear, and/or the tire bouncing on the ground? But, again, on a new car wouldn’t all of us have that issue? Just thinking out loud here....
When I drove home with my '19JCW Hardtop, I noticed that it had a tendency to head to the left. I let go of the wheel and it was definitely steering itself left. I took it back to the dealer and they realigned the suspension ( all four wheels). I watched them do it. They corrected the wandering. Just a thought.
Personally I think the 205 size Run Flat Tires are the main issue with handling when it comes to a new JCW....Period...That and check the alignment specs.
A good 225 size tire will make a big difference all the way around IMO.
The one HUGE MISTAKE BMW/Mini made was to sell the JCW's without a REAL LSD!!! … that and not having a way to adjust a bit more camber in the front.
Check Sig for the upgrades … these statements are from experience.
Past: 56S, 54S
Current: '19 Knight/JCW (waiting on a name approval change)
My first foray into trail braking on the JCW was similar to madmix. Good line, brakes, weight transfers, then it was like someone else was steering the back wheels. I had ample room for correction but without it, I would have been curb hopping. My 56S would not have treated me this way. My next thought was I had a better car so I needed a better instructor. Got one lined up next month. I would like to go to my first MOTD next year without making a mess out of my new car.
Now after reading this thread, my question is what else should I do?
Past: 56S, 54S
Have you had the ABS kick in under the trail braking you do? That unsettles the car a bit. Was this not it? Just asking for your analysis.
