JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
Is this a JCW cylinder head? (pic attached)
Old Aug 14, 2018 | 04:11 PM
A383Wing's Avatar
A383Wing
Considering this engine to replace the one in my '06 R52 JCW car that I bought a while back.....
I looked for exhaust port measurement differences in the forum, and could not find any info......most threads say that the exhaust ports are larger......
So here is pic of the engine in question.......does it look like a JCW cylinder head? (I don't see a red or green painted dot in the other pics that the wrecking yard sent me......so I'm not sure)
Bryan
Old Aug 15, 2018 | 02:43 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
You would have to clean the exhaust ports to really tell as the paint dots and such don't indicate anything that would say what it is.
Old Aug 15, 2018 | 11:21 AM
RB-MINI's Avatar
RB-MINI
Hard to tell from that pic. Cleaning around the port opening and a clearer, more head on pic would help. According to this post: https://www.minitorque.com/forum/f845/jcw-vs-oem-19566/ the JCW exhaust ports should look taller, and maybe a little wider than a regular head.
Old Aug 15, 2018 | 05:56 PM
ItsmeWayne's Avatar
ItsmeWayne
It does look like the JCW head to me!
The dots are usually worn off. The exhaust size ports are the tell!
Old Aug 15, 2018 | 07:16 PM
A383Wing's Avatar
A383Wing
Yea, kinda looks like a jcw head to me as well...... I bought the engine today, might pick it up tomorrow if I'm feeling better..... I have 30 days to get the motor from the wrecking yard.....
Rhen the fun begins......
Old Aug 15, 2018 | 07:32 PM
ItsmeWayne's Avatar
ItsmeWayne
Do they say it runs and has no broken parts? Has the compression been tested to make sure it is sound?
You need to find out as much as you can, before dropping a ton of $$$$ on it.
What am I looking at on the left side engine block? to the left of the oil filter housing.
Old Aug 15, 2018 | 07:46 PM
ItsmeWayne's Avatar
ItsmeWayne
What am I looking at on the left side engine block? to the left of the oil filter housing. It looks like the starter part of the block is broken off.
Old Aug 15, 2018 | 07:52 PM
A383Wing's Avatar
A383Wing
Compression is 170-180 ..... Warranty is for 90 days, I'll look the engine over carefully when I go to pick it up, if there's broken block or anything like that, I will ask for my $$ back
Bryan
Old Aug 19, 2018 | 02:32 PM
A383Wing's Avatar
A383Wing
Wayne....block is not broken.....starter mount is all intact......
Bryan
Old Aug 19, 2018 | 03:28 PM
ItsmeWayne's Avatar
ItsmeWayne
Bryan
Hi Bryan,
That is great news! The picture fibbed me!
Get a starter on it and check compression(for yourself), before you put it in, that way you can do whatever needs doing easier.
Old Aug 19, 2018 | 03:43 PM
A383Wing's Avatar
A383Wing
Yea, that's the plan when I get it mounted on my engine stand, the clutch & flywheel are still attached to the wrecking yard engine......I have a brand new starter here that I got for my '04 R53 a year ago and never got around to installing it......I'm gonna get an oil filter and put oil in the engine, install my mechanical oil pressure gauge and see what the pressure is while I check compression.......
I just have to clear some space in the garage now to work and pull the engine out of the R52
Bryan
715tt
Dec 26, 2017 06:17 AM
bigserb3
Feb 9, 2015 02:24 PM
jhiggs26
Aug 26, 2013 04:56 PM
cfrea
Factory JCW Talk (2009+)
39
Jul 5, 2013 12:58 PM
LethalR53
Jul 8, 2012 02:09 AM
