JCW Issue with JCW Pro Exhaust
Old May 21, 2019 | 07:44 AM
  #101
vetsvette's Avatar
vetsvette
Moderator
Can you check your paperwork from that dealer visit and post the TSB/campaign program number? It should be on your invoice you received for your visit to the dealer. When I was just at the dealer they wouldn't even look at the BT module without charging me a diagnostic fee. If I had a TSB number they wouldn't have a choice.
Old May 21, 2019 | 08:26 AM
  #102
J_L's Avatar
J_L
Thanks Vette, was going to ask the same.
And does anyone have a dealer in SoCal that’s been friendly on this issue? I tried two and they both gave BS excuses and wanted to charge a fee before doing anything. TSB number and a dealer familiar with the issue might be the winning combo.
Old May 21, 2019 | 01:17 PM
  #103
RLM's Avatar
RLM
I'm also going to jump in requesting that TSB number. will give me more ground to stand on in Canada as well.
Old May 22, 2019 | 04:58 AM
  #104
Chedder2017's Avatar
Chedder2017
I will do my best to get you all the information by tonight. I will also post a suggestion or two in working with your dealer.
Old May 22, 2019 | 05:30 AM
  #105
vetsvette's Avatar
vetsvette
Moderator
Old May 23, 2019 | 12:24 PM
  #106
FDR's Avatar
FDR
I finally had the dealer evaluate my flap closing issue and they immediately determined the blue tooth module to be faulty. I’m not sure if the tech was truly able to prove this through troubleshooting or they referenced some sort of TSB, but they acknowledged there was definitely a problem. I’ll be able to report back in a week after replaced unit is installed.
Old May 23, 2019 | 01:51 PM
  #107
Altecfenix's Avatar
Altecfenix
I'll have to hit up Chedder2017 if this works for you!
Old May 23, 2019 | 05:35 PM
  #108
vetsvette's Avatar
vetsvette
Moderator
Please get a TSB/Campaign number from them when you take it back.
Old May 23, 2019 | 07:08 PM
  #109
FDR's Avatar
FDR
Will do, good sir.
Old May 23, 2019 | 08:08 PM
  #110
Chedder2017
Hello all, I was mistaken about the bulletin however I can still help. Please PM me if your exhaust flap is still closing randomly. I am confident I can help at your local dealership level.
Old May 24, 2019 | 05:37 AM
  #111
RLM's Avatar
RLM
Further research on the issue may have sprung me a lead. I have reached out to BMW for a confirmation of my suspicions. If you are having the issue with the exhaust, can you find the RA number on the module and PM it to me. its on one of the white stickers, bottom right corner. format is a 2 digit number with a letter, then a space, then a letter and two digit number.
Cheers,
Rich
Old May 24, 2019 | 05:45 AM
  #112
Chedder2017
It sounds like RLM has your solution as well.
Old Jun 3, 2019 | 03:21 AM
  #113
MikeMJCW's Avatar
MikeMJCW
I noticed that after driving for about an hour the "snap crackle and pops" aren't as pronounced, is this due to the engine getting hotter (weather)?
Old Jun 3, 2019 | 08:12 AM
  #114
kfmuller's Avatar
kfmuller
receiver replacement permanently fixed my issue
Here is the invoice from my PuMA case. I brought my car in a number of times, but they were unable to duplicate the flap closing on its own. I guess I was getting more Bluetooth interference downtown where I live. They replaced the receiver, and I haven't had a single event since even with iPhone X and Apple Watch connected to the in-car Bluetooth. It's been almost a year and 3,000 miles since the receiver was replaced. The invoice says they checked the receiver sticker for firmware identification, and found it to be outdated. I'll take a picture of the sticker later today.
I removed the PDF since my Sharpie didn't make the redactions dark enough. I'll see about just posting the pertinent info later. I tried to see the label sticker on the new receiver, but didn't find a sticker on it in the boot. Regardless, you just should need to point out to the dealer that they should check the firmware version on your receiver to see if it's out of date, and replace the receiver if it is because that solved the issue for me. It's worked the way it should have for nearly a year now.
Last edited by kfmuller; Jun 4, 2019 at 06:23 AM. Reason: removed the PDF - redaction wasn't dark enough
Old Jun 4, 2019 | 06:17 AM
  #115
onefourten's Avatar
onefourten
Check your PM's ASAP.
Old Jun 8, 2019 | 10:37 AM
  #116
Altecfenix's Avatar
Altecfenix
I just got my JCW back from MINI of Portland. They changed the receiver and now it works just as I expect. Stays open until I close it. Perfect.
Old Jun 8, 2019 | 06:11 PM
  #117
Chedder2017
Great to her, not just the news but controlling it as intended!
Old Jun 11, 2019 | 09:00 AM
  #118
RLM's Avatar
RLM
After My service last week and them looking at all the info I provided, New module is on order under warranty. Hopefully will arrive in the next little bit and will hopefully solve all the problems. Thanks again everyone, and especially Chedder2017
Old Jun 11, 2019 | 06:18 PM
  #119
FDR's Avatar
FDR
There was no TSB, but the advisor said he wouldn’t be surprised if they released one soon. I had a new module installed and now the flap stays open 100% of the time. I can’t believe it - three years with this exhaust and it finally works the way it should 😂
Old Jun 12, 2019 | 09:06 AM
  #120
Altecfenix's Avatar
Altecfenix
Fantastic ins't it!?
Old Jun 12, 2019 | 10:02 AM
  #121
vetsvette's Avatar
vetsvette
Moderator
That's right. Rub it in.
I'll make another attempt with my dealer, but I'll speak with the service manager this time instead of an SA that I had never seen before.
Old Jun 18, 2019 | 04:23 PM
  #122
charrigan's Avatar
charrigan
I installed my JCW tuning kit myself except the tune and I am having issues with the flap not opening or closing when pressed. Build date on my kit was late 2017
Old Jun 21, 2019 | 10:28 AM
  #123
J_L's Avatar
J_L
If it's not opening at all, the issue is something other than bluetooth interference. That only causes the flap to close. Something must not be wired right, or it could be the remote isn't paired with the box. There is a button to reset it, I believe- the info is on the instruction sheet.
Old Jun 21, 2019 | 11:56 AM
  #124
charrigan's Avatar
charrigan
It does open and close and it is wired correctly. Sometimes it works perfectly and other times it takes 4 to 8 double clicks to open or close.
Since I posted on the 18th it has been functioning normal so it must have been some form of interference. I do not run any devices with bluetooth turned on so who knows what happened.
Old Jun 22, 2019 | 03:52 PM
  #125
FDR's Avatar
FDR
Hey Charrigan, mine behaves the exact same way. Most times it takes numerous double clicks to open or close, and that’s with the brand new receiver that solved my flap closure problem.
