JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW JCW steering wheel center spoke trim......
Old Aug 11, 2016 | 11:55 PM
dube53's Avatar
dube53
I discovered this today. This plastic part is coated with black paint and peeling.
I cannot see how the Mini trim can be any cheaper than this
Old Aug 15, 2016 | 09:03 PM
flyjets01's Avatar
flyjets01
Richard
Stop holding the center post and grip it at 10 and 2 O clock.
It soft touch paint peels on everything.
Ian
Old Aug 16, 2016 | 11:53 AM
isamin's Avatar
isamin
Cheap? Wait 'til you see what the replacement (including VAT JCW tax) and then you'll be so pissed off.
ISAMIN
Old Aug 16, 2016 | 12:42 PM
3lusive's Avatar
3lusive
https://www.ecstuning.com/b-genuine-...r/32306863535/
$33.98 from ECS
Old Aug 16, 2016 | 07:39 PM
dube53's Avatar
dube53
ISAMIN
It is under warranty. This is just one of the few other trim parts to be fixed or replaced at the next service visit.
It took 2 months for a seat cover to come from Germany.
Old Aug 17, 2016 | 04:41 AM
bratling's Avatar
bratling
Super Moderator
Odd. As Ian (flyjets01) said, soft-touch paint does eventually peel on pretty much everything, [i]but[/] I am astonished that the center spoke peeled so quickly. I had a mouse I used daily take over two years before its soft-touch paint started to come off. The only way I can imagine the center spoke taking so much wear within the first few years of ownership is if you were using the spoke as a pivot point in turns. If your fingers were twisting relative to the spoke as the wheel spins, I could see the forces being enough to wear that paint unusually quickly.
Which isn't to say I think it's acceptable that the trim wear that way. Just that I could see a situation in which it would.
Perhaps this is why on the Gen 3 cars, the JCW steering wheel trim is shiny black.
Old Aug 17, 2016 | 05:03 AM
bratling's Avatar
bratling
Super Moderator
So this thread made me curious… and I found a fascinating article on the state of soft-touch paint technology from the American Coatings Association:
Formulating Soft-Touch Coatings: A Balancing Act
For automotive coatings, chemical resistance to the insect repellant DEET (N,N-diethyl-meta-toluamide) and suntan lotions is essential, as is resistance to cleaners, perspiration, and grease staining. Adhesion can be a challenge as well. “A coating that sticks to one substrate may not stick well to another, or it may be affected by hand creams and suntan lotions, which at elevated temperatures could soften the coating and migrate into the plastic, causing a failure in the adhesion between the coating and the plastic substrate,” Chavannavar explains. “To achieve the required chemical and mechanical properties, the coating would require a higher Tg and increased crosslinking density, which would harden the film and make it resistant to attack by solvents and other chemicals. Since these requirements are the opposite of those necessary to produce a soft feel, the coatings would either exhibit good resistance properties without being soft or they would be soft, but fail in the chemical resistance tests,” she continues.
I had never really thought about the chemical-resistance requirement of interior car surfaces, at least no further than seating surfaces. I can see where a steering wheel would be a particular challenge, as it's exposed to direct sunlight, extreme heat, constant touching, and any and all chemicals we put on our bodies.
Old Aug 17, 2016 | 10:31 AM
Originally Posted by 3lusive
Thats the one, older JCW like my 2012 did not have the JCW logo , this that was added in 3/2013+
Old Aug 17, 2016 | 10:53 AM
TrueEddie's Avatar
TrueEddie
I've had that exact piece replaced for free under factory warranty.
Old Aug 17, 2016 | 11:24 AM
3lusive's Avatar
3lusive
Hmm, I have it and I have an 01/2013 build!
Old Aug 17, 2016 | 11:28 AM
Interesting, and you bought the car new ? Was not added. Must have been a couple months earlier then the etk states. I have seen allot of 2012 models with this added. Popular upgrade.
Old Aug 17, 2016 | 06:33 PM
dube53's Avatar
dube53
I don't handle the steering wheel by the center spoke and I don't wear hand cream. I also have tinted windows and the only person who drives this car.
The matter is really about wrong preparation of the surface before the coating is applied. I know very well about this industry for 35 years.
Old Aug 18, 2016 | 08:59 AM
3lusive's Avatar
3lusive
I don't think it was added but I can't say, I am the second owner. First owner put 9,000 miles between October 13 and May 16, but she got 99% of the bells and whistles you could possibly get so perhaps this was one of them. She even bought what looks like the MINI seat belt holders (and after doing research I found that they are notoriously poorly designed).
Old Aug 18, 2016 | 10:12 AM
Yea, so she might had seen it on a newer MINI and said , I want that, at some time. Same here with mine, the person before got everything, did not like the black top and had it painted BMW Alpine white , with new stripes and mirror caps painted to the tune of $3,500. So I can understand non stock add ons.
B&WMINI
Sep 20, 2023 11:02 PM
Mar 24, 2016 11:31 AM
PelicanParts.com
Mar 24, 2016 09:27 AM
Mar 23, 2016 09:57 AM
PelicanParts.com
Mar 22, 2016 08:44 AM
