JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW JCW needs clutch at 125k miles
Old Jun 22, 2016 | 09:17 AM
67-LS1's Avatar
67-LS1
I gave a 2009 JCW that I bought new. I now have 125k miles and need a clutch. It is starting to shudder at clutch engagement.
Any how-to videos regarding changing a clutch?
Any "special" tools required?
Should I change the rear main while in there?
Any special tool needed for the seal replacement?
Any other parts I should have on hand, i.e., single use clips, tubes or hoses that break?
Anything else I should service while I gave it torn this far down?
Thanks,
Dennis
Old Jun 22, 2016 | 03:18 PM
Mini Mania's Avatar
JCW Clutch
Thanks,
Dennis
Hi Dennis!
Here is the package you need and alignment tool and locking pin.
http://new.minimania.com/part/G2NMG7...m-Gen2-R55-r59
Though not for your exact year, these may provide a guide:
Please let us know if we can help!
Old Jun 22, 2016 | 07:03 PM
dube53's Avatar
dube53
Thanks,
Dennis
You have been pretty good to go to 125K without a replacement. You certainly have a well maintained car. The fix must be quite expensive if the entire front end has to be lowered.
Old Jun 23, 2016 | 07:30 AM
67-LS1's Avatar
67-LS1
Yikes! What a bear of a job.
Thanks for the tip on the alignment tool.
I guess I can't complain at 125k. I also got 105k out of the brakes.
I will probably end up having a local shop do this work. They quoted me $2700 with all factory parts including a new flywheel. I can't imagine the old flywheel will be usable.
Old Jun 23, 2016 | 11:54 AM
Tigger2011's Avatar
Tigger2011
Alliance Member
That's a pretty decent price as it takes about 10 hours to change the clutch without removing the engine. You'll definitely want to change the clutch fork, pivot pin and bearing sleeve. With as many miles as yours has I'd recommend changing the input shaft seal, axle seals and slave cylinder while its apart. Those don't take long and are cheap insurance.
Old Jun 23, 2016 | 07:04 PM
dube53's Avatar
dube53
This is a lot of money. I cannot figure how I would be willing to spend $3K on repairs for a Mini.
I always buy new cars (no lease) and sell before 3 years with about 30K miles when still under warranty.
This option has always worked fine for me in the last 25 years and I have never been concerned about expensive repairs
I still have one more year of Mini ownership before it will go on the block for sale. At that time, it should be around 32K.
I don't see any other Mini on my list unless a new Coupe would come.
Old Jun 23, 2016 | 07:48 PM
bavmotors's Avatar
bavmotors
You should be able to source your own clutch and flywheel and get it done for a lot less than that quote.
Rock auto has your parts for $1000
10 hours labor even at the dealer is $1000
So that's quite a savings
Old Jun 23, 2016 | 08:18 PM
Tigger2011's Avatar
Tigger2011
Alliance Member
Dealers in NY must be charging a lower rate. Fort Lauderdale dealers charge between $125 and $150 per hour. An independent BMW shop in Pompano quoted one of my customers $2K in labor since they drop the engine and trans together.
Old Jun 23, 2016 | 11:07 PM
bavmotors's Avatar
bavmotors
It's 95 an hour at my mini dealer. Either way if you have a preferred Indy you should still save a good chunk.
Old Jun 24, 2016 | 04:39 AM
MrBlah's Avatar
MrBlah
6th Gear - AX Champion
I never swap flywheel unless it shows signs of uneven wear, and even then I go for a resurfacing first
Old Jun 24, 2016 | 08:28 AM
silkcut's Avatar
silkcut
-It is a bear of job to do the clutch on most front wheel drive vehicles, and the Mini looks to be exceptionally tight. ( I haven't done a Mini yet, but I've done other cars.) There's a lot of interferences to remove to replace the clutch.
- You definitely need the alignment tool, and you will either have to position the transmission from below, or on an overhead transom to get it positioned correctly for installation.
- 125k miles out of a clutch leaves a lot of room for complaint in my opinion. I put 330k on a Saab 900SE, 700K+, between three Toyota 4WD trucks, 200K on a Corolla, and never had to replace a clutch in any of them.
- If you don't already have most of the tools to do this job, you're probably better off having it done.
- Those two videos are really good vid's for a clutch replacement. He does a few things that I probably wouldn't, but you definitely come away with an understanding of the scope and steps involved.
- Whether you choose to do the work yourself, or have it done, I would seriously consider tigger2011's advice to replace the additional peripherals while you're replacing the clutch. It would suck to get it all done, only to have to do it again.
- I've been wondering if that flywheel needs to replaced with a clutch. I know they say to replace it, but that's a big $$$$ item.
- I don't need to replace my clutch at this point, but based on the info available on this forum, and others, I don't expect to get the type of clutch performance out of a Mini, that I have on my other vehicles, so I'm getting ready to do it when necessary.
- How did you ever get 105K out of the OEM brakes? That's amazing.
Old Jun 24, 2016 | 12:24 PM
MrBlah's Avatar
MrBlah
I did my wifes r56 clutch in the garage but I have a 2 post lift, it was quite a bit of work.
My alignment tool failed, I used a socket with some tape on it instead. I would definitely do it again, 1500 in labor buys a lot of tools
I did not have to replace the flywheel, depends on the condition of yours and they can be resurfaced too I did the pivot pin & throwout bearing but that's it
Old Jun 25, 2016 | 05:05 PM
dube53's Avatar
dube53
I don't understand why Mini have not been redesigned with a complete front subframe to drop everything to save time. Even regular maintenance or service to some components seem very often a nightmare that requires to dismantle the complete front end of the car.
Old Jun 25, 2016 | 06:04 PM
timski's Avatar
timski
To me it seems that people need to just except that putting the car in service mode may take some extra time. I would much rather do that then fight in a small space for 4 hours getting pissed off.
Old Jun 25, 2016 | 06:27 PM
MrBlah's Avatar
MrBlah
you will be getting pissed for more than 4 hours if you are doing a clutch, I think it books at 10 hours, took me longer as it was my first mini clutch
Old Jun 26, 2016 | 07:33 PM
67-LS1's Avatar
67-LS1
I have a 2 post lift too, so that would help. How does the engine get supported to remove the transmission and still be able to use the lift?
And what is the "alignment tool" mentioned in a few posts?
Old Jun 27, 2016 | 06:52 AM
MrBlah's Avatar
MrBlah
I used one of those harbor freight cross frame engine brace things
when you line up the clutch into the flywheel you have to center it perfectly so the transmission will slide in. They make a pin that will align it most clutch kits come with the pin/tool now
Old Jun 27, 2016 | 06:56 AM
67-LS1's Avatar
67-LS1
I saw that but the engine lift point is not even close to being in line with the shock towers. I was wondering what it would rest on.
Old Jun 27, 2016 | 06:58 AM
MrBlah's Avatar
MrBlah
it rests on the car body, barely enough room, it does not have to be an exact straight lift
lukgar1
Apr 25, 2016 01:19 PM
MiniVoid
Apr 2, 2016 05:44 PM
thelawson
Mar 29, 2016 09:45 AM
Frixos
Mar 28, 2016 10:04 AM
MarioKart
Mar 25, 2016 03:33 PM
