JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Turbo is dead
Old May 18, 2015 | 09:23 PM
En Fuego Mark's Avatar
En Fuego Mark
Turbo is dead
I've got a '09 jcw that apparently need a new turbo. I figured I'd upgrade it from an oem while I'm at it. Any suggestions on a higher performing turbo? I've done some minor upgrades (intake, intercooler). Any advice would be greatly appreciated.
Old May 19, 2015 | 06:20 AM
Grizld700's Avatar
Grizld700
JMTC, GPops, Owens are all reputable. Several NAM members have reports of each on here. I myself am still using my stock turbo so I can't lead you beyond that.
Old May 19, 2015 | 09:02 AM
Factory turbo JCW 11657583149 here is you don't go down the performance road.
http://www.ecstuning.com/Search/SiteSearch/11657583149/
Larger Intercooler and resonated pipe delete are good upgrade, also the sound tube / pipe delete on the back side before the intake manifold.
Old May 19, 2015 | 11:51 AM
PelicanParts.com's Avatar
PelicanParts.com
Vendor
If you want to upgrade and have the cash to do so, then do it. Make sure you do the proper supporting mods with the upgrades. I run a GTX by Turbo By Garrett (non Mini car), but my car also has a built motor. Borgewarner is a good turbo company as well. Blouch turbo is another. Do your research. Otherwise, OEM is here.
-Luccia
888.280.7799 | 6am - 5pm PST
Old May 19, 2015 | 01:55 PM
En Fuego Mark
Thanks for all the input. I'm definitely going with a non oem turbo. Now to find the right one...
Old May 19, 2015 | 05:14 PM
malibujoey's Avatar
malibujoey
Whats
a pipe delete?
Originally Posted by ecstuning
factory turbo jcw 11657583149 here is you don't go down the performance road.
http://www.ecstuning.com/search/sitesearch/11657583149/
larger intercooler and resonated pipe delete are good upgrade, also the sound tube / pipe delete on the back side before the intake manifold.
Old May 19, 2015 | 06:21 PM
dube53's Avatar
dube53
Is there a way to delete the pops and burbles? Are they coming from the turbo when the engine is hot? What is the dashpot on the side?
Old May 19, 2015 | 09:17 PM
05r50's Avatar
05r50
Not sure what your goal is but if you go bigger you will prob need to have a tune put on the car as well. Plus other things like a catless DP etc.
The JCW will run OK with the stock tune and a bigger turbo. If I recall correctly the stock JCW turbo has a 38mm cold side opening and the replacement I used was a JMTC 42mm. Really didn't have any problems, but decided to have Jan from RMW clean up the tune and do some tweaking. Much happier after that.
Old May 20, 2015 | 01:36 AM
velvetcows's Avatar
velvetcows
Have you looked into rebuilding the turbo? If it isn't too damaged you might be able to have it rebuilt and upgraded.
Pker
Apr 11, 2017 12:14 AM
honderpilot
Oct 11, 2015 06:35 AM
jennster
Sep 28, 2015 06:19 PM
TifosinDel
Sep 28, 2015 10:45 AM
EVMini
Sep 28, 2015 10:20 AM
