JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW R56 JCW Rear Brake Caliper's
Old Jan 30, 2015 | 08:39 AM
pakratt99's Avatar
pakratt99
Brought my R56 JCW Hardtop in to do the rear brakes and found out that the rear calipers are shot. Does anyone have a good source for the rear Brembo calipers without having to go through the dealer at $300 a corner?
Old Jan 30, 2015 | 12:07 PM
If you need the JCW brake calipers they are listed here as well as all the hardware.
http://www.ecstuning.com/Mini-2009-Cooper-R56-John_Cooper_Works-Coupe-L4_1.6L_N14B16C/Braking/Caliper/
Old Jan 30, 2015 | 02:58 PM
pakratt99's Avatar
pakratt99
Thanks for the quick reply, just ordered them up!
Old Feb 4, 2015 | 07:54 AM
You are welcome.
Old Feb 6, 2015 | 06:33 PM
dube53's Avatar
dube53
You are welcome.
How are they different from the standard Mini calipers?
Piston OD? Oil line?
I can understand for the front ones that seem real Brembo.
Old Feb 7, 2015 | 03:33 PM
mbwicz's Avatar
mbwicz
When it was time to put new rotors on my R56S, I bought a set of brackets from WMW and used my regular S rear calipers (along with larger rotors to fill out the wheels better). I was under the impression that the S and JCW have the same rear calipers (except for being Red on the JCW).
Mike
Old Feb 8, 2015 | 08:02 AM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
They are red, that is the only difference. That is why we offer the rotor conversion kit. It allows you to use the larger rotors with your stock calipers.
http://www.waymotorworks.com/wmw-big...7-r58-r59.html
Old Feb 9, 2015 | 06:13 AM
Same, just painted red.
Old Feb 21, 2017 | 10:48 AM
Babidi's Avatar
Babidi
Well they are not the same, you can not put a rear 280mm disc on a standard MCS.
That's why JCW rear brakes are red and can have 280mm discs instead of a 259mm like in regular Cooper S.
Old Feb 21, 2017 | 11:04 AM
mbwicz's Avatar
mbwicz
The calipers are the same except for the color. The brackets that mount the calipers are different, which is what allows the larger rotor to be used.
Both vendor responses are correct, I've run the WMW kit without issue, and not changed the calipers.
Have fun,
Mike
Old Feb 21, 2017 | 11:11 AM
Babidi's Avatar
Babidi
I mean the whole kit, if someone exchange the fronts for jcw kit and want to have 280mm disc on the back then no it is not the same. JCW rear kit needs to be installed to.
I know that calipers are the same just the color is red, but you can not just do plug&play with bigger discs on MCS, it will not fit.
So either a whole jcw rear kit or bigger brackets for stock rear MCS, that what I meant.
Another question, fronts are brembo rears are trw, but there is also o set for rears made by brembo, are those from GP?
Old Mar 1, 2017 | 05:13 PM
tommyb13662's Avatar
tommyb13662
yes +1 to find out about this rear Brembo caliper!
Old Mar 9, 2017 | 07:13 AM
I have not seen the rears with the GP2 by brembo, just the same red painted ones on the factory JCW brakes TRW version. 34216784645 and 34216784646
The newest F56 JCW has the rear Mando calipers that are single piston also. 4 pistons on the front F56 JCW are Brembo.
Old Sep 7, 2017 | 02:46 PM
R56devotion's Avatar
R56devotion
wheel size
can these fit under 16" wheels? What a great idea!!!
Old Sep 8, 2017 | 01:51 PM
Should I dont see why not.
Old Sep 8, 2017 | 01:56 PM
R56devotion
I should have said, will they fit with the bigger rotors and adapter brackets from Way ?
Old Sep 8, 2017 | 05:17 PM
mbwicz's Avatar
mbwicz
I had factory 16" wheels with the JCW brackets and rotors. No clearance issues.
Mike
dyeLucky
Sep 11, 2015 10:41 AM
skippermini
Aug 12, 2015 10:05 PM
dyeLucky
Aug 7, 2015 07:10 AM
