R55 R55 Clubman S - Reverse Light
Old Apr 29, 2024 | 02:26 PM
adfundum's Avatar
adfundum
My R55 has ther typical issue where the left reverse light does not illiuminate and was wondering if there is a setting in Bimmercode or ISTA+ that I can toggle to activate the left reverse light short of running a wire over from the right reverse tailight wiring?
Old Apr 29, 2024 | 02:38 PM
cristo's Avatar
cristo
Alliance Member
There is no left reverse light in
man R55. That light is a rear
fog light (when optioned).
It’s not codable as a reverse light.
Old Apr 30, 2024 | 05:18 AM
adfundum's Avatar
adfundum
I bought new union jack taillights and the reverse wire is present but not energized so I assume it is able to be coded to direct current to that wire when in reverse.
Old Apr 30, 2024 | 05:53 AM
njaremka's Avatar
njaremka
Alliance Member
Community Builder
Community Influencer
Those tail lights require a jumper between the lights to make the reverse on both sides. No way around that.
Old May 1, 2024 | 09:24 AM
r55forme's Avatar
r55forme
A couple of ways you can get 2 reverse lights.
Order the UK left side tail light which has the reverse light on the left instead of the right, then jumper it across https://www.northamericanmotoring.co...se-lights.html
Buy aftermarket tail lights which include a jumper and have reverse on both sides: https://www.northamericanmotoring.co...ml#post4674305
What's your goal? Needing more light when reversing or just wanting symmetry? My rear windows are pretty dark, so even with a bright LED bulb I needed more light. You can also add additional reverse lights. I have one of these sitting on my workbench to go on eventually. It will bolt to the bottom of my license plate mount and tuck in under my bike rack.
Amazon Amazon
lesg45
R55 :: Clubman Talk (2008+)
May 7, 2019 06:09 AM
Omar Proeung
May 2, 2019 02:20 PM
njaremka
Electrical
Sep 5, 2017 05:10 PM
chuckg
14
Dec 18, 2014 10:41 AM
DeK
Aug 21, 2008 06:02 AM
