JCW ECU upgrade....
Originally Posted by invaliduser
Anyone have any idea what is differnet about the JCW ecu flash when compared to the regular S's program?
Thanks,
IU
Thanks,
IU
Performance wise we do not see much of a difference from the ECU. It's not meant to be a great stand alone upgrade. How much of the ECU it actually affects is limited.
Once the JCW kit is installed any aftermarket ECU upgrade would be voiding the ECU upgrade from JCW. Results have not been tested and can vary from car to car depending on other upgrades.
The JCW ECU upgrade might provide for some smoother throttle response but otherwise might not be immediately noticable for street or autocross driving. I don't think it affects mpg- at least not that I have read about.
I had my JCW dynoed a few months back and did wideband 02 with it as well. I'm convinced the JCW ECU is not a tune but a detune. The car was running around a 9.5:1 A/F ratio!!!! There isn't a single ECU tuner on the planet that would tune a car and leave it that rich. This is more rich that a 15% pulley car with no ECU so I'm convinced the ECU does squat and in fact may actually hinder performance.
Paul
Paul
Paul, so what's next? Are you going aftermarket ECU? If not, you could always convince your dealer to install "normal" S software.
Paul
Originally Posted by paulmon
I've got the Unichip. It didn't dyno too well a little while back but it looks like it was my dyno method that was flawed, my butt dyno says it's making a difference. A/F was HUGELY improved.
Paul
Paul
Did you ever get a chance to run new dyno tests on your Unichip set-up, as you mentioned in your earlier thread on this?
Originally Posted by Galaxie500
Paul,
Paul
09R56
Nov 16, 2022 10:49 AM
minimofo
Apr 4, 2016 07:36 PM
M7Speed
Aug 6, 2015 01:48 PM
