JCW JCW Side Skirts/Aero Kit
Old Jan 12, 2013 | 09:44 AM
Mical's Avatar
Mical
After multiple emails w/Justin at Sewell, he's added the JCW Countryman side skirt/aero kit as a pkg.. (Similar to the JCW lip w/all parts needed)
I ordered one from him yesterday (they didn't have all the parts separate) and it's going to be approx. 2 weeks before it arrives. The kit runs $1100 +shipping.
Note: If you check their site, I believe they state front spoiler is included in that pkg. and I believe that's a print error.
Old Jan 12, 2013 | 10:49 AM
pidge1114's Avatar
pidge1114
Sweet. I worked with Justin when I filled in the gaps to my incomplete full aero kit. He works with you to get you what you need.
Old Jan 12, 2013 | 10:57 AM
Mical's Avatar
Mical
Yea, he's excellent to work with. He was extremely helpful when I installed an R58 rear fog light on my CMS. Always helpful and open for ideas.
Old Jan 27, 2013 | 04:01 AM
Mical's Avatar
Mical
Rec'd aero kit yesterday and pulled "all-nighter" & installed. Thanks Justin!
https://www.northamericanmotoring.co...ml#post3667434
Old Jan 28, 2013 | 04:36 AM
dpike's Avatar
dpike
what modifications did you have to make to the front mud flaps ?
Old Jan 28, 2013 | 05:00 AM
Mical's Avatar
Mical
The side skirts are wider (hang lower) than the OEM rocker so front mudflaps had to be lowered by almost 2". Since the mudflaps are molded to body contour, it was a little tricky lowering, drilling new mounting holes staying in contour w/body lines.
Old Jan 28, 2013 | 05:29 AM
dpike's Avatar
dpike
thanks.
any pics of how the mudflaps meet the skirt now ?
Old Jan 28, 2013 | 06:35 AM
Mical's Avatar
Mical
This is only real close up before we got 5" of snow
[IMG][/IMG]
Old Jan 28, 2013 | 10:32 AM
dpike's Avatar
dpike
looks like they still fit well.
since the skirts hang a little lower are extensions for the jacking point blocks needed or are the standard blocks deep enough ?
if sewell sold these prepainted i'd be all over a set.
Old Jan 28, 2013 | 02:05 PM
Mical's Avatar
Mical
Standard blocks are deep enough, funny though they give you an extension for OEM jack (extends the handle away from the car)
re: prepainted - you might check w/Justin at Sewell he might be able to arrange to have them painted or check w/a local painter, there's not alot to painting them.
Old Jan 28, 2013 | 08:12 PM
Hujan's Avatar
Hujan
What blocks are you gents referring to?
Old Jan 28, 2013 | 11:29 PM
Mical's Avatar
Mical
Factory jack pads & Block for floor jack (like ones Outmotoring sells)
Old Jan 30, 2013 | 07:16 AM
Hujan's Avatar
Hujan
Those work for your car? I got a set for BMWs along with the plate with the male tab for the jack itself and they do not work with the JCW side skirts.
The only possible way it would work is if the spacers are very tall and the male tab on the jack plate is very tall as well. Otherwise, the jack ends up pushing on the side skirt, which is very very bad.
Old Jan 30, 2013 | 01:15 PM
dpike's Avatar
dpike
Item #5 is an extension for the JCW skirts
http://www.outmotoring.com/mini-coop...ck_spacer.html
Old Feb 4, 2013 | 07:00 AM
Hujan's Avatar
Hujan
Thanks. Do you happen to know if the extension goes in there permanently, or is it something you insert only when jacking the car? In other words, do I buy one or four?
Edit: Read the link; it's removable. Only one needed per car.
Also, does anyway have measurements for the female end of the jack-point spacers? I want to check whether they are different from the BMW ones I bought.
Old Feb 4, 2013 | 09:56 AM
dpike's Avatar
dpike
i was told from my mini dealer, who didn't have them in stock, to see if a bmw dealer had them because they were the same part and share the same part number between them so i would have to imagine they were identical.
Old Feb 4, 2013 | 09:44 PM
Hujan's Avatar
Hujan
Good thinking. I'll have to check the part numbers. I'm betting they are the same.
Any idea whether this will work with the extender:
http://www.outmotoring.com/mini-coop...ad_spacer.html
Old Feb 6, 2013 | 09:05 AM
Mical's Avatar
Mical
I've used my floor jack w/o the spacer and had no issues.
Re: Dimensions of plate, spacer & pad (see attached)
[IMG]
[/IMG]
Old Jan 3, 2014 | 08:57 AM
zmsamson's Avatar
zmsamson
Can someone post a photo of the jack points on a Countryman JCW or a Countryman with the Aero Kit?
Old Mar 15, 2014 | 10:32 AM
VColi's Avatar
VColi
I checked at the BMW dealer. BMW's have four of these "Jack Pad - Under Car Support Pad for Lifting Car" (Part # 517 170 39760) permanently mounted on the four jack points on the cars.
So do we need to do the same for the our Countryman's? I am referring to item 4 shown in the earlier posted diagram, which is the "Jack Pad - Under Car Support Pad for Lifting Car" (Part # 517 170 39760); not the "JWC Extension Block" (Part # 517 171 88454) which is item 5 in that diagram.
If Mini does not provide the Jack Pad preinstalled on the cars and general not stock the part, how do they expect you to use the provided jack?
Also what is the Part # for the "male tab for the jack itself" or "plate" that goes on the jack, mentioned earlier?
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
cm.d
Aug 19, 2015 08:51 AM
