JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Need some advice from the experts (2009 JCW)
Old Jul 19, 2012 | 09:12 AM
Furiousd's Avatar
Furiousd
I've been looking at a 2009 JCW and have a few questions before I take the plunge.
Here a (somewhat) short overview
It's within 2k of the warranty expiring
I just talked to the Mini Shop in Charlotte. Other than a rear brake repair under warranty in 2010. The records were basic maintenance. The recall issued in Jan. 2012 is outstanding but that is easily fixed with a trip to the dealer. No records of timing chain or clutch issues...
... that's where my question comes in. I'm little nervous after reading of both of these potential problems. Especially with a soon to expire warranty. Are there any signs that I should keep an eye/ear out for if I take it out for a test drive?
Thanks in advance for the help!
Old Jul 19, 2012 | 06:52 PM
timfitz63's Avatar
timfitz63
If you've been reading up on the issues throughout the forum, you probably already know the major symptom of timing chain problems: the rattle. It's pretty distinctive, once you hear it:
Not much to look for with the clutch except the usual signs of trouble: slipping. They seem to fail without much warning, too, so it's just hit or miss on those...
Good luck!
Old Jul 19, 2012 | 07:02 PM
05r50's Avatar
05r50
Check to see what the cost is to extend the warranty while you still have coverage. It will be expensive, but much cheaper than a toasted motor 3000 miles from now.
Is it possible to have the car takin to the dealer for a thorough check prior to purchase? I allowed a buyer of my car to do this. They paid for it.
The timing belt tensioner is determined to be replaceable by measuring the slack. If it is at max or more as specified by MINI then they perform the maintenance under warranty. Not to say that they will willing do that labor to check it if there are no outward signs.
Also, you will need to check oil level constantly. This may sound like overkill, but MINI allows for some silly amount like 1 qt of oil every 3000 miles to be consumed. So if you don't check and wait til 15000 miles for oil change you have the potential for having lost 3 qts of oil.
Disclaimer: I have a 2009 JCW and I LOVE IT.
Old Jul 19, 2012 | 10:47 PM
onefish2's Avatar
onefish2
And some 2009 JCWs like mine have not had any these engine problems. My clutch did go out at 27,000 miles though. You can add that to your list of worries.
Just get the car its a blast to drive.
Old Jul 20, 2012 | 07:30 AM
Furiousd's Avatar
Furiousd
Test drove the car yesterday afternoon. Seems to be in fine mechanical shape. Sounded fine on startup. No hiccups during a "spirited" drive. One thing that will have to go If I purchase are the tires. Some brand i've never heard of and they lived up to expectations
Old Aug 18, 2012 | 06:14 PM
beau68's Avatar
beau68
One other issue to be on the lookout for. I bought an 09 JCW last month and I live in the Charlotte area. Car had 58K miles and 3 days after I bought the car, the thermostat housing began to leak. Turns out this is a common issue and the local dealer keeps 7 to 10 in stock. They said they sell 4 or 5 a week. Takes about 3 hours to replace the first time if you are mechanically inclined. Good luck!
Old Aug 21, 2012 | 04:59 AM
anitan1's Avatar
anitan1
Look for any signs of oil leakage in the spot where the car is usually parked. My 09 JCW started leaving some very small oil spots on the floor of the garage just under the passenger side of the car toward the front of the engine (under the timing chain). When I took it into the shop I was told that it was the timing chain tensioner (I never heard the rattle). It was fixed under warranty.
If you have had the car checked at a MINI dealer, they should be able to tell you a lot about the condition of the car. You have to be able to trust your MINI dealer. Good luck with the purchase. I love mine. Really.
Old Aug 21, 2012 | 08:27 AM
JPMM's Avatar
JPMM
just whine about the rattle , they might go and change everything anyways
Sexual Chocolate
Mar 31, 2019 08:02 PM
scottrn
Aug 22, 2015 07:26 PM
Herleman
Aug 16, 2015 06:41 PM
2manyhobbies
Aug 9, 2015 06:02 PM
marendt428
Aug 8, 2015 04:44 AM
