JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW pulley removal
Old Dec 27, 2011 | 10:57 PM
shawncas's Avatar
shawncas
JCW pulley removal
Semi confused as to whether the "JCW pulley removal tool" is the only way to remove said pulley....
Wanting to swap to a smaller pulley, but being told the only way to remove is with the "JCW pulley removal tool" to which apparently 1 exists in the entire world. ;0
Any confirmation?
Old Jan 12, 2012 | 03:58 AM
s2k7's Avatar
s2k7
Any confirmation?
I owned JCW and replaced my pulley to 17%, lucky the shop I went has a pulley
remover for JCW. Saved me a lot of money....otherwise I have to buy it myself.
Oh yeah...unfortunately I live in Connecticut.
Old Jan 13, 2012 | 09:27 PM
Autobot_Lazi's Avatar
Autobot_Lazi
ebay has people selling them
Old Jan 14, 2012 | 03:11 AM
JPMM's Avatar
JPMM
grind it off
Old Jan 14, 2012 | 05:29 AM
daflake's Avatar
daflake
Originally Posted by JPMM
grind it off
If you go this route, be very careful you don't damage the SC shaft. Best to simply buy or rent a pulley tool. You might contact Way (http://www.waymotorworks.com/) to see if he has one that you can rent.
Old Feb 3, 2012 | 08:32 AM
HerpDerpington's Avatar
HerpDerpington
I was on tech supprt with Alta last night and was informed that the way they accomodate the smaller diameter JCW pulley is to sandwich some pop-can between the stock pulley remover and the slightly smaller JCW pulley.
YMMV, but I think Alta has a good rep around here, no? I'm n00b.
Old Feb 3, 2012 | 10:57 AM
shawncas's Avatar
shawncas
Heard much the same... Guys at Way wanted to act like their tool was the only option for removing my JCW. Fortunately found out there were other options.
Old Feb 4, 2012 | 11:56 PM
bahawton's Avatar
bahawton
I used this puller & it worked great:
http://www.sears.com/shc/s/p_10153_1...3&blockType=G3
The only downside is you have to jack/tilt your motor more to make room for it.
Old Feb 5, 2012 | 05:30 AM
daflake's Avatar
daflake
You got lucky... I have seen some pulleys that were so tight that one of those bent it to hell. After that I have to cut it off.
Old Feb 16, 2012 | 09:27 AM
astroBlackMetallic_Mini's Avatar
my pulley was destroyed by the dealer when they did my reduction. it also destroyed the pulley remover!!!
so, be careful! id say, try a cheapy version first, like from Harbor Freight. Otherwise, a crow bar, hammers, and maybe some heat will do it. thats what the dealer here did! i saw 3 guys with a freakin crow bar and hammers going to town on my pulley! lol.
id say, use some lube of some sort, really soak that thing like, over night. then, if its still not loose, maybe try a heat gun on the pulley itself, heat it so it expands just a fraction...
Old Apr 21, 2012 | 09:06 PM
nickheart's Avatar
nickheart
I was lucky and had a trusted mechanic who had a keen hand with a grinding wheel ... i guess that aftermarket shops figure we paid a whole lot for the JCW badge, so it's not their problem.
bobbiemartin
Jan 20, 2016 05:28 PM
Aug 7, 2015 09:51 AM
Aug 7, 2015 08:10 AM
