JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW ECU upgrades - dealer only?
Old Nov 6, 2011 | 07:50 PM
Eric B's Avatar
Eric B
Hi all,
I've been looking for this on the forum but can't see it... so sorry if this has been asked before...
I am ordering a handful of R53 JCW parts for my 06 Cooper S and some of them are meant to work with JCW ecu upgrades (like the injectors & the flap airbox).
I've seen the BMW TIS sheets and it looks like you need to install the software at the same time that you are installing the parts.
I wanted to install the parts myself (easy - I've done this before), and either try to research an aftermarket ecu upgrade, or ONLY bring the car to the stealership for the ECU re-flash.
Can I drive the car with 380 injectors + upgraded airbox on the stock R53 ecu just to get to the stealership if I decide to use their overpriced services?
The less I deal with the dealership the happier I find myself.
Ever since the warranty ran out I've had nothing but problems with them.
What do you all think?
Thx
-e
Old Nov 7, 2011 | 01:04 PM
mr. jim's Avatar
mr. jim
The fuel map for the 380's is different, so it may or may not run at all or very good. You'd be better off to find a place that does custom tunes on MINI's and have them do a tune with your mods.
Old Nov 7, 2011 | 01:45 PM
davisflyer's Avatar
davisflyer
+1
Old Nov 7, 2011 | 01:46 PM
davisflyer's Avatar
davisflyer
In fact, your close enough to RMW to get a real nice tune
Old Nov 7, 2011 | 02:53 PM
Eric B's Avatar
Eric B
so youre saying i shouldnt install them myself because id have a hard time just getting to rmw on the stock fuel map with the 380 injectors? am i reading you correctly?
Old Nov 7, 2011 | 04:09 PM
nodoze's Avatar
nodoze
You will be fine putting the new intake and injectors in and then driving around. I put my JCW injectors in and then drove down to rhode island the next day for the update and the car was fine. The ECU can take up to the JCW sized injectors without immediately needing a re-tune
Old Nov 7, 2011 | 05:12 PM
JCWSLAYER's Avatar
JCWSLAYER
This is absolutely true.
Old Nov 8, 2011 | 07:46 AM
Eric B's Avatar
Eric B
ok cool - thanks guys for confirming!
time to order some parts...
surfblue
Oct 24, 2018 01:20 AM
TybeeJim
Aug 19, 2015 02:31 PM
sabjcw
Aug 14, 2015 07:40 AM
