JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW intake question
Old Mar 28, 2009 | 10:08 AM
turbodogz's Avatar
turbodogz
JCW intake question
So, after taking out the entire intake box to get the filter out so I could replace the factory filter with the K&N replacement, I need to know what the deal is with that little hose off the left/front of the intake box. I have reinstalled the intake box with the new filter and everything else, but . . . Does this hose connect to anything other than the box? Thanks.
Old Mar 28, 2009 | 10:50 AM
buzzsaw's Avatar
buzzsaw
Connects to the vacuum System?
Old Mar 28, 2009 | 11:07 AM
BlimeyCabrio's Avatar
BlimeyCabrio
Yep. Read this.
http://motoringfile.com/files/JCWUPGRADE.pdf
Old Mar 28, 2009 | 01:52 PM
turbodogz's Avatar
turbodogz
Where? Can someone enlighten me to the picture on the bottom of page 6?
Are you talking about the A/C compressor? Photos of what its supposed to look like?
Old Mar 28, 2009 | 01:58 PM
BlimeyCabrio
The airbox has a small, hard plastic vac line coming out the front (6). This has a white barb connector on it. It plugs into a black rubber vacuum hose (5) that connects to a "T" fitting (3) spliced into the bypass valve (2) vacuum hose. The bypass valve diaphragm unit is the little (2" diameter) black thing with the vacuum hose connected to it.
It's under the intercooler horn in this photo:
You can see the JCW airbox vac line connected to the rubber vacuum hose here. Somewhere, you have a loose hose floating around under that waiting to be plugged back in... it's a tight area to get your hand into...
Old Mar 28, 2009 | 02:38 PM
turbodogz's Avatar
turbodogz
Very nice. Thanks a ton. The "under the intercooler horn" was the key to that. Took off the intercooler cover then pushed aside a braided wrap and waaaaaay down in there was a little nipple that needed a hose. Motor On!
Old Apr 9, 2009 | 12:30 PM
SugarBelly's Avatar
SugarBelly
howdy, guys:
the install pdf susggest this is only for JCW equipped cars. is this an absolute?
Old Apr 9, 2009 | 02:03 PM
Crashton's Avatar
Crashton
No it is not. I believe the kit that comes with larger injectors may be that way, but just the intake works fine on non-JCW cars. Mine has worked flawlessly on my non-JCW for 45,000 miles. It's a very nice intake.
Old Apr 9, 2009 | 02:29 PM
SugarBelly's Avatar
SugarBelly
thanks much. figured, but wanted to be sure.
Old Apr 13, 2009 | 02:23 AM
obaspinar's Avatar
obaspinar
What about programing The Ecu , I Mean The lip that opens after 4.500 Rpm , to do that its said that you need to reprogram the Ecu , Did you remove the Lid ?? . My JCW Cold Air Intake is coming this week but I heard that every one is removin' the Lid since they can not program the Ecu.
Old Apr 13, 2009 | 06:28 AM
BlimeyCabrio
No ECU programming required for the airbox. Only for the injectors. Just install the airbox following the instructions and the flap will work JUST FINE as designed.
Old Apr 13, 2009 | 06:32 AM
obaspinar's Avatar
obaspinar
Thx this week I will install the airbox , I hope I can manage it . Thx for the Info
Old Apr 13, 2009 | 06:33 AM
SugarBelly's Avatar
SugarBelly
really?!
Good point, obaspinar. why can't they get re-programming? Is official jcw tuning required to operate the 4500 lip? If so, that renders the cost for the jcw intake moot, doesn't it? there's too many CAIs out there that look great, return results & add meaty sound.
Old Apr 13, 2009 | 06:36 AM
SugarBelly's Avatar
SugarBelly
gotcha
missed your post, Blimey.
thanks for posting the straight dope.
Old Apr 13, 2009 | 02:13 PM
Crashton's Avatar
Crashton
+ 1 ^
Old Apr 19, 2009 | 07:38 AM
obaspinar's Avatar
obaspinar
I installed it perfectly but it lid Engine lamp and i connect my mini to Laptop and it said the problem was In accelerator pad , and we couldnt be able to erase the problem from the ECU , but after i disconnected it from the PC it went back to normal and then again i connect it to PC and we were able to erase the problem , not its working flawless, Thx for the help
W0TM8
Dec 19, 2019 07:50 AM
massmini03
Aug 12, 2015 11:19 AM
nomar116
Aug 10, 2015 11:24 PM
papawhiskey
Aug 10, 2015 09:31 PM
