JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Ready to attempt rear fog light toggle switch install
Old Feb 26, 2009 | 05:56 AM
javedikian's Avatar
javedikian
I have my rear fog lights comming along with a toggle witch. I need to go get the new switch cover (P/N: 64113442594). I've read the only instructions available for this but there are still some steps later in the process that don't have pictures and seem a little vauge to me.
For all those who have done this, are there any pitfalls that you wished you knew about? Also, are the screws around the air vents supposed to be removed as well? Ayone have any additional photos? Thanks.
Old Feb 26, 2009 | 07:00 AM
MoxieMini's Avatar
MoxieMini
Well, I've never done this (so I have no advice to give), but I've been wondering if it could be done. Be sure to let us all know how it goes!
Old Feb 26, 2009 | 08:05 AM
phlash's Avatar
phlash
www.realoem.com is your friend.........good luck
Old Feb 26, 2009 | 09:23 AM
ScottRiqui's Avatar
ScottRiqui
Well, you're getting a new switch and a switch cover, so it sounds like you've got the mechanical parts of the project covered.
I don't know if the R56 is the same as the first-gen cars in this respect, but I know that with the older cars, after you installed the switch and the rear fog lights, you had to have the car's computer reprogrammed at the dealer to tell it you have rear fog lamps. This is because the toggle switches don't control the accessories directly - they just send signals to the car's computer, and the computer actually handles turning the accessories on and off. If the computer doesn't know that you have rear fogs installed, it will just ignore the signal from the rear fog toggle switch.
Old Feb 26, 2009 | 11:52 AM
javedikian's Avatar
javedikian
Here are the only instructions I've found. I'm hoping someone here has done this and can expand on them.
https://www.northamericanmotoring.co...-retrofit.html
Old Feb 26, 2009 | 05:17 PM
digi0123's Avatar
digi0123
should be fog light....not lights? Only one yes?
Old Feb 26, 2009 | 05:21 PM
ScottRiqui's Avatar
ScottRiqui
Looking at the very last line of the directions, it appears that the R56/R55 still require a trip to the dealer to have the rear fog lamp feature activated in the car's computer after you've finished the physical installation & wiring.
Old Feb 26, 2009 | 05:27 PM
javedikian's Avatar
javedikian
OK, I know I need it reprogrammed, that is easy. Putting in the 2 lights in back is also very, very easy.
I want to know if anyone has added the switch and if they have any additional pointers or regrets that are not already in the instructions above.
Also, what type of bulb goes in there?
Old Feb 27, 2009 | 09:30 AM
saturn's Avatar
saturn
The bulb is a 921
Old Feb 27, 2009 | 10:23 PM
javedikian's Avatar
javedikian
Thanks for the bulb pic - that's what I needed. I also finally found this awesome video on how to take everything apart:
https://www.northamericanmotoring.co...al-on-r56.html
Old Feb 27, 2009 | 11:49 PM
rkw's Avatar
rkw
The fog lamp assemblies come with bulbs included. This is typical for lighting parts sold by MINI, and the instructions mentioned earlier does say bulbs are included.
Old Feb 28, 2009 | 06:04 AM
javedikian's Avatar
javedikian
So are there any other relatively inexpensive retro fits I should do at the same time while everything is apart? Like Bluetooth, USB or iPod?
Dec 23, 2015 10:36 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
