JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW JCW springs
Old May 20, 2008 | 12:18 AM
minimust's Avatar
minimust
JCW springs
Can the JCW "lowering" springs be purchased as a stand-alone item, apart from the JCW sports suspension?
Old May 20, 2008 | 01:40 PM
PaulCIssa's Avatar
PaulCIssa
Get in touch with Morristown Mini (Morristown, NJ) and have them fax you the order form. There's 3 part numbers for different spring rates dependent on your car's build. $321.00 delivered to your door.
Old May 20, 2008 | 08:27 PM
minimust's Avatar
minimust
Thanks very much, Paul! Exactly the info I was hoping to get.
Regards . . .
Old May 24, 2008 | 02:20 PM
Bhatch's Avatar
Bhatch
do you need a VIN to get these?
Old May 24, 2008 | 06:59 PM
PaulCIssa's Avatar
PaulCIssa
Yes, they ask for VIN to determine build specs.
Old May 25, 2008 | 02:23 PM
MINIGURU@WAY MOTOR WORKS's Avatar
Vendor
He's correct you can get the springs by themselves no problem. They do want the VIN when I order them to get the correct rates.
www.WayMotorWorks.com 2006 & 2007 NAMCC Overall Champion
Alta,M7,Helix,Wilwood,H-sport,Milltek,CROSS,Craven,DDM,H&R,Megan,Carbotech,EBC,Forge,TSW,Powerflex
Old May 25, 2008 | 02:42 PM
Bhatch's Avatar
Bhatch
yeah but the VIN issues is a problem since my address is Canada my VIN links to my adress, i can not get US dealers to sell to me. To save mucho's denario on JCW parts.
Old May 25, 2008 | 06:19 PM
digi0123's Avatar
digi0123
maybe you need a friend in the states?
Old May 25, 2008 | 07:31 PM
Vendor
PM me your VIN and I'll get them priced for you. I sell to CN, the shipping is what hurts.
Old May 26, 2008 | 01:09 PM
goat's Avatar
goat
That is odd. I am also in canada and bought my JCW parts from Morristown without any issues. They cannot SHIP to canada, but they can certainly sell to canada. You can have them shipped to a parcel service in a nearby state and then pick them up and declare them at the border. Usually pay just applicable taxes (no duty) when you do this and still works out far cheaper than buying from a Canadian dealer.
Old May 26, 2008 | 01:50 PM
lhoboy's Avatar
lhoboy
Your dampening rate will be problematic if you don't switch the struts at the same time you swap out the springs. It'll start bouncing around corners like the other poorly tuned ricers out there. The struts need to be tuned for your spring/weight combination. (said differently, the springs are spec'd based on your strut/weight combination). Based on your VIN, the dealer will provide the right spring rate for your vehicle weight, assuming you are using JCW struts. If you are not using those struts, the spring/dampening rates will not match properly for your vehicle weight.
Old May 26, 2008 | 11:41 PM
Bhatch's Avatar
Bhatch
JCW springs, Koni yellows...maybe revavled.
Thanks for the offer mr.motorworks.
Old May 27, 2008 | 06:48 AM
PaulCIssa's Avatar
PaulCIssa
Excellent combination, IMO.
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
dyeLucky
Sep 11, 2015 10:41 AM
nomar116
Aug 10, 2015 11:24 PM
dyeLucky
Aug 7, 2015 07:10 AM
