JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW JCW Aero underbody repair question
Old Feb 29, 2008 | 10:05 PM
jmelrose's Avatar
jmelrose
Hi!
I have the JCW Aero Kit on my 07 MCS and it seems there is some plastic that extends down vertically from the bottom of the front Aero Kit bumper, reducing the clearance between the under-chassis and the road by a couple inches. It is about 6 inches back from the front edge of the bumper. It reminds me a bit of a cow catcher, but smaller and it is invisible unless you get down on your hands/knees to see it, for the most part. Anyway, I recently pulled up too far over a parking block and knocked one around pretty good, loosening it. I checked the other side to see how it was supposed to look, and the other one had already fallen off, I found out! So I am assuming they are meant to hang down several inches but I have nothing to compare it to.
So, does anyone know the value (as in, what their job is down there) of those pieces and how I might find out the part numbers if I want to replace them. It LOOKS like they should just snap back on, but there may be more to it than meets the eye. I know there are places to find Mini part numbers but I am having a harder time finding the JCW Aero Kit repair part numbers in particular.
Old Mar 1, 2008 | 12:39 AM
japtor's Avatar
japtor
They do aerodynamic stuff...not exactly sure what stuff, but it does something with the air flow. A lot of people with the aero kit have damaged, lost, or just removed the pieces (before one of the first two things happens). I'm not sure anyone outside of the designers really know how much of a difference they make, but it seems like no one has noticed much. Supposedly it may help at higher speeds (100+ I guess) but I don't remember if anyone tested the theory.
I believe it's a simple fix and the pieces are available from the dealer, I think they are $15 or so, but I'm not 100% on that.
Old Mar 1, 2008 | 02:59 AM
ghosthound's Avatar
ghosthound
my guess is they lower the drag, to some degree, below the car. I have heard they are relatively cheap at the dealer although im not sure about 15 bucks though. Ive also heard they are designed to be easily replaced because they are pretty obviously fairly easy to break off. Just give your dealer a call, i think its called the front airdam. You could also check on realoem for the part # but im sure if you describe it to the parts person they will know what you are talking about.
Old Mar 1, 2008 | 05:55 AM
jmelrose's Avatar
jmelrose
Thanks to you both. VERY helpful!! I'll investigate!
Old Mar 1, 2008 | 08:38 AM
n1tr0's Avatar
n1tr0
I think this is what you're looking for.
http://new.minimania.com/web/Item/G2.../InvDetail.cfm
very cheap to replace, everyone scrapes them a bit from time to time
Old Mar 1, 2008 | 02:30 PM
hendricks488's Avatar
hendricks488
no n1tr0 he isnt looking for the air dam, they are just two small flaps...i lost one of mine and damn near knocked off the second one...the way that it was explained to me by my MINI dealer and techs is that they were just there as precaution so that u dont damage the body kit itself..ex. driving up a driveway, speedbump, ect....i took the second one off and havent had any problems...my dad got an '08 last week with them and has almost already lost one of his, so surly they werent meant to stay on for good considering the ease it is to rip them off....
Old Mar 1, 2008 | 02:36 PM
uzun's Avatar
uzun
Please remember to post the part number for those small flaps here if you find out what it is. I also have the JCW aero kit and I will probably need to replace those flaps sometime.
Old Mar 1, 2008 | 04:55 PM
n1tr0's Avatar
n1tr0
ah you're right, I just checked the aero kit pdf, it looks like they're the left & right ram-air lip's or in realoem, deflector lips
looks like part#'s
51110415351 left
51110415352 right
Old Mar 1, 2008 | 06:49 PM
ATCQL's Avatar
ATCQL
One of mine was about off, so i removed it completly and the other as well.I am not an engineer,but i don't believe it serves any purpose ,except its there to make contact with any thing that gets in the way.
Old Mar 1, 2008 | 10:48 PM
r56mini's Avatar
r56mini
I think they reduce lift and also provide air circulation to the radiator/intercooler.
Old May 13, 2008 | 04:45 PM
SJ Skid's Avatar
SJ Skid
One of mine just broke... and I've been searching trying to figure out what exactly, it is.
This thread helps make my day a little better. So thanks to all who wrote before me!
Old May 13, 2008 | 05:44 PM
mellowmcs's Avatar
mellowmcs
on some bmws those are used to direct air flow to the brakes to cool them.
Old Jun 25, 2018 | 12:32 PM
edgy's Avatar
edgy
Old Jun 25, 2018 | 02:44 PM
You are in the gen 2 area, yes the front bumper is nla. Can you show me what you have and I might be able to come up with a piece from another year and model to mod it to work.
Old Jun 25, 2018 | 02:50 PM
edgy's Avatar
edgy
Old Jun 25, 2018 | 02:52 PM
No problem. Yep sometimes they have the same issues. But in this case its a designed part, but what i can do if always use my MINI knowledge and find other OEM parts as work arounds.
Old Jun 26, 2018 | 04:11 AM
N2MINI's Avatar
N2MINI
On the 1st Gen cars that is molded into the Aero Bumper so once you curb it, or bottom out good ( for us with lowers cars ) it is not a replaceable part. I cut mine down shorter when I had the bumper off installing my home made splitter.. It could possibly direct air somewhat sideways to the brakes, or create a vacuum below the engine to pull air down and under the car to help air flow thru the engine bay..
Old Jun 26, 2018 | 10:49 AM
Subw00er's Avatar
Subw00er
Yup, its a badly designed lip on the gen 1 aero kit. I got a spanking new aero front bumper and the first snow storm 80% of it was immediately ripped off (I'm not lowered). I'm just going to trim it flat the next time I'm under there.
Old Jun 26, 2018 | 01:56 PM
cristo's Avatar
cristo
Alliance Member
looks like part#'s
51110415351 left
51110415352 right
Note: Different part numbers for R55.
Pretty cheap in either case.
W0TM8
Dec 19, 2019 07:50 AM
Dec 23, 2015 10:36 AM
elightbo
Aug 17, 2015 01:50 PM
massmini03
Aug 12, 2015 11:19 AM
