JCW Garage Interested in John Cooper Works (JCW) parts for your 1st Generation MINI? This is where JCW upgrades and accessories for the Cooper (R50), Cabrio (R52), and Cooper S (R53) MINIs are discussed.
JCW 03 supercharger failure
Old Jan 17, 2008 | 02:01 AM
harhoosh's Avatar
harhoosh
Hi guyz..
i own jcw03 . I toke my car yesterday to change my tensioner and the belt.. beacause there was noise coming while my car is cold.. so then the tech guy told me that my supercharger is almost DIE : ) ,, he told me I have to change my supercharger befor my engine be gone :| ? it is true ?
do i have to go for new one ?? it's too expensive..
wut about M7 supercharger ??
please guyz i need your help
Old Jan 17, 2008 | 03:20 AM
Motor On's Avatar
Motor On
How many miles on the MINI? Is it due to coating or gears that the S/C is almost gone?
Depend upon the level of damage it's either a rebuild or replacement, in your case with a JCW or other aftermarket available S/C a take off S/C may not necessarily be ported the same causing you some power loss.
Old Jan 17, 2008 | 05:08 AM
harhoosh's Avatar
harhoosh
95000KL on it ... is it possible to rebuild the supercharger ?
Old Jan 17, 2008 | 06:56 AM
ScottinBend's Avatar
ScottinBend
There is a used one in the marketplace right now. Same as yours just the stock (non-JCW) pulley.
Old Jan 17, 2008 | 09:21 PM
Motor On's Avatar
Motor On
It depends on the cause and extent of damage, if you do a search this has become a very common issue the past few months as so many R53s pass that 100k mile point.
Old Jan 18, 2008 | 02:40 AM
harhoosh's Avatar
harhoosh
there is any web sites have this part ? (supercharger) ?
i saw in the mini mania its too expensive :S ,, wut about a used one ? for how much is it worthy to buy ??
Old Jan 22, 2008 | 09:31 PM
harhoosh's Avatar
harhoosh
is it gonna harm my engine if i keep driving ???
Old Jan 22, 2008 | 11:33 PM
user 7082082's Avatar
user 7082082
I dont remeber if it was on motoringunderground or NAM but there is a company that rebuilds them for i think 800 bux it was. I bet you can find it if you search a bit.
Old Jan 23, 2008 | 12:11 AM
verveAbsolut's Avatar
verveAbsolut
Stigemeier or Endyne.
Understand though that if the needle gears are worn down, there's nothing they can do: it's a locked part from Eaton.
As long as those are in good shape though they can rebuild it: new seals, re-specced, etc.
Or so I've been told/read.
- Matt
Old Jan 23, 2008 | 01:23 AM
Motor On's Avatar
Motor On
Yes, its tied into the serpentine belt, once that stops your water pup stops engine over heats and dies.
Old Jan 23, 2008 | 02:21 AM
MC 2's Avatar
MC 2
These is one on ebay 4$$ have a look there..
Old Jan 23, 2008 | 04:52 AM
muladesigns1's Avatar
muladesigns1
When replacing such an important engine componant like a SC, I would highly recomend a new or rebuilt unit. if you buy a used one then you are looking at the same headache all over again sooner then if buying new.
I never put used engine parts on a vehicle.
Old Jan 23, 2008 | 09:02 AM
miminut's Avatar
miminut
From: Half Moon Bay California, 25 miles south of SF on the coast
Buy used
By buying used you save bucks, lots of them. Second, by buying used and saving the bucks you can have the part modified the way you want: In this case you will get a SC with better bearings, seals and polished and ported. It will be far better then OEM and will last far longer. A last point, by buying used you help keep parts out of landfills, for the green types like me this counts. You want a polished ported head? Where do you think that bare head came from? Sounds like I'm preaching, not, just think about it.
Old Jan 24, 2008 | 04:46 PM
muladesigns1
I could understand what you are saying, but, you are talking about buying a used part and rebuilding it.
that is different from what was being proposed. the person was advising purchasing a used part to install as is. (not Smart).
especially on such a critical component.
As far as the head story goes, it depends who you get it from. some companys build and design there own and cast them from scratch.
as far as the landfills go. whatever dosent get sold just gets melted down and recycled anyway. so buying from a salvage yard does nothing for the enviroment.
Old Jan 25, 2008 | 05:30 AM
healey67's Avatar
healey67
If your SC locks up and stops, dont worry about the overheating issue, It wont run long enough to do that once the SC locks up. Your call will not get any air into it causing the engine to stall befor you overheat. You will know when it happens
Old Jan 25, 2008 | 06:43 AM
markertoo's Avatar
markertoo
The usual problem is that the supercharger loses its lubricant in the water pump end, but the charger itself does not usually seize. It will continue to spin, but the water pump stops. THAT is why the cars overheat.
I actually have an extra supercharger, as I committed to buying 2 when mine failed. So, I have a spare used one.
Old Jan 25, 2008 | 08:49 AM
Eric_Rowland's Avatar
Eric_Rowland
that is different from what was being proposed. the person was advising purchasing a used part to install as is. (not Smart)...
IMO it depends on the part.
Used clutch? Folly - because it takes so much effort to get to it.
SC? - Given that the failure mode is virtually always the water pump gears, it's very easy to inspect/refill/seal those gears before install to ensure that they are up to snuff.
It also depends on whether you do the work yourself, and if you can afford downtime on the car. Also the cost delta. A reman SC from minimania is $1385. I got a used one for $150 - I can install as is, or spend another $3-500 to get it rebuilt if that makes me feel better. Still well below the cost of even a reman - I've seen $2200 for new ones.
YMMV
Old Jan 25, 2008 | 11:35 AM
mini-rolls's Avatar
mini-rolls
You can send it to http://www.psesuperchargers.com/ to be rebuilt for less than money. They can rebuild a m-45 for $450.
Old Jan 25, 2008 | 11:53 AM
MotoringSpeed_gnat's Avatar
MotoringSpeed_gnat
The market for used ones has been climbing as of late. While I could find lots in $400 range 6 months ago now they are going in the area of $600-$800. Retail on a Reman unit from MINI is $1385, we sell them for $1110 (20% discount)
Old Jan 25, 2008 | 12:56 PM
Eric_Rowland
Do they have the water pump gears? That seems to be the gating item in rebuilding an SC.
Old Jan 25, 2008 | 02:41 PM
harhoosh's Avatar
harhoosh
so guyz. wut do you advice me ?
anyone have a used one. cuz i jst want to install it and sell the car ..
Old Jan 25, 2008 | 02:45 PM
muladesigns1
If your gonna sell it go as cheap as possible. theres prices for cheap ones in this thread scroll back and youll see them
Old Jan 25, 2008 | 03:41 PM
SteveS's Avatar
SteveS
I don't believe the rebuilders have access to replacement gears. That is why you get stuck buying take-offs or buying new.
Old Jan 26, 2008 | 04:18 AM
harhoosh's Avatar
harhoosh
I tried to search but i couldn't find any S/C
anyone can give me a web site which i can order from it please.. : )
Old Jan 26, 2008 | 05:23 AM
muladesigns1
POST #18 gives a web address, POST #19 Gives a web address.
I can't hold yer hand any more then that
