JCW Garage Interested in John Cooper Works (JCW) parts for your 2nd Generation MINI? This is where JCW upgrades and accessories for the MINI Clubman (R55), Cooper and Cooper S (R56), and Cabrio (R57) MINIs are discussed.
JCW Need help with JCW hand grip!!!!
Old 05-05-2007, 06:53 PM
devious duck's Avatar
devious duck
devious duck is offline
OK, i just got the new hand grip and shift **** from JCW. The shift **** is installed. How do i get the hand brake grip put in. I know someone else has to have it by now. I need some guidance. Thanks
Old 05-13-2007, 10:08 AM
mr. jim's Avatar
mr. jim
mr. jim is offline
OK, did you get the old one off already? If so you need to wrap a small amount of either electrical tape or duct tape on the handbrake so that the JCW grip will stay in place.
Old 05-14-2007, 08:59 AM
diablito's Avatar
diablito
diablito is offline
The directions are to put some type of glue...I follow them but after a few days it was loose again..the only way for the thing to stay on properly is to use a stronger epoxy, not glue.
Make sure you do not use the handbrake for at least 48 hours.
Old 05-14-2007, 10:09 AM
devious duck
I had the original hand brake off and then found out that the JCW one needed the epoxy. So i just put it back to stock and when i had the JCW aero kit installed the dealer installed the hand brake for me also. For Free. So no worries. If you do attempt to do this yourself you will need to epoxy it or ghetto rig something up to keep it on.
Old 05-14-2007, 11:19 AM
solberg's Avatar
solberg
solberg is offline
For those of you who have the JCW shift ****, how do you like it? I'm considering getting one myself.
Old 05-14-2007, 11:42 AM
PGT's Avatar
PGT
PGT is offline
the JCW e-brake is held on with Sikaflex, an adhesive/sealant available at most RV or boating stores. or, if you are like me and like the ability to ever take it back off again, loosely wrap some 3M Super 33+ electrical tape on the metal lever itself. Put enough and it's friction fit...not going to come off easily, but it's not permanent.
Old 05-14-2007, 01:51 PM
devious duck
I definitely reccomend the shift **** from JCW, it goes good with the brake lever and the shift **** feels good in the hand. I really like the finger grooves and it has a good weight too.
theblackfalcon
10-11-2015 09:49 AM
squawSkiBum
10-02-2015 09:21 AM
Colt45Magnus
09-07-2015 10:47 PM
Emnotek
08-13-2015 05:47 PM
minipopkart
08-13-2015 05:22 AM
Quick Reply: JCW Need help with JCW hand grip!!!!
