Interior/Exterior white front indicators
Old May 19, 2003 | 05:27 PM
6f7's Avatar
6f7
I like the look of the philips silver vision bulbs, but resorted to what was already in my garage. I had some standard 1156 bulbs and took a dremel and removed one of the alignment posts so that it would fit into the Y-connector. The bulbs are white and blink bright white. Now the side and front indicators are both white--a very sharp look with the b&w theme, IMO.
Old May 20, 2003 | 08:55 PM
red03miniS's Avatar
red03miniS
i am confused, can you elaborate more?
Old May 21, 2003 | 08:48 AM
6f7's Avatar
6f7
The alignment posts are little "nubs" that are on the metal collar of the bulb. They protrude from the collar only 1mm. One can be seen on this image:
The stock orange bulbs are PY21W12V. The alignment posts are not opposite each other, but at ~120 degrees.
The 1156 bulb is white, but has alignment posts that are opposite each other at 180 degrees. Since these posts will not line up with the slots on the cars socket at 120 degrees, you must sand/grind/cut one off. They are very small and could even be removed with some 200 grit auto sand paper.
I also looked into it a bit further and found that the 1156 bulb is 27W. So far, I've had no issues.
_________________
Old May 21, 2003 | 09:13 AM
red03miniS's Avatar
red03miniS
i have phillips blue vision in my lexus
what phillips lights fit there?
and you are talking about the turn signal indicators on the front bumper correct?
Old May 22, 2003 | 08:27 PM
red03miniS's Avatar
red03miniS
6f7--i did get 12w lights..from autozone..the only ones they had
they are clear..and i did the mod u suggested and it came out perfect..but its yellowish white..not as crisp white as my fender clear lights from phillips bluevision
where do i get the philips bluevision front bumper indicators?
my wedge phillips i got from england and they werent cheap
Ryephile
Suspension
113
Feb 9, 2020 03:43 PM
emulajavi
Dec 24, 2018 09:15 AM
boostedhaze
Jan 2, 2018 07:26 PM
FLYM1N1
Aug 15, 2015 11:20 AM
