Interior/Exterior Headlight Ring Removal
Old Mar 28, 2007 | 09:11 PM
MINIGolfer1's Avatar
MINIGolfer1
Does anyone have any good reference information on removal of the headlight rings on an '05 MCS with the washer option?
I need to take my chrome ones off, and am afraid to just start prying on them.
Old Mar 28, 2007 | 09:52 PM
glnr13's Avatar
glnr13
do it slowly or you'll break the tabs that hold em on
for the washers... i personally broke mine off (on purpose) and ordered new caps from the dealer. the washer arms need to be pulled forward in order to get to the cap and they seemed a little fragile. i preferred to snap em off than to try and take them off and possibly bust my washers arms
Old Apr 8, 2007 | 04:11 PM
Vinyl Styles's Avatar
Vinyl Styles
Hey Troy! I recently did a write up on the removal of the headlights and rings. I'll shoot ya a PM!!
Old Aug 14, 2007 | 08:40 PM
edubledie's Avatar
edubledie
man those rings are a painnnnn to take off
Old Aug 14, 2007 | 09:13 PM
IrishCooper's Avatar
IrishCooper
Hye Langston can i get that PM as well?
Old Aug 14, 2007 | 09:19 PM
glnr13's Avatar
glnr13
heheheh what happened to "in your face!"
Old Aug 14, 2007 | 09:30 PM
terryg's Avatar
terryg
Pop the bottom 3 tabs by gently prying near them with a small screwdriver. Take your time and try to keep the tabs intact.
Then slowly lift up on the ring from the bottom to detach the double sided tape. As it starts to come loose, slide the ring toward the top of the headlight to unhook the two larger tabs on the top of the ring.
Before reattaching, be sure and clean up the old tape, and use a good quality double-sided tape to reattach them.
Hook the top two tabs in first, then push down on the ring to engage the bottom three tabs. This part is tricky because one of the top tabs always seems to come undone.
For headlights with washers, have a helper fully extend the washer after you've loosened the ring. There is one larger tab on the curved side of the chrome piece, and 2 smaller tabs on the straight part. Pop the two tabs, then slide it off.
This is all infinitely easier if you remove the headlights to do the work, but make sure if you have washers that you put a plug over the water connector, unless you want a lap full of headlight water
Old Aug 15, 2007 | 08:31 AM
IrishCooper
Can you buy extra ones from the dealer?
Old Aug 15, 2007 | 08:40 AM
terryg's Avatar
terryg
We tried to pick some up at the dealer yesterday, but they wanted 60 bucks a set for the ones without washers, which seemed excessive.
Old Aug 15, 2007 | 09:20 AM
El_Griton's Avatar
El_Griton
yeah it comes to right around $100 for the rings with washers. to much for me.
Old Aug 15, 2007 | 09:46 AM
RussellCory's Avatar
RussellCory
I'm surprised that no one in the aftermarket has produced a set of unpainted tape on rings for the headlights. Kinda like the JCW cover for chrome grills. Something that would cover the chrome and be easily painted. Something that sells for OH… $50 - $60 unpainted.
Wink, wink, nudge, nudge, know what I mean???
Old Aug 15, 2007 | 03:00 PM
MUShadd's Avatar
MUShadd
xenon rings are $25 each from dealer
Old Aug 15, 2007 | 04:37 PM
MiniStupidfun's Avatar
MiniStupidfun
you will be hearing from me for those CF ones
Old Aug 15, 2007 | 09:53 PM
IrishCooper
Where did you get that? They are saying $100 for them above.
Old Aug 15, 2007 | 10:15 PM
glnr13's Avatar
glnr13
the standard headlight rings are $25. if you have xenon they are about $35 each, then the caps are about $10 a piece. total for standard=$50, total for xenon=$90
Old Aug 15, 2007 | 11:15 PM
MUShadd's Avatar
MUShadd
It may depend on the year as well...not sure, but I have an '04 MCs with Xenon. I bought one ring to replace a cracked one, it was 24.99. It came out to be 26 and some change after tax. (7% sales tax in ohio) It was just the ring, i didn't need the washer cover. This was at Midwestern MINI in Columbus, OH
Old Aug 16, 2007 | 03:53 PM
CARdiac's Avatar
CARdiac
Can you shoot it to me as well?
Old Aug 16, 2007 | 09:57 PM
MUShadd's Avatar
MUShadd
why not just post it up here..for all inquiring minds to see?
Old Aug 17, 2007 | 07:29 PM
Brihyanna's Avatar
Brihyanna
I'd love to know the how to as well!! Thanks! :D
Old Aug 24, 2007 | 07:44 AM
xkot's Avatar
xkot
look up there is a how to!
dyeLucky
Sep 11, 2015 10:41 AM
greekzilla
Aug 23, 2015 03:44 PM
kpl
Aug 11, 2015 04:52 AM
dyeLucky
Aug 7, 2015 07:10 AM
