Interior/Exterior Hood scoop diy
Old Mar 11, 2007 | 07:41 PM
Sublim3's Avatar
Sublim3
Hood scoop diy
I recently got a jcw hood scoop from Morristown but it didn't come with installation instructions. Does anyone have a diy for a noob here? Thanks!
Old Mar 11, 2007 | 09:13 PM
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
Open your bonnet. Look at the underside where the scoop is.
You'll see 2 phillips head screws. Undo them and put the screw somewhere safe. You'll also see 2 10mm nuts. Undo them MAKING SURE NOT TO DROP THEM and put them somewhere safe. The air diverter will come out with slight pulling.
You'll see 2 more 10mm nuts. Remove them, again without dropping them, and put them somewhere safe. The scoop will now lift out from the upper side of the bonnet.
Reverse the procedure to install the new scoop.
Old Mar 12, 2007 | 06:36 AM
nixjosh2's Avatar
nixjosh2
put a blanket or or old towel on the engine compartment (Cold not hot) to catch any errant nut that will fall out of your hands, this will save you much frustration
Old Mar 12, 2007 | 07:31 AM
minimusprime's Avatar
minimusprime
mine had these two little plastic covers i had to pop out and hold back while getting access to the front two little bolt thingies. just fyi.
Old Mar 12, 2007 | 07:39 AM
MiniMacPR's Avatar
MiniMacPR
^^^+1, I also had the covers...
Old Mar 12, 2007 | 07:49 AM
Sublim3's Avatar
Sublim3
Thanks guys, mine are covered up too. I'll work on it later today. Thanks for the responses!
Old Mar 12, 2007 | 11:05 AM
Sublim3's Avatar
Sublim3
Ok, was able to access the other two nuts after removing the 2 plastic covers. Im such a ******* sometimes. I appreciate the tips from all. The JCW cf scoop fits perfect.
Old Aug 26, 2010 | 04:58 PM
Blington's Avatar
Blington
I'm a complete newbie and I'm trying to install a chrome scoop. I removed the air diverter, got the scoop to pop up but there is something holding it back in the middle on the front. Are you suppose to remove 6 screws in total? I only removed 4.
Thx!
OutMotoring
Mar 3, 2017 06:29 AM
Colt45Magnus
Oct 1, 2015 04:08 PM
M7Speed
Oct 1, 2015 07:05 AM
mini merle
Sep 30, 2015 04:42 PM
drum6g
Sep 29, 2015 01:15 PM
