Interior/Exterior Blacked-out gas cap/cover
Old Mar 7, 2007 | 03:16 PM
low-n-fast's Avatar
low-n-fast
I am in the process of blacking out an mcs. i have replaced the grills, black wheels... but i can not find a black gas cap cover to replace the chrome one that comes with the mcs. Any ideas?????
thanks
Old Mar 7, 2007 | 03:24 PM
SHRTSTAK's Avatar
SHRTSTAK
Most people get it powder coated. I don't think any vendors sell a direct replacement.
Old Mar 7, 2007 | 03:59 PM
El_Griton's Avatar
El_Griton
yep powder coat or paint it re the most common ways to black them out. are you going to do the door handles also? if so them get them both powder coated at the same time and save time and money.
Old Mar 7, 2007 | 04:47 PM
DrPhilGandini's Avatar
DrPhilGandini
My little dose of LITHIUM
I have the gas cap powder coated -- relatively simple because it's made of casting metal (zinc and aluminum I think). But the door handles are plastic, so you *can* get them powder coated but powder coating plastic is a relatively rare and expensive process compared to p-c metals. Most people paint the door handles to mixed results. Remember in this case the end result is directly proportional to preparation effort.
Old Mar 7, 2007 | 04:54 PM
CR&PW&JB's Avatar
CR&PW&JB
Or... you could have Mike at Aesthetic Creations make you a vinyl cover in black, like the one he made me in Checkers. Of course, he'd have to modify it a little bit to completely cover your lid.
Old Mar 7, 2007 | 07:00 PM
El_Griton's Avatar
El_Griton
wow, i didnt relize they were plastic. and i was planning on doing just that, what to do now......
Old Mar 7, 2007 | 07:46 PM
ANT818's Avatar
ANT818
be carefull with the gas door. i sent my cooper works exhaust tips to be jet coated in flat black. at the same time, i figured i'd include the gas door. it couldn't take the heat. the compostion of the gas door could not withstand the heat. they sent it back looking like an oatmeal cookie. however, the tips look great. if you find a source for pc the plastic handles please share it.
Old Mar 8, 2007 | 09:16 AM
low-n-fast's Avatar
low-n-fast
thanks for all the thoughts i guess i will look into the powder coating for the filler cap, but i think the handles would get scuffed to easily anyway.
Old Mar 8, 2007 | 09:23 AM
Vinyl Styles's Avatar
Vinyl Styles
The gas cap can be sanded down with some 220 grit or so and coated a couple times with some good quality spray paint (I used SEM).
The door hands are a pain in the a$$ to remove. I sprayed mine with 2-3 coats of SEM semi-gloss black and I do have a few minor chips, mainly from my front tires kickin' up rocks. A sharpie can fix those tho!
Old Mar 9, 2007 | 12:08 PM
JS's Avatar
JS
I removed gas cap and lightly media blasted outer surface, then painted. Very easy. Handles I'll scuff with Scotchbrite and paint.
JS
Old Mar 9, 2007 | 12:28 PM
Partsman's Avatar
Partsman
Legion_of_Doom
JS
That's how i'm going to do my handles and grille surround, Joel. Be sure to post(or send me) some pics when you're done.
I also painted my gas door and side grilles...
Old Mar 9, 2007 | 12:50 PM
El_Griton's Avatar
El_Griton
i did my gas cap last night. turned out WAY better then i thought it would just using some krylon camo ultra flat black. ill be doing the handles whenever it stops raining here.
scfiveo
Sep 27, 2019 02:27 PM
PsychoRallye
21
Feb 17, 2019 06:08 AM
OutMotoring
Mar 3, 2017 06:29 AM
riff42
Sep 22, 2015 03:07 PM
mini_mike237
Sep 21, 2015 08:42 AM
