Interior/Exterior R56 roof rack
Old Feb 26, 2014 | 03:51 PM
  #401
hokusai's Avatar
hokusai
Originally Posted by walk0080
There is a gap on mine. I believe if it touches the roof it will damage your paint eventually while driving on the highway.
I'm still waiting for info on the "shoulder bolts PN 82792354857". I've emailed four dealerships nearby and none of them answered. I knew my usual dealership has a crummy parts department (and now I am convinced pretty terrible maintenance as well based on my last visit)... but four dealership parts department all ignoring their email requests? I'll have to stop by sometime when nearby I guess to force MINI to take my money - haven't found any source online in Canada yet.
Thanks for the response!
Old Feb 27, 2014 | 06:05 AM
  #402
I haven't been able to use mine for a while now. I bought mine used and I think it was very heavily used for several years.
Anyways my torque wrench seemed to have busted because I stripped two of those brass nuts months ago and the little lines never lined up to indicate I reached the correct torque. I installed/removed the rack two times previous to this 'incident'.
We have been thinking about a roof box and buying a replacement rack would be $260 + shipping. Checked realOAM today and I see that there are now replacement brass nuts available! I don't remember them being there in the past.
Anyways, here are the details. I'm checking with my dealership but I expect them to be ridiculously over-priced. I'll just keep the rack on most of the time. I don't drive much on the highway so reduced gas mileage is not much of an issue.
http://www.realoem.com/bmw/showparts...71&hg=82&fg=51
Set of Shoulder Nuts (4pk): PN 82792354857
Torque Wrench 6NM 5mm: PN 82722230149
We have them here:
The nuts set currenlty will have to come from overseas, but are available.
#11 Set of Shoulder Nuts (4pk): PN 82792354857
http://www.ecstuning.com/Search/SiteSearch/82792354857/
#5 Torque Wrench 6NM 5mm: PN 82722230149
http://www.ecstuning.com/Search/SiteSearch/82722230149/
Thanks and hope that helps.
Old Feb 28, 2014 | 09:43 PM
  #403
walk0080's Avatar
walk0080
Old Mar 3, 2014 | 06:30 AM
  #404
schatzy62's Avatar
schatzy62
Just spoke with Penske Parts, www.penskeparts.com (Inskip MINI in Rhode Island). From what they told me the nuts are not in stock at the North American Warehouse. They would have to be ordered from Germany.
If you contact them they will order the parts for you. Their cost is about $22.00 USD. But you would still have to pay for shipping and that would probably cost you about $20-25 unfortunately.
So maybe call your local dealer and ask them to special order them, or get them from the guys at ECS.
Others have also found regular nuts that will fit the threads and used a washer behind it.
Old Mar 8, 2014 | 03:33 PM
  #405
dedalus5550's Avatar
dedalus5550
I've read through a good portion of the latter part of this thread. I have one question. Is the 2013 Hardtop S set up for this? I ask because, man, I can't see any evidence of perforation in the rain gutter seal. I looked. Then I read posts where people say it's not obvious. Then I looked again and couldn't see it. Then I read posts where people say it's really, really hard to see. Then I looked again. Every angle. Lifted up the edge to look around. Just can't find it. And I'm assuming without knowing exactly where to put it, it might damage the roof in some way if put in the wrong spot.
If it helps, for those who have done it, can you measure an exact length from, say, the read edge of the door window?
Thanks,
Mike Todd
Old Mar 8, 2014 | 04:59 PM
  #406
walk0080's Avatar
walk0080
Old Mar 8, 2014 | 05:01 PM
  #407
MikewithaMini's Avatar
MikewithaMini
The perforation is really a perforation but just little vertical imprints on the rubber as it lays up against the top. As I recall the front is like 4 5/8 in. I'd you have the install instructions I believe the measurements are there. Lighting is everything when you are looking.
Old Mar 8, 2014 | 05:11 PM
  #408
Kirby11's Avatar
Kirby11
there's a post earlier in this thread with all of the measurements.
https://www.northamericanmotoring.co...ml#post3387716
Old Mar 18, 2014 | 03:16 PM
  #409
Gitmoe's Avatar
Gitmoe
Originally Posted by MikewithaMini
...Lighting is everything when you are looking.
I agree. Lighting is everything. This might help...
Old May 18, 2014 | 05:49 PM
  #410
webfoot1's Avatar
webfoot1
Very good explanation for installation of your rack can be found here: http://turn17.com/?p=261
The cutouts are located at 9.25 inches and 36.25 inches as measured from the back of the post at top left of the driver side windows and top right of the passengers. They are 2.25 inches long.
The easiest part to see on my Mini were the vertical lines ( | ) on both sides of the cutout. These two lines are on the piece of rubber immediately adjacent to the roof. This is the part of the rubber that you slide the card behind.
Having found that I could then see the lines in the bottom of the rain gutter
( _ _ _ _ _ _ _ _ ) Slide the plastic card behind the rubber and use tweezers to pick the rubber up and away from the card and roof. I found it easier to use the tweezers to pick up the rubber and then used needle nosed pliers to remove the cutout. You will then have to use either one to remove the corners that did not come out with the rest of the cutout.
Now, if only I had not stripped one of my nuts....My rack would be on. Going to do the nut with washer fix posted here.
Old May 26, 2014 | 07:29 PM
  #411
MotorWorf's Avatar
MotorWorf
MINI Crossbar
Cabela's Carrier
4 Hella 500s Lamps + 4 MINI Lamps = 8 Off-Road lights
Headlamps
Fog Lights
Old May 26, 2014 | 07:34 PM
  #412
MotorWorf's Avatar
MotorWorf
Another view from the rear
Old May 26, 2014 | 07:35 PM
  #413
MotorWorf's Avatar
MotorWorf
Side view
Old Nov 17, 2015 | 07:37 PM
  #414
walk0080's Avatar
walk0080
Old Jan 11, 2017 | 08:21 AM
  #415
kdotv23's Avatar
kdotv23
Can you guys tell me if I installed this right. Do I need to push it in the rain gutter more? Although it seems like I've pushed far in enough. Any thoughts?
Old Jan 11, 2017 | 08:34 AM
  #416
walk0080's Avatar
walk0080
Old Jan 11, 2017 | 08:37 AM
  #417
kdotv23's Avatar
kdotv23
Looks ok to me... I would usually push inwards on the two flaps with one hand while tightening the bolt with other hand using the little torque wrench. Very easy to strip the brass nuts so use the torque tool.
My replacement stainless steel nuts and washers have so far been holding up well... the trick is to never remove the rack - leave it installed at all times.
I'm probably just over thinking the install. I pulled on the rack with lots of force without movement so I think it should be pretty secure. Thanks man
Old Jan 11, 2017 | 09:09 AM
  #418
MrT's Avatar
MrT
kdotv23, looks good, that's as far it will probably go.
Old Jan 11, 2017 | 12:51 PM
  #419
kdotv23's Avatar
kdotv23
thanks for the input. nice to have some reassurance. I was gonna take them off again just in case
Old Jan 14, 2017 | 05:53 PM
  #420
BMC_Kid's Avatar
BMC_Kid
Looks more or less ok to me... I would usually push inwards on the two flaps with one hand (the area just above the nut/bolt) while tightening the bolt with other hand using the little torque wrench. Very easy to strip the brass nuts so use the torque tool. See if you can push inwards anymore and if torque tool allows you to go any tighter.
I take mine off and on all the time. In fact, when I do I take it off and put it back on as a unit - towers connected to the cross bars. Never have had any problems but you get good at taking it off and on doing it as much as I do.
Old Jan 14, 2017 | 11:34 PM
  #421
Zephyr1's Avatar
Zephyr1
The designer of this mechanism should be sent to remedial engineering 101. And should be forced to take one of these off and put it back on once per day, for the rest of their life. This is rpobably the single worst design I have ever come across. 1000 easy ways to do this better. I hope they fired this person. Rant off.
Old Jan 16, 2017 | 03:32 AM
  #422
schatzy62's Avatar
schatzy62
just as BMC Kid does i take mine on and off all the time. In the 8 years i have owned mine it has been on and off the car at least 800 times and i have NEVER NEVER NEVER stripped a brass nut or had any problem geting them on or off. In fact I can put both rakes on the car correctly in less than 3 minutes. Those that have problems putting it on or striping nuts just dont have them set up properly to begin with. The first time they go on the car there are screws on the underside of the rails that have to be lossened just enough (1/2 - 3/4 turn) to allow the mounting brakets and rails to slide against each other and then once the brackets are tight and mounted then the bolts connecting the rails and brakets need to be tightened and never touched again. After that is done they are easy to take on and off. I have helped many people up here in new england get the racks seg up properly when thier dealers could not and all of these people take them on and off regularly. If done correctly they should be easy on easy off.
Old Jan 16, 2017 | 05:09 AM
  #423
randeez's Avatar
randeez
havent had any problems with mine either, goes on and off couple times a month usually - my bike rack stays on the cross bars and i put it on the car as one piece. I made some tabs out of 3/16x1" stainless stock, drilled and tapped to attach it.... hated the "clamping" style mounts
Old Jan 19, 2017 | 08:30 PM
  #424
TVPostSound's Avatar
TVPostSound
Looks fine, if the two halves were touching, there would be no room to tighten if wear occurs.
Old Dec 20, 2020 | 01:10 PM
  #425
zwingtip's Avatar
zwingtip
Sorry to bump an ancient thread... anybody have tips on installing the rain gutter caps?
I took the rack off my R56 since ski season isn't coming this year, but apparently I'm either too weak and pathetic to get the caps in or I'm doing it wrong. One side goes in, but then the other side won't move. I'm pretty sure the plastic lip is supposed to face up, but I've tried it both ways and failed.
