Interior/Exterior Sveedish armrest installation
Old Dec 25, 2006 | 04:48 PM
Puddle Jumper's Avatar
Puddle Jumper
Mrs Claus gave Santa the Sveeedish armrest offered through Mini Mania. http://new.minimania.com/web/Item/NM.../InvDetail.cfm Has anyone installed one of these babies and can they give any tips? Thanks!
Old Dec 25, 2006 | 05:25 PM
Motor On's Avatar
Motor On
Originally Posted by MiniMania
To see how easily this unit can be mounted, pull the plastic seat backing off (backside of the seat) and see how easily you can access the mounting area. Simply give a good tug at the top of the plastic seat back and it will pop off and swivel down. The seat material can be peeled back by release a few clips and springs. Lumbar **** and bracket will add a few minutes to the assembly. Requires a small hole in the leather for the shaft.
This seems much more like the way to go instead of the other install instructions that they linked externally to.
Old Dec 25, 2006 | 06:38 PM
Puddle Jumper
Thanks Drew Wondering if we have to remove the seat or can leave it in... and then there's disconnecting the battery.... don't want the airbags in the seat popping (Hope your Christmas was merry!!)
Old Dec 25, 2006 | 08:30 PM
Motor On's Avatar
Motor On
I think you should be able to leave the seat in, but it may be a crampt work space. I doubt you'll touch anything related to the airbags going through the back of the seat hoever it is probably a safe move to undo the battery for 15-30min just to be sure. If it turns out there's not enough room in the car and the seat needs to be removed then you must undo the battery to avoid warning lights. I'd love to see a photo with the back compeletely off, I'm not sure just how deep the framing for the seat is.
Feel drop me a PM if you want a spare hand or find you need to borrow a torw screwdriver or some random tool.
(Very Merry Christmas this side of town)
Old Dec 25, 2006 | 11:52 PM
Jtrem's Avatar
Jtrem
I would also like to see the back of the seat off. I wonder what it looks like hmm....? I bet there is candy in it!
Old Dec 26, 2006 | 11:19 AM
scooterboy's Avatar
scooterboy
I installed mine a few weeks back. Here's my post about the installation.
No need to remove the seat or disconnect anything. The plastic seatback popped right off with a moderate pull. I left it attached at the bottom like it was hinged. This left plenty of room to peel the inner bolster seat cover forward and install the bracket.
If you run into any problems, I'll keep my eye on this thread and help if I can.
Old Dec 26, 2006 | 03:02 PM
Puddle Jumper
Thanks for the support! Am going to start the process... will update with photos of progress shortly.. I hope.
Old Dec 26, 2006 | 06:42 PM
Puddle Jumper
Success!! The installation only took about an hour, and I'm very happy with the results! Your input about the seatback removal was much appreciated Scooterboy, since it is not mentioned in any literature!! We ended up just taking the whole back off for easier access.
Here are some pics: bracket to put in, removal of the seat-adjusters, we found a Knome overseeing our heating elements (for those of you interested what was inside the seat.. he watched to make sure we didn't accidently slice anything since the elements are a spun wire, embedded in some of the foam), a bit of foam had to be removed for the bracket to sit properly, it wasn't mentioned but a portion of the armrest support is unnecesary to fit a MINI's svelte proportions, and the final product installed.
Off for a drive to test it out!
Attached Thumbnails Sveedish armrest installation-christmas-06-045.jpg   Sveedish armrest installation-christmas-06-030.jpg   Sveedish armrest installation-christmas-06-033.jpg
Old Dec 26, 2006 | 07:36 PM
Puddle Jumper
Back from the drive, and Highly recommend this armrest!! This outdoes the factory op because it is so adjustable! Looks like it was a factory fit too!
Here are the other pics that wouldn't fit on the last post....
Happy to give more feedback!
Attached Thumbnails Sveedish armrest installation-christmas-06-049.jpg   Sveedish armrest installation-christmas-06-012.jpg   Sveedish armrest installation-christmas-06-018.jpg
Old Dec 26, 2006 | 07:38 PM
Motor On's Avatar
Motor On
Looks Great!!!
Old Dec 26, 2006 | 08:18 PM
kurvhugr's Avatar
kurvhugr
Old Dec 26, 2006 | 08:50 PM
scooterboy's Avatar
scooterboy
Nice job!
I'm jealous - I didn't have gnome in my seat to help me...
adrchn
Aug 13, 2019 02:11 AM
minimofo
Nov 5, 2015 08:40 AM
minimofo
Oct 25, 2015 05:53 PM
minimofo
Sep 9, 2015 10:29 AM
