Interior/Exterior "High Temp" paint and OEM Cooper S tail tips?
Old Sep 28, 2006 | 01:25 PM
ImagoX's Avatar
ImagoX
Question: What kind of "high temp" paint would you guys recommend for painting the inside of the OEM Cooper S exhaust tips?
I recently purchased a pair of these from a fellow NAMer, and they looked great - they were black on the inner edge, which I like. They looked fabulous for a few weeks, then a large bubble appeared in the paint, which quickly flaked off, leaving a fugly, exposed patch.
I plan to sand down the existing paint and re-paint, but I need to know what to buy for this high-temperature application and where to get it, please.
Thanks!
Old Sep 28, 2006 | 01:31 PM
yumyumdriver's Avatar
yumyumdriver
I used high temp Bar-B-Que paint and it still looks the same as when they went on the car in May.
Old Sep 28, 2006 | 01:32 PM
DarkMiniCooperS's Avatar
DarkMiniCooperS
I guess an engine's head paint would do it...
It is available at any auto parts stores and can handles high temps.
ImagoX's Avatar
ImagoX
BBQ... good idea. Just from the local DIY store? Did you have to do any special prep?
Old Sep 28, 2006 | 01:38 PM
agranger's Avatar
agranger
I was going to suggest the BBQ paint as well. I saw it once at Home Depot. It's flat black. Prep instructions should be on the can.
Old Sep 28, 2006 | 01:43 PM
ImagoX's Avatar
ImagoX
Sounds PERFECT. Thanks - I never would have thought to go that direction...
Old Sep 28, 2006 | 01:50 PM
agranger's Avatar
agranger
... or you could just leave 'em unpainted... a MCS runs so rich that they should be black in a day or two!
Old Sep 28, 2006 | 01:57 PM
ImagoX's Avatar
ImagoX
Yeah, but it's so blotchy...
Old Sep 28, 2006 | 03:52 PM
ignote's Avatar
ignote
BBQ Paint and I didn't prep them first. Just use 4 or 5 light coats allowing them to dry between.
Old Sep 28, 2006 | 03:55 PM
PGT's Avatar
PGT
ThermoTec from www.summitracing.com - About $7. I did the front pipe in silver and rear section in satin black. It's good to 1200F and cures with heat cycling. I sprayed the exhaust housing on the turbo on my Subaru with it and it's holding up great (which says alot as a turbo gets MUCH hotter than the exhaust tips)
Old Sep 28, 2006 | 07:49 PM
schulzmc's Avatar
schulzmc
I used some black spray paint I had from a fireplace store. Made by "Rutland" and called 1200 degree stove paint. It's used to paint the bricks inside your fireplace or to repaint a wood-burning stove.
Mark S
Old Sep 29, 2006 | 07:19 AM
ImagoX's Avatar
ImagoX
That all-black look is really nice... I may have to consider doing that... Hmmmmm.... I wonder how I'd prep the chrome peices of I decided to go that way, though.
I fear that the old paint won't strip off well... Should I use sandpaper or steel wool or what to prep the tips? My fear is that I'll paint over the existing stuff that looks solid and that it will peel later on.
Old Sep 29, 2006 | 07:42 AM
omascow's Avatar
omascow
Scrub it
Just give it a good scrub with some steel wool or an SOS pad and then give it a bunch of coats of BBQ paint. About 5 coats will coat it nicely. The other day I decided to clean mine with my tire brush for the first time and come black paint scratched off, but im not worried, it soots up in that area anyway so you would never tell that a little paint is missing (as long as I dont try to clean them again with the tire brush )
Jan 4, 2019 12:51 PM
Aug 11, 2015 11:58 AM
Aug 10, 2015 02:03 PM
Aug 10, 2015 01:59 PM
