Interior/Exterior Broken Door Lock
Old Sep 18, 2006 | 05:54 PM
xnotfunkylex's Avatar
xnotfunkylex
Broken Door Lock
I wasn't too sure where to post this, but this sounded right. My driver side door will no longer unlock with the key or the center lock switch. But it will lock using the key. Has anyone had this happen or does anyone know how to fix this. It really sucks having to use the key hole every time I get in the car. Any help is awsome.
Kyle
Old Sep 19, 2006 | 05:27 AM
muppetmandan's Avatar
muppetmandan
I have EXACTLY the same problem, it started about a month ago. I does suck having to use the "old fashioned" method.......lol It's like having to get of the couch to change the TV channel rather than using the remote!!
My dealer said that i need a new part in the door, and so have many members here. Only problem is, i'm at 60k so no warranty. I think it's about $200 to get the problem fixed.
I was going to get the part and do it myself, but i can't figure out how on earth to get to the mechanisim (sp?) as i can bearly get my hand in there.
Old Sep 19, 2006 | 10:59 AM
ProfessorDave's Avatar
ProfessorDave
I also have this problem, but am fortunate enough to still be (just) under warranty. It is definitely something I would live with otherwise.
I believe the door lock actuator is the culprit, and can be reached easily by removing the door panel (I know I saw a write-up on how to do that somewhere here on NAM).
Anyone out there attempt this repair on there own?
Old Sep 19, 2006 | 02:46 PM
muppetmandan
I did remove the door panel, but it was still VERY tight. I can't find a write up anyware :(
Old Sep 19, 2006 | 03:14 PM
xnotfunkylex
Thanks for the info. I think I will see what Johnny's Auto Clinic in San Pedro can do it for. He does really good work with the MINI's. Or I guess I may just have to deal with it.
Old Sep 23, 2006 | 08:43 PM
k-huevo's Avatar
k-huevo
I’m patiently awaiting a report on the fix and part number. Mine went out today. Getting the panel off is no problem.
Old Sep 23, 2006 | 09:44 PM
Ryephile's Avatar
Ryephile
Mine is also ka-put. I can hear the solenoid trying to work, but it no longer actuates the mechanism, so I'm stuck doing ye ole fashioned key operation to lock and unlock. I already have a new assembly sitting here, but it looks daunting, LOL!
It does look very tight in there. I'm not sure how to seperate the outside door handle from the black box. Even if that happens, I really hope the box comes out past the window mechanism! It would be nice if the Bentley manual had a tip or hint, but alas, yet again, when something tough needs repair, the Bentley is silent. Anyone out there actually replace theirs successfully?
Old Sep 24, 2006 | 08:53 AM
norm03s's Avatar
norm03s
My passenger door is doing the same thing.
I'd like to see a superfix beyond just the replacement of the same OEM parts that will fail again, that is unless k-huevo comes up with an upgraded OEM part.
Old Sep 24, 2006 | 09:08 AM
vm's Avatar
vm
To remove the door panel:
Unscrew and pull. That's what I remember.
Old Sep 26, 2006 | 09:04 PM
k-huevo's Avatar
k-huevo
Mine started working yesterday.
Old Sep 26, 2006 | 09:14 PM
Ryephile's Avatar
Ryephile
I would definitely appreciate some elaboration on your process! I'm not one of those lucky ones that has their door lock mechanism start behaving itself again like k-huevo's!
techgearpro
Jul 23, 2019 07:09 PM
xpunisherx
Nov 27, 2015 03:32 PM
Filmy
Sep 7, 2015 08:27 PM
F55MidnightBlackCooperS
Sep 3, 2015 04:02 PM
spackletooms
Sep 1, 2015 10:12 PM
