Interior/Exterior How to remove the back seats
Old Aug 11, 2006 | 09:56 PM
flannelhippie's Avatar
flannelhippie
Help? I want to if they are easy to put backin, but if not, then I not gonna bother with it.
Old Aug 11, 2006 | 10:06 PM
Eastsidemini's Avatar
Eastsidemini
removal
Pull and lift the seating part off, you will find few bolts in fr/rr, tilt the back at 45 degree towards the front of the car and lift up.
Old Aug 11, 2006 | 10:11 PM
flannelhippie
One thing, I got the front part of the seat unclipped, is the back the same way? Just a little force, I didnt want to pull to hard, and break anything.
Old Aug 11, 2006 | 10:17 PM
Motor On's Avatar
Motor On
You have to pull the carpet back a little bit to get to the center bolts. I'll do a search and see if i can find the detailed instructions. The bolts are the easy part, but the back takes some "persuading" to find the right postion to get the pivot points out, rember one at a time and seat backs need to be mildly angled one at a time to get the sweet spot for removal.
Old Aug 11, 2006 | 10:21 PM
Motor On's Avatar
Motor On
Originally Posted by sanity29
yes you need to remove the bolt in the center holding the two seats together. then lay the right side down and remove the left side first. it is easier this way. when removing you need to kind of wiggle the seat backa nd forth while pulling it out. the reason for this is becasue the seat has two tabs i guess you can say. and the peice the are in has matching slots for these tabs. so the point of wiggling is to get the tabs to find those slots and it will just pop out. doesn't take much effort or work, but once you get the first side out you will see what i mean.
hope this help s and doesn't confuse you any more. any questions just ask. as mine have been out for over 2 years now and i just installed a false floor since there is no room for people back there any ways.
later
ja
From another thread.
Old Aug 11, 2006 | 11:07 PM
Eastsidemini
removal
You will not break the seat BTW. You just need to find the right angle (45 degree) on mine and pull up.You will need to be in back of the front seat when you're doing it.
Old Aug 12, 2006 | 06:55 AM
flannelhippie
But, are they easy to put back in?
Old Aug 12, 2006 | 07:52 AM
Rick-Anderson's Avatar
Rick-Anderson
I made some detailed Instructions:
Page 1 http://i44.photobucket.com/albums/f3..._mini/rsd1.jpg
Page 2 http://i44.photobucket.com/albums/f3..._mini/rsd2.jpg
Old Aug 12, 2006 | 09:31 AM
snid's Avatar
snid
The rear seat bottom is cake to take out / put in. No tools or anything. Well, putting it back in might be a touch harder than pulling it out, those little child seat / LATCH thingies can be a little difficult to snap in sometimes (like maybe a 2 on the 1-10 scale of difficulty).
The seat backs are pretty easy to put back in. One bolt is involved, and I usually just loosen it, not remove it completely. I'd probably say for the seat backs, putting them back in is a little bit easier than taking them out.
This is all assuming you're not also removing / replacing the seatbelt hardware and such, just the seats themselves.
Old Aug 12, 2006 | 09:37 AM
snid's Avatar
snid
I just looked at Rick's pictures, and they're different from how I remove my seats. Not sure if it's a model year change, or if he's removing some of the brackets along with the seats...
Looking at these pictures:
The only bolt I loosen (not even remove) is seen in the second picture, it's the one directly above the one that is being removed - the one that is between the seat back halves. Loosen that until the top part of the "plate" moves enough to let the pin attached to the seat back slip out of the bracket. Wiggle things and loosen that enough and the pin will pop out of the bracket in the center. Find the right angle and the pin on the outboard side of the seat will come free.
Old Aug 19, 2006 | 05:57 PM
MisterCooper's Avatar
MisterCooper
Easy
It's a lot easier than that even. From the boot, fold down the two seats and unscrew the bolt that's between the crack of the two seats (as referenced in the post directly above). Take the bolt all the way out, and what you're now looking at is a latch. Push the top part of the metal bracket toward the front of the car and then the seats are free to come out. Take the middle part out first and then angle the seat 45 degrees and pull the seat toward the center of the car to remove the seat from the outboard side.
Old Aug 19, 2006 | 07:36 PM
MidnightDave's Avatar
MidnightDave
Just did a rear seat delete to mine today, to put in a Shrader Performance kit. It was all guys, so we didn't read the directions (included), we just unscrewed the center bolt and as many size 40 torx heads as we could find and it wiggled right out. Then we put the extra bolts back in! ;-)
(not me, a buddy named Steve, credit to him for working while I took pics...)
Old Feb 7, 2007 | 02:08 PM
fj0's Avatar
fj0
I wanna put my car on fire, I just can't get the damn seats out!
Old Mar 21, 2007 | 02:29 PM
davavd's Avatar
davavd
Anybody know if these instructions have been tried on a convertible?
flyers47
Jul 27, 2020 02:38 PM
surfblue
Oct 24, 2018 01:20 AM
steelz21
Sep 12, 2015 10:06 PM
Mini'mon
Aug 26, 2015 01:02 PM
DWooderson
Aug 10, 2015 09:12 AM
