Interior/Exterior Installed Quintuple Checkerboard Stripe
Old Jun 3, 2006 | 11:50 PM
neilgj's Avatar
neilgj
It didn't take too long and I think it looks pretty good - [pictures soon].
I installed a quintuple checkerboard bonnet stripe on my LY MCSC. It took about 2 hours including the time to run out to the hardware store to get some double-sided tape to re-apply the MINI emblem. It's not too hard. It seems like the trick is to make the bonnet wet enough to allow you to float the stripe on a small layer of water and move it around until it's in position. Then you use the squeegee included in the kit to sqeeze out the water and a soft towel to pat it dry. I used a sharp knife to carefully cut the edges of the sticker at the gaps at the scoop and the grill.
I removed the front MINI emblem using a heat gun to warm it up (carefully - not too hot as it's just made of plastic) and then dental floss to lift the edges. With the edges up high enough, I inserted a wooden toothpick at the center of the emblem to loosen the adhesive tape there. Then more pulling with the dental floss and it popped off.
I used soapy water to remove the remnants of the adhesive tape from the bonnet and soaked the emblem for about 30 minutes to loosen the adhesive still stuck on it. I picked that off with my fingernails.
The stripe is black checkerboard with the LY showing through to create the checkerboard design. I got it from MightyStripes. I have enough left over to do the boot, too. Maybe next weekend...
Old Jun 4, 2006 | 12:25 AM
neilgj's Avatar
neilgj
Here are some photos:
https://www.northamericanmotoring.co...0&size=big&cat=
https://www.northamericanmotoring.co...27268&size=big
Old Jun 4, 2006 | 12:35 AM
jchanger's Avatar
jchanger
Nice job!
Now just pack some checker/chess pieces in the glove box and you'll never be bored, unless you're playing by yourself I guess...
Old Jun 4, 2006 | 01:33 AM
Motor On's Avatar
Motor On
Looks good
By the title I was expecting to see one of the side stripes but I think that this was a very neat additio to your MINI and I like the wat it matches the LY, a mix between the race track and taxi cab.
Old Jun 4, 2006 | 06:22 AM
kenchan's Avatar
kenchan
cool!
Old Jun 4, 2006 | 06:53 AM
gt6's Avatar
gt6
Very nice, and different. It's a clean look.
Old Jun 4, 2006 | 07:01 AM
qwertmonkey's Avatar
qwertmonkey
Looks pretty sweet. I like the fact that it tucks under the scoop!
P.S. Nice badges!
Old Jun 4, 2006 | 12:38 PM
illegalprelude's Avatar
illegalprelude
yea man, I like that alot. GGRRR. I wanna go checkered on my car so bad but do to the other theme I started before, I cant or it will look like a mess with different colors and themes :(
adrchn
Aug 13, 2019 02:11 AM
MoganDavid
Mar 14, 2016 10:44 AM
squawSkiBum
Oct 2, 2015 09:21 AM
bctf1
Aug 6, 2015 12:55 PM
